opt 7 switch to oem fog light switch , harness wires differant colors ?
Discussion in 'Cali Raised LED' started by marlinmonty, Feb 28, 2017.
  1. Feb 28, 2017 at 12:02 PM
    marlinmonty
    marlinmonty [OP] Well-Known Member
    S.E. Oklahoma
    Ok after looking at several write-ups here , my harness from caliraised is red , white , black . So , I want to wire in the new oem fog light switch I got from them also . I have NO directions as I got my caliraised fog pods second hand .
    My switch has black , red , red , green like others in the write-ups but my harness again is red, white , black . No blue wire .
    I got the fuse tap also , this would connect to the top red wire next to the black wire out of the switch ? I think I have seen both the reds used in some of the write-ups now .
    Hummm ?
    Could use a hand guys . Getting ahold of Caliraised on the phone aint happening ! Tried several times , ol Jake must be very busy .
    MM
  2. Feb 28, 2017 at 12:08 PM
    marlinmonty
    S.E. Oklahoma
  3. Feb 28, 2017 at 12:15 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
  4. Feb 28, 2017 at 12:20 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    moved to the caliraised subforum so they can spot this and give you a hand
    moe2o4 likes this.
  5. Feb 28, 2017 at 12:34 PM
    marlinmonty
    S.E. Oklahoma
    Thank you sir . Sorry If I put this in the wrong spot .
    MM
    moe2o4 likes this.
  6. Feb 28, 2017 at 12:52 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    That would be Ma'am!
  7. Feb 28, 2017 at 7:38 PM
    marlinmonty
    S.E. Oklahoma
