Opinions on Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gumbeyyy, Mar 16, 2014.
  1. Mar 16, 2014 at 5:44 PM
    gumbeyyy
    gumbeyyy [OP] Well-Known Member
  2. Mar 16, 2014 at 10:02 PM
    gumbeyyy
    Anything.
  3. Mar 16, 2014 at 10:12 PM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If you plan on using 5100's up front, then you don't need that Amazon lift. Just get the 5100's and set them to the setting you want for lift. Then buy some 1"-1.5" blocks from toytec for the rear. You'll save yourself money and get a better quality setup.
  4. Mar 16, 2014 at 10:19 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Are you gonna adjust the bilsteins for some added lift, then add a spacer? I wouldn't recommend doing that. If you want to lift then use the 5100s for their adjustability. You have a choice of 0" lift (stock ride height), .85" lift, 1.75" lift, and 2.5" lift. You can Cain the lift by adjusting the C clip on the bilsteins to obtain your desired lift height. For the rear you can add a leaf, get a new set of leaf springs, or the cheapest way would be blocks.
  5. Mar 16, 2014 at 11:11 PM
    gumbeyyy
    I was planning to use the blocks and U Bolts for the rear only. I can't find a AAL Or 1" blocks on Amazon. I choose amazon because I have a few hundred dollars credit to use from them.
    Also when I do the 5100's at 1.75 will it level out without a 1' block? My leaf pack now has the 3+1 overload. I have been reading all in the forums but just want to make sure before I pull trigger
  6. Mar 17, 2014 at 3:26 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    If you have a 1 1/2 in rake not, 1.75 will put you slightly higher in the front. If it is 1.75, that will get you level. Do some measuring and see if you want to be set at .85 or 1.75. If you are looking at leveling only, I would level w/ the 5100s and not use blocks. There is a reason blocks and spacers are the cheapest way to lift your truck.
