Opinions on Top Plate Spacer or leveling kit
Discussion in 'Suspension' started by nammer, Jul 22, 2012.
  1. Jul 22, 2012 at 11:03 PM
    nammer
    nammer [OP] Well-Known Member
    Nam
    Bradenton, Florida
    2006 DCSB
    Relentless Aluminum Front Bumper Maxtrac Spindle Lift and 3'' Spacer Allpro Standard leaf and 2'' block
    ok, so I'm super cheap, so I wanted a lift at lowest cost, basically takes out those $1K suspension lifts or billies 5100, and I already have a skyjacker 2'' leveling kit
    http://www.topguncustomz.com/p-4482-2-05-09-toyota-tacoma-skyjacker-4x4-leveling-lift-kit-.aspx
    question 1: is that the same as a top plate spacer?
    question 2: on ebay these leveling kits look the same as coil spacers? how do i tell the difference, if they are different?
    I read from chris4x4 that top plate spacers can cause premature wear to ball joints, and how bad would it be to use this, or a 3'' spacer?
    I wanted to get a lift as cheap as possible, so I was thinking about 3'' spacer in front, and 1.5'' add a leaf in rear, should I just stick to this leveling kit, to save my suspension?
    also they have 2'' leveling kits on ebay for like $50 shipped, how different is this skyjacker one?
    thanks in advance, sorry so many newb q's
  2. Jul 23, 2012 at 5:31 AM
    oaker
    oaker Active Member
    '11 Tacoma DCSB TRD
    I just installed a 2" top plate spacer on my DC, it gave me the perfect amount of lift for a level truck, i went round and round on what to do but ended up going with the spacer because i dont go offroadin with my truck (if you do id go with the billies) i was able to get a little more lift than with a set of billies because they would have only given me 1.75" (2.5"would be too high) and the top plate spacer doesnt preload the springs, it actually rides better than before. spacers get a bad wrap on this site which i can understand if its an in coil spacer, but the top plate ones are a good option for some, however i wouldnt go over 2.5", then you may run the risk of some premature wear.
  3. Jul 23, 2012 at 5:45 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater,FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x9 Fuel Krank wheels, 35x12.50 Cooper Discoverer STT, Borla cat back exhaust, map & dome l.e.d's, TRD badge on grill, Redline tuning hood struts, Maxtrac spindles, Bilstein 5100's front set at 1.75 & ext.rear, All Pro expedition leaf springs & 1.5" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer both sides, TRD skid plate sprayed with bedliner, Cali Raised ditch lights & brackets, N-Fab steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I was looking at those lifts on eBay too.
    Spacer in front for 3" & a 2" block or aal in the rear for $125 shipped.
  4. Jul 23, 2012 at 9:40 AM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    i think i'm most likely going to go with that option, i just started getting some ideas on how i should maximize the install, because another member was going to help me install some used trd billies and i already have the leveling kit, so i figured why not just go 3 inches while we're doing it, and i don't offroad either, but good call on the excess wear, and this way, i don't have to touch the back
    yea that was the route i was gonna take, i just can't figure out why it's soo much cheaper
  5. Jul 23, 2012 at 9:47 AM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    07 TRD Off-Road SR5 BSP
    mall crawler
    Do NOT get a spacer lift of any kind. What youve read about them messing up the rest of your suspension is true. you can go to DSM and get billies (front and rear) for $300. Probably a bit more than you wanted to pay but its better to do it right than have issues down the road.
  6. Jul 23, 2012 at 10:06 AM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    yea man, i know you're right, but it's that upfront cost that deterring me, i appreciate the advice though
  7. Jul 23, 2012 at 10:32 AM
    oaker
    oaker Active Member
    '11 Tacoma DCSB TRD
    top spacer or billies, the change in the angle is still the same.....as long as you dont exceed 2.5" itll be ok.
  8. Jul 23, 2012 at 10:37 AM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
    after wildcattaco's advice, i was kinda thinking bout just getting the fronts, thanks for ur input as well :thumbsup:
    i just went outside to look at it, i was thinking the same thing, so i think u just sold me on just using the leveling kit i already have
  9. Jul 23, 2012 at 10:46 AM
    oaker
    oaker Active Member
    '11 Tacoma DCSB TRD
  10. Jul 23, 2012 at 11:24 AM
    nammer
    Nam
    Bradenton, Florida
    2006 DCSB
  11. Jul 28, 2012 at 1:12 PM
    Taco89
    Taco89 Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    x2
