Opinions
Discussion in '1st Gen. Tacomas (1995-2004)' started by PkTaco, Sep 12, 2010.
  1. Sep 12, 2010 at 7:14 PM
    PkTaco
    PkTaco [OP] Well-Known Member
    David
    Zanesville Ohio
    I have a 2003 Toyota Tacoma for sale. Ext. cab, 4x4, 5 spd. manual transmission. 3.4L v-6, 74k with auto windows, mirrors, and locks. 33" BFG tires with 75% tread on 3, one is brand new. Towing package.
    11,500
    Sorry no pictures.
    Went and drove the above described truck, a while ago and the onwer re-listed it about a month later.
    Body is in decent condition some dents and long scratches, it is a truck that was used for some kind of work.
    Motor and transmission drove like they should.
    Since the truck had bigger tires it kinda skipped around the road didn't know if that was normal or not.
    Bed was ok it had rhino lining but it looked like someone had shoved a mower in it and pulled up some of the lining on the wheel wells and had some dents in it.
    4 wheel drive worked fine, binded up like it should have.
    Frame was rusty... did not know if this was normal and if these trucks where part of the recall from Toyota due to the frames.
    Interior was in good shape, the 4 wheel drive thing you pushed in stuck a little bit and constantly flashed that it was on on the dash? Again not sure if that's normal or not.
    It had a small hole in the exhaust that would need fixed.
    Thanks for your help guys and sorry if I posted this in the wrong place.
  2. Sep 12, 2010 at 7:17 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    need to get pics,or your gonna get flamed.
  3. Sep 12, 2010 at 7:18 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    The constant flashing of the 4x4 light was signaling that it wasn't engaged.
    He doesn't need pics here this isn't the buy/sell/trade section, its the 1st gen discussion section.
  4. Sep 12, 2010 at 7:26 PM
    PkTaco
    David
    Zanesville Ohio
    It was the emergency brake light that flashed when the little handle thing you push in to disengage the emergency brake was pushed in, I just don't know if I pushed the lever all the way in or if that was a problem. It wasn't the 4 wheel drive light.
