Opion On Frame Damage And Repairability
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nickvan23, Nov 12, 2021.
  1. Nov 12, 2021 at 9:33 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    whatstcp likes this.
  2. Nov 12, 2021 at 10:25 PM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    wait, don't people weld on sliders and do front body mount relocations? both which involve welding?
    whatstcp, Slashaar and 5nahalf like this.
  3. Nov 12, 2021 at 10:42 PM
    Slashaar
    Josh
    Kansas City, MO
    I welded shock towers on and did CMC. :anonymous::welder:
  4. Nov 12, 2021 at 10:57 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    They do, but it compromises the frame. It can affect how the frame reacts in a future accident. Front frame rail modifications can affect the timing of the air bags too. Even an aftermarket front bumper reinforcement can change the timing of the air bag deployment. Srs system and the frame were all designed around factory parts and parameters.
    In the eyes of Toyota, it would be a liability if they approved of shops heating up and welding on their frames. Especially in critical crumple zones like the front frame rails.
    Here is a video from Honda below on what can happen when not using original collision parts.
  5. Nov 12, 2021 at 11:33 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    Jeez It seems like people talk about these trucks like its a fighter jet that if it doesnt have the correct bolt installed it will drop out of the sky. Liability changes a lot, but man people been welding in floor panels and every other kind of patch on cars for 100 years. Is the frame made out of unobtanium or something?
    Thats an end piece of the frame that just holds some bumper pieces together, its not like he is shortening the frame or chopping the top.
    I think alot of the scare is promoted by people that have never held a torch or raw piece of metal in their lives. Live a little ;)
    DownbyLaw and hfjeff like this.
  6. Nov 13, 2021 at 12:29 AM
    nickvan23
    nickvan23 [OP] New Member
    nick
    2019 tacoma trd off road
    It is going to be an insurance claim and I am looking to go to the Toyota dealership on Monday I will let you all know the outcome thanks for the opinions !
    Superdave1.0 likes this.
  7. Nov 13, 2021 at 12:37 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    FALSE FALSE FALSE
    The HSS used in the frame and body is not heat treated at all. Stop spreading that lie. It's an alloy with high tensile strength that allows them to bend a frame and body panels out of thinner sheets of metal.
    Heat treated metal doesn't flex, it will shatter if bent. Who's going to build a truck frame like that? Let's use some common sense here.
    DownbyLaw, Slashaar and Superdave1.0 like this.
  8. Nov 13, 2021 at 1:41 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm not seeing where it says it can't be welded. I do see that it can't be heated to stress relieve for straightening.
    How are cold straightening pulling aids attached to a frame? Genuinely ignorant and curious...CRIB 136 implies they are welded on.
  9. Nov 13, 2021 at 3:33 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I know next to nothing about welding. How does toyota weld brackets and other parts when making the frame without compromising the steel? Are they heat treating it afterwards or using 'frkin lasers'?
  10. Nov 13, 2021 at 6:10 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    How's the shop going to fix it? Using a small torch, a bfh, a grinder, and a welder. If you are lucky, they will have a can of spray paint available too.
    Want to prevent heat transfer, use heat block putty inside and outside the section to draw out heat and keep it localized. Unless there is other severe damage, I don't see a frame replacement for a non-critical section.
  11. Nov 13, 2021 at 7:26 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Heat treated doesn't mean hardened. Don't confuse a term to manipulate the physical properties of steel in many ways with one kind of heat treatment that makes steel very hard.
    Jeff Lange likes this.
  12. Nov 13, 2021 at 9:06 AM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    Funny, a properly heat treated knife can be bent to 90 degrees and return to true (see American Society of Bladesmiths, Master Smith qualification). Heat treat can do a lot of different things to steel depending on alloy, temperatures (intentionally plural) used, dwell times, and cooling methods.
    So, give proof (i.e. statement from Toyota) that it is a lie.
    Slashaar likes this.
  13. Nov 13, 2021 at 9:12 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    If @whatstcp says ur good then ur good lmao
    Doesnt look to bad to me, also remove the rust and cosmoline it
    airmax233 and whatstcp[QUOTED] like this.
  14. Nov 13, 2021 at 9:17 AM
    Rx7turbo2
    Rx7turbo2 Well-Known Member
    Canada
    2020 TRD OR DCSB (Current) 2005 TRD OR DCSB (Sold)
    I think it’s worth clarifying my take.
    If this is my own truck? I don’t bother with an insurance claim. I’ll handle the repairs myself , I’m more than capable, I’d bash that piece of the frame back, fire up my Miller and not give it a second thought.
    However if OP is doing an insurance claim it’s much different and should be treated differently.
  15. Nov 13, 2021 at 6:25 PM
    #35
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Hoping OP bashes it :D
  16. Nov 13, 2021 at 7:55 PM
    #36
    Rx7turbo2
    Canada
    Great post!
  17. Jan 19, 2023 at 6:55 PM
    #37
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    This is an old thread, which I don't usually like to revive without good reason, but I will say that Toyota does in fact sell parts of the frame separately for repair, just because there is damage doesn't mean the entire frame is replaced. The part in the original post that was damaged is sold separately, part number 51021-04022.
    Welding this portion of the frame is an approved procedure, and Toyota provides the instructions on how to do so in their collision repair manual.
    Jeff
  18. Jan 30, 2023 at 10:40 AM
    #38
    Slashaar
    Josh
    Kansas City, MO
    Mic drop. End of thread.
    Jeff Lange[QUOTED] likes this.
