Opinions on wheel spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white2red, Mar 31, 2024.
  1. Mar 31, 2024 at 12:24 PM
    white2red
    white2red [OP] Active Member
    OK
    2008 White TRD Sport DCSB, 2012 Red SR5 4x4 DCLB
    Everything but the engine
    I see varying opinions all over the site about wheel spacers, which has made me uneasy about buying some. For context, I have a second Tacoma on black wheels with no offset, and I want them to have a similar look to my XD monster wheels I run on my 4x4 taco. I have looked into Mammoth 2in wheel spacers that are around $80, but then I have seen some called “hub centric” that are around $300. Again I have heard so many varying opinions without really knowing about spacers, or what the difference is between the two I listed. Could someone dumb it down for me? Thanks!
  2. Mar 31, 2024 at 12:35 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I ran a 1" spacer for yrs without issues.
    Our trucks are hub centric meaning they are centered around the hub tightly, 106mm hub if I'm not mistaken. The ID (inside diameter) of the spacer will fit tightly around the OD (outside diameter) of the hub.
    The other option is lug centric meaning the lugs ensure things are centered.
    Lug centric is popular because it allows the spacer to fit on more vehicles since the over size the center bore. Hub centric will only fit that hub bore meaning less options.
    https://www.discounttire.com/learn/hub-centric-vs-lug-centric
    GearHead899 and Clearwater Bill like this.
  3. Mar 31, 2024 at 12:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    I admit, in the past I ran a small one on my S10 so I could use some early Z28 wheels and clear calipers.
    When I refreshed the S10 and went to aftermarket wheels, I just bought ones that fit properly.
    Spacers can work fine. I just prefer to avoid them. One less thing to futz with.
  4. Mar 31, 2024 at 12:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I have a habit of buying used stock wheels then getting over sized tires.
    Just last week I switched from TRD OR rims w\1" spacer to FJ wheels and no spacer with 34's. I'm currently rubbing my frame and uca so I'll need smaller spacers.
    I see people often recommend 0 offset. Personally I haven't purchased a new rim in yrs.
  5. Mar 31, 2024 at 2:27 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Run high quality hub centric bolt on spacer only. Bora or Spidertrax are both very good brands.
  6. Mar 31, 2024 at 2:36 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    I ran spidertrax for a long time on my 4runner, never had an issue. I don't really like wheel spacers but it seems like if you get a good brand that are made for your specific application and properly install them they should be fine.
  7. Mar 31, 2024 at 2:42 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    This, and install per manufacturer instructions. Every tire rotation, you need to check spacer torque. And also, no impact wrench on your wheels, which means you are probably doing your own rotations and brake work.
    But if you do all of that, you will be absolutely fine.
    gotoman1969[QUOTED] likes this.
  8. Mar 31, 2024 at 3:05 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    ^^^ This and don't get to truly stupid with spacer thickness. (2" is pushing it.) I currently run 1.25" Spidertrax spacers on my 4Runner and they've been on there since new. I re-torque them with every tire rotation and have had zero issues. That said, if I had my druthers, I'd always recommend wheels with the proper offset built in, but if that's not possible, get a good set of hub centric spacers.
  9. Apr 1, 2024 at 6:10 PM
    illjimae
    illjimae Well-Known Member
    1.25" spidtertrax with stock oem rims so I can get better clearance with bigger tires. It's honestly no different than getting an offset, the wheel hub will not see any difference between either solutions if increased load is the issue. Just torque and apply red loctite and read the manual. Been running about 25,000 miles. I stopped checking because after the 3rd tire rotation, they were still torque spec'd.
