Opinions please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Mar 16, 2015.
  1. Mar 16, 2015 at 2:27 PM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    After having an oil change done on the weekend I noticed that my driver's side CV boot that covers the bearing is loose and so the bearing is exposed. I had both sides changed and all the boots for the first time in october with 176000km on my taco. I have around 191000km now. It probably came loose more recently driving through deep snow but shouldn't be. I'm worried i'll need a new bearing. I'm hoping just a new boot and clean / regrease the old one.
    Opinions Please Thanks
  2. Mar 16, 2015 at 10:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If the bearing was exposed ( boot loose ) you have probably slung most of the grease out of the bearing. How long it has been exposed to the elements is the unknown factor along with how much dirt and grit has gotten into the joint.
    Reduced grease along with dirt and grit will greatly reduce the life of the CV Joint. I think at a minimum the axle should be pulled and the CV Joint cleaned and inspected repacked and sealed with a new boot, Properly Clamped onto the axle.
