Opinions on warn winch. What to buy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Festus, Sep 26, 2015.
  1. Sep 26, 2015 at 9:58 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    Have a 05 dcsb, putting an arb bumper on and want to get a winch in there at the same time. What warn winch do you recommend
  2. Sep 27, 2015 at 1:01 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I had a HS9500 on my last Tacoma and an XD9000 on the current one. No complaints with either winch. The '95 had an ARB as does the current '05.
    Be sure to check your measurements to make sure whatever you choose will fit; you'll need a non "i" series too- the "i" is for integrated solenoid control module which won't fit in the ARB.
    Festus[OP] likes this.
  3. Sep 27, 2015 at 8:51 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Be sure to get at least an 8000lb minimum rating.
  4. Sep 27, 2015 at 9:35 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Get a 10k winch.
    I've had good luck with my Warn VR10S
  5. Sep 27, 2015 at 12:27 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    I'm leaning towards the 9.5xps. Overkill?
    Edit: just realize it's 1800 bucks... Change of plans. Lol
  6. Sep 27, 2015 at 12:31 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    Xd9000 is prolly gonna do it. How's the water seal worked out for yall? Any issues?
  7. Sep 27, 2015 at 1:09 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Are you dead set on steel cable? Stuff can add quite a bit of weight to your front end over synthetic.
  8. Sep 27, 2015 at 3:31 PM
    cmartinez95
    cmartinez95 Well-Known Member
    Houston
    2014 TSS DCab 4x4
    2.0 SAWS, 2.0 Icon Rear Shocks, 1.5" Icon AAL, USOFFROAD Winch Mount, Warn M8000S, HID Retrofit Headlights, Custom made sliders, Fab Fours rear bumper, LED Fogs, Heated Mirrors, Auto Dimming rear view with temp and compass, BAMF antenna mounts, LED Interior lighting and Undercover SE Tonnea.
    I'll second the 8000lb minimum and will cast a vote for a M8000s (yes, that's that I am running in mine). :)
  9. Sep 27, 2015 at 3:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That is what I ran on my TJ with 33s. It pulled me through 75ft of 3' alpine snow when locked front and rear deflated MTs couldn't get me through. Good bang for the buck winch.
    cmartinez95[QUOTED] likes this.
  10. Sep 27, 2015 at 6:40 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    Not stuck on steel cable at all. Would prefer synthetic of course.
    Also adding 886 coils this week. Truck is being built mindfully
  11. Sep 27, 2015 at 6:42 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    8000 is the minimum that warn offers so...yes 8000 minimum. I'm looking at the 9000, has anyone used this winch? And how does it hold up?
  12. Sep 27, 2015 at 6:48 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    It's an excellent winch but yes expensive.
  13. Sep 27, 2015 at 6:50 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Warn offers a full line, including the M6000, so 8000 is not the minimum. That said Warn is the only way to go and keep it 8000+.
  14. Sep 27, 2015 at 7:08 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I suggest the VR10S if your on a budget
  15. Sep 27, 2015 at 9:59 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    Not a bad suggestion. No problems w the seals? Mine will get put in water from time to time
  16. Sep 27, 2015 at 10:07 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    My Jeep buddy has a VR8000.... and it regretfully has pulled me out more than it has pulled him out. My truck has ARB front, 4X innov. rear bumper, 33's, canopy and tools. He drags me up things no problem.
    Although I would prefer a 9000 lb, if you can only afford an 8000 it'll do the trick, speaking from experience.
  17. Sep 27, 2015 at 10:11 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    Afford is not the problem. I'd like to buy it once and be stoaked. I'm looking for suggestions and experience w certain winches
  18. Sep 27, 2015 at 10:12 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    Then a VR9000 would be the winch you need.
  19. Sep 28, 2015 at 4:23 AM
    Bajatacoma
    SC
    You'll definitely need to upgrade the suspension with the ARB and a winch. Synthetic line is safer and saves a good bit of weight. Also budget for winch accessories such as a tree saver strap, leather gloves, snatch block, etc. If you don't know how to properly use a winch find someone to instruct you; they are great tools but can easily injure or kill if things go wrong.
  20. Sep 28, 2015 at 1:48 PM
    Festus
    Festus [OP] a guy
    Festus
    Jefferson
    05 TRD DCSB
    Picked up a xd9000 today and a synthetic cable. Stoaked. Thanks for the input fellas.
    Foihdzas and Wile like this.
