Opinions on running 4X4H at 70-80mph?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GeauxTRD, Dec 6, 2018.
  1. Dec 6, 2018 at 7:55 AM
    GeauxTRD
    GeauxTRD [OP] New Member
    2018 Cement Tacoma 4X4 TRD Off-Road
    I have to drive a lot in the mountains on I-70 in Colorado in snowy/icy conditions. I usually run 4H if there is any snow on the road or if the roads are wet in sub freezing temps. They do a pretty good job maintaining the road conditions, so I can safely run 70-80mph at times on long straight aways. Will running those speeds in 4H cause any damage/problems to my taco? I’ve read a lot of people saying that you shouldn’t run faster than 50-60mph, but my Tacoma seems to run great at 70-80 in 4H. Thoughts?
    2018 TRD Off-Road 4X4
  2. Dec 6, 2018 at 7:57 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    You can't engage 4HI over 50 something mph per the manual, but I have driven all sorts of 4x4 vehicles in 4hi at freeway speeds.
    Your gas mileage will suffer, but I wouldn't worry about doing it.
  3. Dec 6, 2018 at 7:58 AM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    No problem at all running 4h at any speed. It was designed to go as fast as the truck will let it, just actuator max speed is 60
  4. Dec 6, 2018 at 7:58 AM
    doorsidedown
    doorsidedown Well-Known Member
    I don’t have any helpful info that actually answers your question, but I think if the roads are “safe” enough to run 70+ mph then you probably don’t need to be in 4x4.
    Just my .02
  5. Dec 6, 2018 at 7:59 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Isn't it foolish to travel that fast in conditions that would require 4wd?
    I'm speculating here, but the transfer case and front gear set may not be designed to handle load above 50mph. There's probably valid reasons Toyota advises against it, so I'd err on the side of caution.
  6. Dec 6, 2018 at 8:02 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I do it all the time here in Michigan. Can have dry roads for 2 miles then the highway is snow covered. In those situations I just leave it in 4 high.
    I do slow down on the snowy sections, and I hope you do too.
  7. Dec 6, 2018 at 8:03 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Snow/ice + 70-80 mph = brilliant
  8. Dec 6, 2018 at 8:04 AM
    GeauxTRD
    It’s a very windy interstate in the mountains and 4WD is required on the sharp turns in these conditions. But On the straight aways you can safely cruise at 70-80 as long as it’s not a blizzard and visibility is good.
    DavesTaco68 likes this.
  9. Dec 6, 2018 at 8:06 AM
    GeauxTRD
    Yes, the roads are very similar here. Can be dry for a while, then you are in conditions where you definitely want 4WD.
  10. Dec 6, 2018 at 8:09 AM
    koditten
    Kirk
    Central Michigan
    Actually, your MPG won't suffer at all.
    Cruising in 4hi at 60 MPH or lessless be much more efficient than 80+ in 2 hi.
  11. Dec 6, 2018 at 8:10 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    I never drive 80, but 60-70 at times while slowing down for extra snowy sections or to pass slow traffic. Won’t hurt the 4wd at all.
    DavesTaco68 and GeauxTRD[OP] like this.
  12. Dec 6, 2018 at 8:12 AM
    Prjct_Vodo
    Prjct_Vodo Well-Known Member
    Ali
    Michigan
    2019 Voodoo Blue Tacoma TRD Pro
    There's a great YouTube video from Engineering Explained that goes over the concept of part-time 4wd and how to properly use it ... Long story short I'd definitely slow down and not exceed the speed Toyota says (which I think is 50mph) during the turns and windy roads
  13. Dec 6, 2018 at 8:16 AM
    jsi
    jsi Well-Known Member
    native earthling
    Maybe 3rd gens are different than my truck, but I only have part time 4wd. I try to avoid running in 4wd if the roads aren't a little bit slippery. If the roads are slippery enough for me to need 4wd then 70+ mph = being in the ditch or worse.
  14. Dec 6, 2018 at 8:18 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    It's ok if you have 4wd :luvya:
    arnette64 likes this.
  15. Dec 6, 2018 at 8:27 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Based on some of the logic in this thread, I wouldnt be able to drive a subraru on the interstate.
    There are no issues with running 4wd at any speed and contrary to popular belief Toyota does not put a max speed on 4wd, simply the maximum recommended speed for SHIFTING into 4wd.
    loastad, Loqu!to, shakerhood and 9 others like this.
  16. Dec 6, 2018 at 8:31 AM
    Prjct_Vodo
    Ali
    Michigan
    Subarus are asymmetrical 4wd which is pretty much full time unless you have an STI trim to adjust those settings .. my understanding is he's asking about how he would use the part-time 4wd system which is geared a little differendif and can only "properly" or "shouldn't exceed" a certain speed limit.
    synaps3 and sailtowery like this.
  17. Dec 6, 2018 at 8:32 AM
    RoninWanderer
    RoninWanderer Well-Known Member
    Austin
    2010 Toyota Tacoma TRD
    Snugtop, more to come!
    Subarus are All-Wheel Drive and are a completely different system than our Part-Time 4WD vehicles. They don't have a transfer case to start and have an open middle diff usually.
    LocoLocal, synaps3 and MoneyMan55 like this.
  18. Dec 6, 2018 at 8:32 AM
    RoninWanderer
    Austin
    beat me to it!
  19. Dec 6, 2018 at 8:34 AM
    dung
    dung Well-Known Member
    2018 TRD OFFOAD
    Subaru has an AWD system that is meant for continuous use and won't bind in turns. The Tacoma is not the same.
  20. Dec 6, 2018 at 8:34 AM
    JoeCOVA
    Joe
    Colorado Springs
    We know what the difference mechanically, the point is you can drive whatever speed you want regardless. Part-time vs full-time is completely irrelevant in this discussion.
    False
    We arent talking about turning...we are talking about speed
