optima battery
Discussion in 'Technical Chat' started by w.trackler, Jan 12, 2009.
  1. Jan 12, 2009 at 9:50 PM
    w.trackler
    w.trackler [OP] Member
    grand junction, colorado
    08 tacoma
    hello. I have a 2008 tacoma with a 4 cyl. I caled the battery store to get a price on an optima battery....they informed me i would need a kit to install an optima battery in my truck. Is this right? Can anyone help?:(
  2. Jan 12, 2009 at 10:19 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Did you ask them what kind of kit this was? And no, it's not correct. But you may need a spacer to raise the batter higher up a bit so that your battery cables will reach the terminals.
  3. Jan 12, 2009 at 10:28 PM
    w.trackler
    08 tacoma
    thank's, no they did not. is this battery worth it or do you recomend something better ?
  4. Jan 12, 2009 at 10:33 PM
    w.trackler
    08 tacoma
    hello again, does anybody have a better batery i heard about a odyssey what do you think ? please help.
  5. Jan 12, 2009 at 10:45 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Both are pretty pricey, I wouldn't get them if you don't really need a battery such as these. If you have audio equipment and plan to use it with the engine off then get it. Get an Interstate battery or an Autzone one.
  6. Jan 12, 2009 at 10:49 PM
    TengoTaco
    TengoTaco Wish i was wheelin
    Tyler
    San Diego, CA
    2001 TRD stock
    None
    I have an optima battery. It works fine... A lot of money though... I had to extend the battery cable to make it connect.
    I have heard a lot of good things about Duralast. I will give them a chance next time i need a battery.
  7. Jan 12, 2009 at 10:53 PM
    EBruddah
    EBruddah Well-Known Member
    626 - SGV / RakiRaki, Fiji
    05 TRD Off Road 4X4 - OME Built to Wheel!
    2005 Tacoma V6 SR5 - 4WD AC TRD Off Road - 6 Speed M/T Full OME Lift w/886 Coils & Dakars,, Optima Yellow Top, Cobra NightWatch 29 WX NW ST - CB Peaked/Tuned + talkback/confirmation tone - PA Horn, Lil Will CB Antenna, Downey Off Road Extreme Duty CV Boots, 255/85/R16 BFG Mud-Terrain T/A KM, All-Pro Sliders, Drop in K&N FilterCharger, Flowmaster 40 Series, 62” Hi-Lift Extreme Mounted in Bed w/all Hi-Lift Accessories. Custom Skid Plate by Defined Engineering, 10 lb. PowerTank with HPX Regulator
    I'll take a pic of my lil ghetto hold down in a minute.... So far it's been bullet proof on the trial and you'll trip once I disclose what it took to craft it.
  8. Jan 13, 2009 at 2:42 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Duralast is a decent battery and have used them for years. I agree with Humanoid though.
  9. Jan 13, 2009 at 5:05 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    I like the die hard Platinum... is that good thou? I bet is expensive.
  10. Jan 13, 2009 at 5:08 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    The optima should be sold with a spacer (mine came with it at least) that the battery can rest on to raise it up. You'll need this as the battery is pretty short compared to stock and the hold down bracket won't be able to hold the battery down without it. (assuming the 4cyl has the same setup).
    Optima Yellow Top D35 in 06 Tacoma (4.0) & Billet Tray - no modification / extension of cables.
  11. Jan 13, 2009 at 5:45 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    how do u know odyssey battery comes off the same factory? :D
  12. Jan 13, 2009 at 6:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2 on the Odessey
  13. Jan 13, 2009 at 1:25 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    I have an Optima red top and haven't had any issues with it. I didn't use the spacwer with it and cut the battery holder extensions to fit it. If you don't want to go with a real expensive Optima, Odyssey, etc, I would get one from the dealer. There are a million things not to buy from a dealer, but the batteries last and have a decent warranty.
  14. Mar 9, 2009 at 5:38 PM
    Lake Murray Man
    Lake Murray Man Member
    Chapin, SC
    Long Bed 4X4
    K&N Hella Head Lights Pioneer Stero soon - Rear TSB
    Hey SilverBack ... does your second battery cause that nifty color change on your truck? I want one of those .......
  15. Mar 9, 2009 at 5:56 PM
    Phantom_X-SP
    Phantom_X-SP Rude Boy |><|
    High Point, NC
    08 DC Black Sand Pearl X-SP
  16. Mar 10, 2009 at 9:39 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    haha, i was wondering how he did that :D:confused::D
  17. Mar 10, 2009 at 9:46 AM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    The newer Toyota batteries are made by Johnson Industries. This is the same company that makes the Optima. Obviously it's not the same kind of battery as the Optima, but I would expect the quality to be very good. Anybody know what Toyota charges for their batteries?
  18. Mar 11, 2009 at 9:03 PM
    Bambigular
    Bambigular Well-Known Member
    Corona, Ca
    04 Double Cab SR5
    Unless you have a hooked up system, go with something from auto zone, they come with a decent warranty and a lot more inexpensive than Odyssey or Optima.
  19. Mar 13, 2009 at 9:01 AM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    I read an article about a year back from consumer reports, and they were advocating Wal-Mart batteries...
