Options Poll: FLYZEYE Designs, LLC.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyzeye designs, Jan 6, 2013.
Do you want additional options for cases?
Poll closed Feb 5, 2013.
  1. Camouflage cases (various themes)
    19.4%
  2. Skulls / tribal prints
    5.6%
  3. Color-matched (to the vehicle)
    66.7%
  4. Different materials? (Such as a clear ploycarbonate case)
    16.7%
  5. Other ideas...
    8.3%
  1. Jan 6, 2013 at 10:15 PM
    flyzeye designs
    flyzeye designs [OP] Revised Company Logo
    Darren
    Mesa, AZ
    double-cab long-bed 4X4 debadged TRD Sport
    6 inch lift, tinted windows, custom tail lights, custom Red/White/Red-Black FLYZEYE Designs TCMA-0513 V2W interior light Custom Powder-Coated Devil Horns by Andres
    All, we have been getting various questions about optional finishes... Do you guys want more options such as those offered by hydro-graphing? Camouflage themes, skulls, simulated carbon fiber, different colors? Check out http://www.rlhydrographix.com for ideas. Give us your thoughts, please.
  2. Jan 7, 2013 at 1:00 AM
    flyzeye designs
    Darren
    Mesa, AZ
    Thank you for your interest and feedback. it is appreciated.
  3. Jan 7, 2013 at 3:18 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    I think your current product line is great. Matching the interior color makes sense for the majority of the buyers, and your product blends in perfectly.
  4. Jan 7, 2013 at 4:49 AM
    SteelRain
    SteelRain Veteran Redleg
    Curt
    San Tan Valley, Arizona
  5. Jan 7, 2013 at 4:56 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2021 4x4 TRD Sport DCLB
    Can you still get the A/C controls and radio out after you install this, it looks like it might stop you from getting the A/C controls out once you have taped it onto the bottom of the radio.
  6. Jan 7, 2013 at 5:55 AM
    pra4sno
    ^ You can easily peel it off. If you have any trouble, a hair dryer will loosen it up.
    The tape can be replaced very easily at any hardware or general store with the 3M double sided mounting tape/foam. Its $2.00 for a 1.5 meter roll.
  7. Jan 7, 2013 at 6:52 AM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Speaking of your product, I was considering buying one and was curious if you still have any black trim, in a wired version, with just white lights.
    On topic, I like the plain version but a lot of people are into carbon fiber and the like.
  8. Jan 7, 2013 at 9:26 AM
    flyzeye designs
    Darren
    Mesa, AZ
    Yes. You do NOT have to remove the mounting plate to gain access. That said, it does require extra effort to get the HVAC control panel out but, it can be done.
  9. Jan 7, 2013 at 9:30 AM
    flyzeye designs
    Darren
    Mesa, AZ
    True but, we do NOT recommend the user-level 3M double-sided mounting foam - it's simply way too thick. :rolleyes:
    It makes a HUGE difference in the fit quality. Our version measures something like 7 mils (not millimeters / 0.007"). Most readily available 3M foam tapes are running in the millimeter range. ;)
  10. Jan 7, 2013 at 9:31 AM
    flyzeye designs
    Darren
    Mesa, AZ
    The black cases are currently SOLD OUT but, replacement cases are expected in mid to late January.
    Thanks for the input.
  11. Jan 7, 2013 at 9:44 AM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Thank you. I will be waiting for an update in the lighting section, unless you wouldn't mind sending me a pm when available.
  12. Jan 7, 2013 at 9:53 AM
    flyzeye designs
    Darren
    Mesa, AZ
    I certainly don't mind sending PMs, I just fear my C.R.S. (Can't Remember Sh!t) will kick in and I'll miss you (and others). I will update a few posts regarding black cases as soon as I can confirm they've shipped. ;)
  13. Jan 7, 2013 at 10:15 AM
    trafficmaker
    trafficmaker Active Member
    The A/C controls can be removed with leaving the base plate on, I did it just to check that myself while installing. And in reality, the bottom of the head unit bracket is 'soft' enough that no trimming needs to be done to install wire. I did not cut/trim any plastic.
  14. Jan 7, 2013 at 10:29 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    I don't think there will be a huge following wanting custom cases. Maybe work with a hydrographic vendor off TW to offer it as a special order option.
  15. Jan 7, 2013 at 10:32 AM
    flyzeye designs
    Darren
    Mesa, AZ
    I don't expect a huge following either but, as a possible option, it might just make someone's day. :)
    We are always open to ideas and as you know, we like to work WITH our customers as well as for them. ;)
  16. Jan 7, 2013 at 10:38 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Sent you a PM
  17. Jan 7, 2013 at 10:45 AM
    flyzeye designs
    Darren
    Mesa, AZ
    Replied. ;)
  18. Jan 7, 2013 at 11:13 AM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Never seen nor heard of this product before. After looking at the website, I ordered.
  19. Jan 7, 2013 at 11:29 AM
    flyzeye designs
    Darren
    Mesa, AZ
    So, I see we need to expand our efforts in getting the word out! :eek:
    Your order has been received, and processed. Your TCMA-0513 LED light will go into production later today/tonight and likely ship no later than Wednesday. :)
  20. Jan 7, 2013 at 11:32 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Took my ac control box out this wknd to wire the switch blanks underneath and it slid right over my v2 mounting plate :)
