Opinions on installing mesh gaurd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kgbrev, Jul 24, 2024.
  1. Jul 24, 2024 at 9:41 AM
    Kgbrev
    Kgbrev [OP] Well-Known Member
    2020trdoffroad
    Diamondback SD cover
    Does anyone have any knowledge on installing a mesh guard in front on a condenser? Like what kind of problems can occur, if any?
  2. Jul 24, 2024 at 3:08 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I assume this to keep bugs from getting in between the condenser fins?
    If so, a simple piece of household window screen mesh should work for that (my dad used to do that, I think he used eyelets and a combination of small bailing wire & wire ties to secure it).
    Shouldn't cause any issues except maybe in the very hottest climates (like what it's been in the Southwest here the last couple weeks). Place the screen ahead of the condenser an inch or two (don't put it right up against it), that will give the best air flow.
  3. Jul 24, 2024 at 3:28 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    In cold/frigid climates there might be a risk of ice accumulation on a fine mesh ... blocking air flow. In deepest winter some block much of the grille to prevent freezing the engine (look at semis and that cloth patch), but to collect ice and fully block would be bad.
    4x4junkie[QUOTED] likes this.
  4. Jul 24, 2024 at 3:33 PM
    4x4junkie
    So Calif. (SFV)
    Good point.
  5. Jul 24, 2024 at 3:36 PM
    Bishop84
    Bishop84 Well-Known Member
    I've yet to see an issue where I am and we see -45c to +45c
    That said the better the install the better the results. We are seeing lots of rock causing damage this summer, its not a bad idea.
  6. Jul 25, 2024 at 10:17 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
  7. Jul 26, 2024 at 12:52 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    This is what I did. Lowe’s has black gutter guard with a doubled up edge. I think I needed three.
    Remove grill. You can use cardboard to make a template or just cut as you fit. Used small drill bit to put holes around frame. Used small zip ties to hold it in place and used stainless lacing wire to finalize mounting.
    Can take some more pics if needed.
    joba27n likes this.
