Opinions Wanted: Going Full Retard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowmanwithahat, Mar 29, 2016.
  1. Mar 29, 2016 at 9:10 AM
    snowmanwithahat
    snowmanwithahat [OP] Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    So... I'm at a bit of a crossroads. My truck is no longer my daily driver and I've been kicking around the idea of buying a Jeep JKU and going the route of building one of those into an overland vehicle. I have had a couple of TJs, a stretched XJ and am fairly familiar with the benefits of a solid front axle and a built Jeep. What I haven't done, is wheel with an IFS rig much and I'm wondering if the truck will cut it and be a better rig overall compared to a JKU.
    So the options I'm trying to weigh are... 2-4" lift on a JKU w/ 37s, Dana 44s and lockers or... My 2013 DCSB w/ a build really similar to @DefconBrix @ckeene or @loco 's old truck... Some sort of LT w/ 35s and expedition style leafs in the rear, high clearance rear bumper, etc... It comes down to going full retard with the taco, or leaving it as a beautiful (but stock) truck and thrashing on something else.
    Anyway, opinions are welcome.
  2. Mar 29, 2016 at 9:27 AM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    For the amount of money you'll throw into the Taco to fix it up with LT, lockers and everything else you'll put on it, probably $15-20,000 you can sell the Taco and buy a older truck and make it a dedicated wheeler and still have $$$ left over.
  3. Mar 29, 2016 at 9:27 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Go full retard.
    Howen, Hartford and snowtank like this.
  4. Mar 29, 2016 at 9:59 AM
    snowmanwithahat
    My only real dilemma is that I still want something capable of towing, so I either need to keep the Taco and it will remain a very long term investment as a street / mild utility truck or the next vehicle needs to be halfway capable of towing... I think a JKU is only rated around 3,500. I'm practically looking at keeping the Taco no matter what.
    lemons[QUOTED] likes this.
  5. Mar 29, 2016 at 10:38 AM
    lemons
    lemons LOCO 4X4
    Virginia
    Land cruiser FJZ 80!!!!
  6. Mar 29, 2016 at 12:02 PM
    Tacorazy
    Tacorazy Well-Known Member
    Utah
    2014 Barcelona DCLB Sport
    Keep the taco and use it to tow an Arctic Cat Wildcat or a Polaris RZR. You'll go anywhere the Jeep or the Tacoma will go in half the time and twice the comfort (unless it is cold, lol).
  7. Mar 29, 2016 at 12:07 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    once you go LT theres no turning back, be prepared for more expensive prep work, repairs and upgrades but if you use you truck to what its capable of its well worth the enjoyment.
    75E718C7-ECCB-4892-A139-12B3AEC9471D_zps_4dcdda160d749d3186b2f18a815002c7fea581ff.jpg
    nosfanatic2006 likes this.
  8. Mar 29, 2016 at 12:22 PM
    nosfanatic2006
    nosfanatic2006 Well-Known Member
    Jeff
    2004 Xtracab 3.4 5speed
    This is tacomaworld, build the Taco
    kgarrett11 and Howen like this.
  9. Mar 29, 2016 at 12:54 PM
    Pigpen
    Dan
    Northwest Montana
    Enjoy your Tacoma for what it is. Build a Jeep - or better yet, build an old solid axle Toyota pickup.
  10. Mar 29, 2016 at 7:45 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    If you want to run fast in the desert stick with the IFS Taco. If you want to wheel hard in the rocks articulation is the key so go with a solid axle Jeep. Plus, having a wheelbase shorter than the DCSB is better on tight trails. Or actually go big and do an solid axle swap to the Taco.
  11. Mar 29, 2016 at 8:06 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Doesn't matter what you do to that truck, a Jeep with comparable upgrades will always be a better off road vehicle thanks to the wheelbase, approach and departure angles. If you really need that towing capacity, just upgrade your Taco, chances are you can still do anything you would have off road with it anyway and you keep your larger towing capability.
  12. Apr 5, 2016 at 2:25 PM
    DefconBrix
    DefconBrix instagram @defconbrix
    Sean
    Phoenix, AZ
    '13 Overland Taco
    Check the build thread.
    I may have gone full retard lol
    Very capable and still a very comfortable daily when I'm not riding the Harley.
    Worth it!
    truchador likes this.
  13. Apr 5, 2016 at 2:31 PM
    austin21
    austin21 Well-Known Member
    Austin
    Bend, Oregon
    2014 Super White Tacoma SR
    Cut springs
    Go full retard. Taco is life.
