Optima Battery ( D35 )
Discussion in '4 Cylinder' started by Maintenance Man, May 8, 2010.
  1. May 8, 2010 at 6:26 PM
    Maintenance Man
    Maintenance Man [OP] Well-Known Member
    Justin
    Atlanta, Ga
    05 Tacoma Pre-runner SR5 2.7L
    Leer camper shell; afe stage ll intake; 265's bridgestone dueler tires; rockford's power series 6.5's; tint on all windows; semi de-badged; weathertech digitial mats; grillcraft grill; blacked out headlights with eyelids; blacked out badges; and more to come.
    So, my battery was on its last leg today and I had to buy a new battery. I went ahead and bought a yellow top Optima Battery D35 for my 2.7L Pre-runner. I know this sounds crazy, but I actually believe my truck runs alot better! From a dead stop, with A/C on, starting out in first gear was pretty sluggish if I didnt give enough gas. Now, I can almost start out in first gear with hardly no gas at all.
    Anyway, just thought I let all yall know that my Taco runs better with an Optima Battery. Now I am not saying I wouldnt get the same results with a regular new battery, but I didnt buy one of those...
    Maintenance Man
  2. May 8, 2010 at 9:19 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Any fresh battery brand would have provided a better voltage for your ignition coil.
  3. May 9, 2010 at 6:00 AM
    Barnone
    Barnone Guest
    Only if your charging system was malfunctioning.
    I think it's like a lot of our mods resulting in the placebo effect.
  4. May 9, 2010 at 9:58 AM
    Maintenance Man
    Justin
    Atlanta, Ga
    I knew any battery would be better, but I do like the look of that yellow top in my engine compartment. Plus, I have a powerful DC\AC converter that im sure this will help out in.
  5. May 9, 2010 at 10:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. Only way the truck would seem to run better, was if too much load was put on the alt., trying to keep the battery charged.
  6. May 9, 2010 at 11:19 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I was looking to buy a Red top, Anyone know the difference between the Yellow and Red...thanks
  7. May 9, 2010 at 11:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yellow is a Deep cycle.
  8. May 9, 2010 at 11:26 AM
    MJonesTrumpet
    MJonesTrumpet Well-Known Member
    Michael
    Central PA
  9. May 9, 2010 at 11:54 AM
    numbah57
    kahai
    Maui, Hawaii
    Very good...thanks
  10. May 9, 2010 at 3:24 PM
    Maintenance Man
    Justin
    Atlanta, Ga
    Thats true, I also have been looking at an aftermarket alternator. My 05 Taco has 80k. I figured a new yellow top and a new alternator, I want be having any problems for awhile. I work out of my truck, I rigged up a air compressor in the back and also have a flux core wire fed lincoln welder back there. I havent used any of them with the new battery, but Im guessing they will work better too.
  11. May 9, 2010 at 3:28 PM
    MJonesTrumpet
    Michael
    Central PA
    they definately should. I want to get a new alternator...but dont want to spend like 300-400 bucks since mine still works just fine...only have 30k miles on it...
  12. May 9, 2010 at 4:13 PM
    Maintenance Man
    Justin
    Atlanta, Ga
    ya, I probably would wait before buying a new alternator too if I had your miles.
  13. May 9, 2010 at 4:30 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Yeah no point in wasting the money on something you won't need for a long time. Still using factory alternator & 146,000 miles on my 05.
