Options for bringing wiring through firewall into cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by foothill96tacoma, Mar 18, 2025.
  1. Mar 18, 2025 at 6:40 PM
    foothill96tacoma
    foothill96tacoma [OP] Well-Known Member
    1996 3.4 V6 MT 4WD
    What options are there for routing wiring through the firewall? I believe I see a grommet beneath the brake master cylinder area, not especially accessible. I have set up some pretty amateurish wiring in the past on this truck and want to redo it correctly as I start a new electrical project :) Thanks!
  2. Mar 18, 2025 at 7:30 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yes the grommet below and inboard of the master cylinder is a good location, comes out above the gas pedal in the cab so you can run up into the dash or directly below the radio area. Just bundle all the wires you need (plus maybe an extra or two) in a loom and open the grommet to pass it through, then you can seal the grommet around the loom.
    The pass-through for the main engine wiring harness to the ECU on the passenger side is also a good location for wiring on that side of the engine bay if needed.
    None of them are particularly accessible, especially if you’re a large human. One of the downsides of a compact truck.
  3. Mar 18, 2025 at 8:15 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Yeah Agreed
    that grommet the best choice
    foothill96tacoma[OP] likes this.
  4. Mar 19, 2025 at 12:52 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Grommet near the brake/clutch is the best choice. Poke through with a coat hanger and pull your wires through. It's easier to get to then it seems.
