Opinions On Cold Air Intake
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Apr 28, 2015.
  1. Apr 28, 2015 at 2:50 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    What do you guys suggest for a cold air intake (brand, wet or dry, horsepower, etc...)? I have a 2003 4cyl Xtra Cab. I need a bit more horsepower to help on the hills, I know of K&N but I don't know much about them. Except that they are really expensive, are there any advantages to them?
    Thanks
    Liam
  2. Apr 28, 2015 at 2:51 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
  3. Apr 28, 2015 at 2:59 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    look up deck plate mod and maybe a afe pro dry filter. I wouldn't go with k&n. and no need for a CAI. do the deck plate mod and your good
  4. Apr 28, 2015 at 3:02 PM
    goldentaco03
    Liam
    NJ
  5. Apr 28, 2015 at 3:04 PM
    pudge151
    Sean
    Connecticut
  6. Apr 29, 2015 at 10:58 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    get a true cold air :devil:
    bowyer2002 likes this.
  7. Apr 29, 2015 at 11:53 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You asked for opinions so I will give you mine as there is NO definitive answer to this question.
    Stock intake is a CAI.
    K&N filters work just fine, do not over oil it, most common problem and it's on the end user to do it right. There is a procedure to oil them, follow that procedure and it will be just fine and give many years of service. Over 120,000 miles on my K&N and absolutely no problems. Engine has 232,000 miles currently. Dry air filters work just fine too, I'm not knocking them at all, it's totally your decision as to what YOU want to use.
    Really the biggest advantage to using any washable filter is that you save money over time by not having to buy a disposable filter. Not actual HP increases, but possibly slightly better throttle response.
    Deck plate mod, I have no opinion on this. Supposedly there is somebody who ran a dyno test and there was some increase. A lot of guys are doing it. Biggest thing you hear back is increased intake noise and having to plug the hole when it rains. If you do this mod I suggest a screen over the hole so as not to end up with excess debris in the air box.
    Removing the two intake resonators and plugging the holes will help a little with throttle response, when combined with a slightly free-er flowing muffler. Again this will add some intake noise but it's not too bad unless you drive at WOT all the time. I myself have done this and for the moment am pretty happy with it. I have not noticed any significant HP increase but the engine does rev up a bit smoother and the throttle response is slightly better.
    Better way is to do an aftermarket intake tube that is smooth, no resonators, and it will have the proper vacuum line connections. If you do this, some kits remove the stock airbox all together and add the cone shaped filter with an engine shield to keep the cold air coming in. Other kits simply replace the tube itself and you retain the stock airbox and filter of your choice.
    None of these will give significant HP increases, but every little bit helps.
    With your 4-banger I think a lot of guys swear by the long tube exhaust header for actual "feel it in the seat of the pants" horsepower increases. :)
    When did you last do a tuneup? New plugs and wires every 30,000 miles can make a hell of a difference.
  8. Apr 29, 2015 at 1:36 PM
    goldentaco03
    Liam
    NJ
    I just got it and have been meaning to do a tuneup. I don't necessarily feel like redoing headers so I'm looking for some easy things to increase my HP. Anyone have any more details on deck plate mod?
  9. Apr 29, 2015 at 1:38 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    without going full blown super charger you arent going to gain HP. if you swap the intake, headers and exhaust you get a smoother flowing louder less potential MPG ride. newer electronically controlled vehicles dont take advantage of bolt on go fast goodies like the old days. even with a supercharger you need to retune the ECU to make it run right.
  10. Apr 29, 2015 at 1:44 PM
    pudge151
    Sean
    Connecticut
  11. Apr 29, 2015 at 1:47 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    well hes only a 4cyl so even the deck plate is a waste of time.
  12. Apr 29, 2015 at 2:31 PM
    goldentaco03
    Liam
    NJ
    If I do CAI or deckplate it won't need to be retuned right? The ECU can correct enough for it.
  13. Apr 29, 2015 at 2:36 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    considering it does 1% difference if that, the ECU will be fine.
  14. Apr 29, 2015 at 2:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    Downshift one gear, press the right pedal a bit harder. Much cheaper and easier than anything else you are considering, assuming the vehicle is a decent state of tune.
  15. Apr 29, 2015 at 2:49 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    unless its an automatic, if so. not much help there. that 4 speed auto paired with the 4cyl is just not built for speed.
  16. Apr 29, 2015 at 3:49 PM
    goldentaco03
    Liam
    NJ
    Its a 5spd with a 4cyl... I have no idea when the last time it was tuned (just got it). It has ok acceleration and power I just want a bit more out of it, I always hear how CAI can add like 7HP and you can feel the difference going up hills. I just want to know your guys opinions.
  17. Apr 29, 2015 at 4:17 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    Should've bought a truck with a V8 if you wanted something with more power.
  18. Apr 29, 2015 at 5:07 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    OP, since its a new to you truck, I'd start with a basic tune up, see how it does, and go from there. :)
