Optimal Alignment after 1.75 Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by '14RC, Nov 30, 2016.
  1. Nov 30, 2016 at 2:48 PM
    '14RC
    '14RC [OP] WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Hey TW members,
    I've been reading a lot of posts about optimum alignment specs for lifts 3" and above but there's very little on what the specs should be for a small leveling kit.
    With Bilsteins @ 1.75" up front and 1.5" AAL in rear, should I shoot for exactly 0 toe and camber like suggested for larger lifts, and just hope for good caster at the end of the day ( stock UCAs)?
    Thanks a lot!
  2. Nov 30, 2016 at 2:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    your gonna get around 1.5* of caster with that setup if that.
    I have 1.75 5100's up front and a 2in AAL in the rear of my DCSB. i was able to get 1.5* of caster with 0 camber... but hated the way it drove, also the fact that the UCA would hit coil at droop.
    Installed SPC arms and got 3.4* of caster on each side -0.4* of camber for even tire wear and .1* of toe in per side. Drives like a damn champ now.
  3. Nov 30, 2016 at 3:01 PM
    '14RC
    '14RC [OP] WA State
    Seattle
    Thanks for the input nd4spdbh! Camber and Toe settings confuse me a bit.. I think even 0 camber and 0 toe is out of factory spec on my RC. Is the general idea to minimize camber and toe as much as possible after a lift? I hear you on the caster.. I think as it is now one side is 1.7* and the other is 2*
  4. Nov 30, 2016 at 3:05 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    From what I can remember, I was able to get 1.9 and 2.1 of caster on 1.75" setting on 5100's with zero camber/toe. Drove fine. Each truck is different. You might just get away without getting UCA's. On my current truck, Eibach coils (1.6") and was barely able to get 2.0 caster on one side.
  5. Nov 30, 2016 at 7:20 PM
    GroupW
    GroupW Well-Known Member
    Mark
    Arizona
    Red TX
    3 inch lift with Toytec Boss and All Pro UCA's up front. AP expedition leafs with Bilstien 5100 shocks in the back. 255/85/16 Cooper S/T Max tires. All Pro skids, rear bumper and sliders, Hidden winch mount with XRC 8000 winch. Dual Optima batteries with IBS combiner/isolator and solar. CMC. Auto sliding rear window mod, hidden CB, CVJ axles and plenty of other little mods.
  6. Nov 30, 2016 at 7:46 PM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    I have 2.0*/2.2* caster on my truck after installing 1.6" Eibach coils. Very pleased with the ride. Full droop barely clears the coil but at least it clears. I didn't notice any change in steering feel or wandering, good or bad, from stock but I also drive slow most of the time. I may get new UCA's eventually but it's low on the list. New leaf springs are a much higher priority after I learned how much mine sagged in a year with the canopy on it.
