Optimal Alignment Specs 2.0" Lift w/ Stock UCA's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YotaDriver631, Sep 3, 2015.
  1. Sep 3, 2015 at 6:20 PM
    YotaDriver631
    YotaDriver631 [OP] Well-Known Member
    '18 Taco
    I have a Toytec BOSS adjustable lift set at 2.0" so the truck is level with the 1.5" rear AAL with no rake and want to get my truck aligned again but want to have some perfect specs to meet. I work at a BMW dealer and one of the techs will be doing it there again so he said to just give me exact specs and he will get it there or as close as possible. What are the Castor, Camber and Toe values that will extend tire life and make the truck turn well on the road? Thanks in advance! As of right now when I'm in 2WD and make a turn on pavement full-lock I do get some heavy binding but that could just be the sticky BFG KO'2s on the asphalt.
    P.S. Do not comment in the thread if you have anything to say about "YOU NEED TO GET AFTER MARKET UCA'S" orrrrrrr " JUST GO BY THE FACTORY SPECS" because I DO NOT need aftermarket UCA's and the factory specs have such a huge range its kinda ridiculous.
    Thanks guys!
  2. Sep 3, 2015 at 9:26 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Toe - just a smidge of toe in ( 1/16th - 1/8th of an inch less width at the front of the tires from centerline to centerline vs the rear)
    Camber - just a smidge of negative camber (top of the wheel in) .3-.5* (this allows the tires to wear evenly)
    Caster = AS MUCH AS YOU CAN GET with keeping a good camber number
  3. Sep 3, 2015 at 9:30 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    I was just reading up on this on my sons 1st gen. Found this. Screenshot_2015-09-03-21-26-33.jpg
  4. Sep 3, 2015 at 9:38 PM
    RudedogII
    RudedogII Well-Known Member
    So Cal
    Stock 2010 Double Cab 4x4
    None yet but in the works!
    Just go by the factory specs. A good mechanic will set to factory specs, test drive, and adjust if nessary.
  5. Sep 3, 2015 at 9:44 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    You can't get "optimal" alignment specs. The best you can get is "within spec".
    0 toe
    0 camber
    3* caster
    Would be my idea of "optimal", but you can't get that with stock control arms.
    Arailt and RudedogII like this.
  6. Sep 3, 2015 at 9:48 PM
    DukesTaco
    AZ
    Holly shit a good mechanic is like a unicorn. Spoken of but never seen.
    YotaDriver631[OP] likes this.
  7. Sep 4, 2015 at 4:38 AM
    YotaDriver631
    '18 Taco
    I liked your post and I work as a Service Adviser at a BMW dealer haha
