Options other than lift to fit bigger tire?
Discussion in 'Wheels & Tires' started by brp, Jun 14, 2012.
  1. Jun 14, 2012 at 3:19 PM
    brp
    brp [OP] Well-Known Member
    Yesterday I asked about adjustable lifts and got great responses, it looks like a dead-end for my needs.
    TC Bob's sticky lets me know that I can fit...
    For 2005+ Tacomas: 265/70/17 or 265/75/16, depending on what size wheels you have
    ...with stock suspension.
    My question is what is the limiting factor if I go with a bigger tire on stock suspension?
    If I get new UCAs or do some cutting, can I fit a bigger tire? What is the first thing that will rub? Can it be addressed short of a lift?
    Thanks
  2. Jun 14, 2012 at 3:23 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    cut your frame, remove your body panels, then make custom body parts out of paper mache.
  3. Jun 14, 2012 at 3:33 PM
    brp
    I am sure that all applies at some point. But can I get an extra inch of tire with something more minor.
  4. Jun 14, 2012 at 3:44 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    cab mount chop and trim the fenders. you need to do this even if you do get a lift, or else you wont be able to use any up-travel.
    Remember, a lift only lets you fit bigger tires at ride height. At some point in time, your suspension will travel and the wheel will be at stock ride height location, and it's gonna hurt.
  5. Jun 14, 2012 at 3:46 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    why do you want such big tires without any sort of lift?
    if it's for wheeling purposes, when you flex the big tires they will just tear up the fender, and you'll HATE it.
    if it's for looks.. big tires on a stock truck looks ugly IMO
    you will spend MUCH less money in the long run by getting a small lift, then tearing up body panels
  6. Jun 14, 2012 at 3:46 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Sell for bigger truck.
    Whats the point of bigger tires with no lift?
  7. Jun 14, 2012 at 4:00 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    the money you'd spend on aftermarket UCA's could cost just as much budget suspension lift where you get to keep your stock ones fyi.
  8. Jun 14, 2012 at 4:07 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    true, but i've seen a couple members with 100% stock suspension with 33s. They did extensive trimming, but it looked really good. One of them is long beach taco or LB taco or something.
  9. Jun 14, 2012 at 4:13 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You originally wrote:
    If you run bilstein 5100s at 1.75" in the front, an "add a leaf" in the back, and 265/75R16 tires with a more agressive all-terrain tread on your stock rims - pretty much only "expert" tacoma owners will even be able to notice your truck is "lifted."
    Everyone else will simply think it's got a look like it's been "hitting the weight room" but they won't be able to put their finger on why.
  10. Jun 14, 2012 at 4:15 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Ever consider 255/85/16's?
    I'm only rubbing a slight portion on my front towards the back of the wheel well and I got jack for lift. My caster is at 2.6* and that's obtainable for stock if memory serves me correctly.
    The rear stuffs up just fine and will never rub
    front (black crap is structural silicone that was holding my mud flaps on) I could use a little trimming, but nothing I'm worried about anytime soon. Next time I rotate Ill cut a little bit off.
    edit: And these rub LESS then the 265/70/17's I have sitting on my deck.
  11. Jun 14, 2012 at 4:21 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I could clear my 35s with stock suspension, but I cut 2" out of the sheet metal
    for 33s you can cut your body mount back, if you need to at all, and trim lots of plastic, it's doable! If you have to, throw a small spacer under your bump stop and push your caster forward as much as you can.
  12. Jun 14, 2012 at 4:27 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    I remember someone put 285's on a stock set up and either cut off or removed the fender liners and did lots of trimming. 265 will fit with little trim.
  13. Jun 14, 2012 at 4:42 PM
    XXXX
    sKiP
    05 Prius
    But did they wheel it? I know guys with 285's, 1" body lift, 3" suspension lift, extensive trimming, fire wall beating, and they still rub.
    Thats why I went with 255/85's. I get the clearance of a large tire without all the BS. To me 3% narrower tire then a 265/70 is worth is especially since I have never been stuck due to lack of floatation.
  14. Jun 14, 2012 at 4:50 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    ^^^^Ding ding. Winner^^^^_^`
  15. Jun 14, 2012 at 4:55 PM
    x2468
    Vermont
    You're running bone stock suspension?
  16. Jun 14, 2012 at 4:55 PM
    XXXX
    sKiP
    05 Prius
    No, but I'm also not "lifted"
    King 2.5 remote resi front shocks #25001-119
    King 700# front springs #e300-14-700
    Total Chaos UCA's #96504
    FK stainless steel uniballs #wssx16t (required in salt belt IMHO)
    TSB springs #48210-04570 & 48220-04210 (overload leaf removed)
    Wheelers 3 leaf progressive AAL #whe mp3
    Bilstein 5100 rear shocks #bil be5-c478-to (too short - need to upgrade)
    Wheelers front & rear superbumps (rears mounted to frame)
    AP U bolt flip kit
    AAL is flat and Kings have 4 threads showing. My truck rides just about stock height.
  17. Jun 14, 2012 at 4:59 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    How about 255/75/17. That's the size I think I am going with when I wear out my stockers. It seems like if 255/85/16 fits with minimal rubbing so 255/75/17 will fit with no issues. I think you could also go with Billies set at .85" or even 1.75" and know one will really know.
  18. Jun 14, 2012 at 5:03 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    how is that not lifted? if the 5100's are too short, then you are taller than most guys who run them with 1.5'' - 2'' just fine..
    and you have king front springs and remote resi front shocks, those are stock height? I'm confused..
    wait I didn't read the last line, I guess I get it.. but weird haha
  19. Jun 14, 2012 at 5:06 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    you can adjust coilovers to be stock ride height
  20. Jun 14, 2012 at 5:06 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    but why oh why would you! :p
