Optional Manual Trans out there?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Nov 15, 2011.
  1. Nov 15, 2011 at 1:28 AM
    x2468
    x2468 [OP] Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    I'm thinking that if the auto tran ever goes, knock on wood, i'll replace it with a manual. But im not a fan of a 5 speed tran that has a lower final drive gear than my 4-speed auto. I was reading toyota 4wd enthusiast and they had a build where the guy mounted a tranny from a different model after fashioning an adapter plate some some sort. Not sure if I read it right but either way... are there any other transmissions that might be compatible with the 5vz v-6? maybe one with different gear ratios, or more durability. maybe less weight so it has less of manual lean?
  2. Nov 15, 2011 at 8:42 AM
    haddix
    haddix Well-Known Member
    KY
    07 FJ Cruiser
    SAW coilovers, Dakar leafs, OME nitro barger sport, 255/85 KM2, Softopper, ARB,custom sliders, custom rear bumper, IFS skid
    X2. Your looking for something more durable? The 5 speed tranny in these trucks are pretty damn durable.
  3. Nov 15, 2011 at 9:16 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    What? I'm pretty sure the 5speed in these trucks are lighter than the auto...
  4. Nov 15, 2011 at 12:21 PM
    x2468
    Vermont
    From what I've read the 5th gear at 80mph on the manual is at 3k rpm. On my auto in 4th its at 2.5k. Seems a bit stupid if you think of it. Its almost like a close ratio tran. I'd rather have the 5th gear (or 6th) that holds a lower rpm at highway speed for better Mpg cruising.
  5. Nov 15, 2011 at 2:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Sure. if you have the money you can put and tranny in there ya want.
    And yes, autos get better hwy mileage, but we get better city usually.
    and its all just an opinion really. Do you like it to be easier to crawl up stuff? or down?
    also..why in the hell do you have to go 80mph anyways?? you'd get much better mileage at 70-73 with either tranny.
  6. Nov 15, 2011 at 10:52 PM
    x2468
    Vermont
    Because I want to....? Plus if the man. revs to 3k at 80 and the auto at 2.5k, it still stands to reason that the auto will rev lower at lower speeds as well. The difference just won't be as great.
    I guess its cuz I have to spend a lot of time in the highway. Its about 65 % of the driving I do.
  7. Nov 15, 2011 at 11:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well then keep the auto..
  8. Nov 17, 2011 at 12:06 AM
    x2468
    Vermont
    Yeah true. At least you'd be closer to the meat of the torque curve at 3k rpm for when you need to make it past that 18 wheeler asap. I'm guessing the top speed on the manual is lower than that of the auto? Not that it matters.
    I was just thinking, if there is another trany out there that could be fitted with relative ease it might be interesting.
  9. Nov 17, 2011 at 12:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I doubt it. Custom bell housing and driveshaft will be needed no matter what.
