Optima D34/78 Red Top (install w/pic)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovetacos, Feb 28, 2010.
  1. Feb 28, 2010 at 10:57 PM
    ilovetacos
    ilovetacos [OP] Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I just installed an Optima D34/78 Red Top battery. Got the "hook up" from a friend that works at a battery store for only $80.00 :eek:
    I need to clean a few things up but the install went very smoothly. I had to get a longer ground wire but I knew this going into it. The battery is a little short so I used the tray that came with the battery and I also reused the factory tie down (sprayed it with Duplicolor Bed Liner Paint). I am going to get a billet tray in a couple months and also install my Blue Sea's Fuse Block to clean up the wires.
    Let me know if you have any questions...
    Will get some more detailed pics up later.
  2. Mar 3, 2010 at 10:22 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I guess I'll make this my update thread as I plan on installing my Blue Sea Fuse Block this weekend.
    I also just ordered this Battery Box from Ruff Stuff Specialties. I was going to order the Billet tray from Ebay but it was a little too "pretty" for me.
    I plan on having it line'xd or powder coated black.
  3. Mar 3, 2010 at 10:24 PM
    Kenny650
    Kenny650 Well-Known Member
    WTF $80!? Autozone sells them for like $180ish
  4. Mar 4, 2010 at 6:55 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    That's a crazy deal. My Odyssey was nearly $200.
  5. Mar 4, 2010 at 7:17 AM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I know! I couldn't pass it up!
    I originally wanted an Odyssey but he couldn't give me deal on it. Then I wanted a yellow top and again he couldn't give me a deal so I had to go with the red top which should be fine for my set-up. I can always upgrade to the yellow top thru him for only $30 more.
  6. Mar 4, 2010 at 2:43 PM
    Kenny650
    ^ Still an amazing price for a yellow top. I sell them for like 209.99 each.
  7. Mar 4, 2010 at 3:07 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    This is my install, using a billet mount.
  8. Mar 4, 2010 at 3:12 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    whats so special about these batteries?
  9. Mar 4, 2010 at 11:09 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    ^^^^^ Nice Coupe!!!!
    Taken from their website....
    Red Top:
    The OPTIMA® RedTop® high-performance AGM battery is the ultimate high-CCA starting battery designed to deliver the strongest 5-second ignition power for a reliable start-up every time. The RedTop will outperform and outlast traditional batteries in demanding cranking/starting applications. With unparalleled high power delivery and extreme resistance to the most common causes of battery failure, the RedTop is idea for trucks, SUV's, luxury cars, hot rods, off-road vehicles and other applications that require a leak-proof starting-only battery.
    -Strongest 5 second starting burst
    -Up to 2x longer life
    -More than 15x the vibration resistance
    -Completely spill-proof, mountable in many positions
    -Maintenance free
    -Faster recharging capabilities
    -Optimal starting power, regardless of temperature
    Yellow Top:
    The YellowTop® high-performance AGM battery is one of the only true dual-purpose automotive batteries available. With premium cranking power and unparalleled cycling capability (rechargeability), it is perfect for modern accessory-loaded vehicles. The YellowTop can repeatedly bounce back from deep power drains to full energy capacity, so it can power plenty of electronics and still start you up time after time. Lower internal resistance also provides more consistent power output and faster recharges.
    Trucks with winches, vehicles with multiple electronics, cars with high-demand audio systems, commercial vehicles and heavy equipment all rely on this battery to provide ultimate starting and deep cycle power.
    -Deep cycling and cranking power
    -Maintenance free
    ...and they're pretty too :D
  10. Mar 5, 2010 at 2:55 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Yeah!
    What he said^^^^^
  11. Mar 5, 2010 at 3:11 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Yea those are sweet batteries. My brother has one in his truck that is almost 10 years old and still works perfectly.
