Options to increase payload
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BaconPower, Aug 15, 2016.
  1. Aug 15, 2016 at 9:09 AM
    BaconPower
    BaconPower [OP] Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    Having a '13 model not subject to rear spring TSB, I'm looking around for options to increase rear payload capacity by a good 600lbs.
    So here's a list of options I've gathered. If you have tried any of these let us know how it worked out for you:
    Bump-stop replacement option:
    In general this involves replacing the factory polyurethane bump-stop with a taller, more gradual polyurethane bump stop. It's the easiest way to go, but not the most comfortable. They do not usually come with a weight rating. Polyurethane bumpstop prevent the suspension from bottoming-out metal-to-metal by having a somewhat gradual rubber flex. More info here. Here are a list of aftermarket bumpstops:
    Air-springs
    Air springs are the bees knees in comfort. They're adjustable according to payload by pumping more air. A bicycle pump can be used since 40psi is usually enough. But airsprings are more involved to install, they can be lacerated/punctured by road debris, can leak and don't last forever. And they're expensive.
    Add-a-leaf
    Adding a leaf to the pack is more involved than the bumpstop replacement but it's a tried and true method. It lasts forever (as long as a leaf pack). But the ride is harsher when the bed is unloaded.
  2. Aug 15, 2016 at 9:18 AM
    Pigpen
    Dan
    Northwest Montana
    I love my Firestone Ride Rites. I've had them for a few years. I just put on Dakars with AAL and kept the air bags, but they're just expensive bump stops at this point.
    I'd like to find someone who wanted to trade their Timbrens for my Firestones.
  3. Aug 15, 2016 at 9:23 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    maybe look at finding someone local with the 4 leaf tsb on the cheap side and maybe add a leaf.
    or just buy a dakar pack.
    for the extra 600lbs the dakars will be just right without adding the d29xl extra leaf.
    I would avoid air bags unless towing often.
    some nice bump stops would be nice, but i would highly suggest the dakar pack first.
    balljoint likes this.
  4. Aug 15, 2016 at 9:30 AM
    Pigpen
    Dan
    Northwest Montana
    I keep a lot of weight in my truck and tow often. I can't recommend the Dakars enough. They are burly, yet ride smoothly. If you want to save money, buy me some Timbrens and I'll send you my air bags. They come with the Daystar cradles too.
    Jdiaz109, balljoint and lobsterbait like this.
  5. Aug 15, 2016 at 9:35 AM
    nevadawolfe
    nevadawolfe Well-Known Member
    Heather
    Northern Nevada
    2019 MBM DCSB SR “The Boss”
    MESO mod count: 2 Mickey Thompson Sidebiter II’s - 16x8 mattgecko under hood light kit - cool white
    How harsh does the ride get with Dakars over the stock with AAL? I don't haul big weight now but I'm trying to plan ahead for at the very least a decent shell and hopefully a little trailer for camping. Also have a hubby with back problems so trying to get a happy medium between performance and comfort as a DD here.
  6. Aug 15, 2016 at 9:39 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Dakars make the truck ride like .. a truck. Not harsh, but definitely stiffer than stock.
    If you want to keep the ride supple but have adjustability down the road, get airbags. And spend the extra coin for the Firestones, the Air Lift springs suck. AMHIK. Daystar airbag cradles are a must if you wheel the truck on anything beyond a gravel road.
    I have Dakars - and airbags. But I'm a belt/suspenders kind of guy.
  7. Aug 15, 2016 at 9:45 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I just installed Dakars yesterday (3rd leaf removed) along with new rear shocks (Fox 2.0 RR). With the limited driving I've done I'd say the he ride is better than stock...not firm or jarring at all. Once everything settles I should end up with about 2" of lift from the new leaf packs.
    Bobcdn and nevadawolfe like this.
  8. Aug 15, 2016 at 9:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    :goingcrazy:
    :D
  9. Aug 15, 2016 at 9:55 AM
    nevadawolfe
    Heather
    Northern Nevada
    This is what I was thinking of doing. I have new Icon stage 2 RR shocks so I figure taking the one leaf out will help things a bit. Thanks for the input guys! Now I know yet another thing I have to buy for this truck... never thought I'd end up selling my soul to mod this thing when I first got it, but it's worth it. :evil::rofl:
    bluezzy and stickyTaco[QUOTED] like this.
  10. Aug 15, 2016 at 9:57 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Dakars and shackle flip FTMFW! :luvya:
    20yrTaco, JadedTaco, DrFunker and 2 others like this.
  11. Aug 15, 2016 at 9:58 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Not sure where in NNV you are but you're welcome to take a ride in my truck before pulling the trigger on Dakars. Also, check with Headstrong on pricing for the leaf pack.....they beat the GB pricing that was running last month.
    nevadawolfe[QUOTED] likes this.
  12. Aug 15, 2016 at 10:02 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    No matter what you do, you won't legally increase payload over what is on the sticker on the door jamb. My truck is a 2007 almost identical to yours with a cargo capacity of 1200 lbs. Yours is probably pretty much the same. Trying to get another 600 lbs out of that would give you more than most 1/2 tons are rated for and is not a realistic goal.
    If you need to carry an additional 600 lbs you need a bigger truck or use a trailer.
  13. Aug 15, 2016 at 10:07 AM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    Upgrade to a full-size truck. If you start trying to exceed stock payload you're probably going to find the weakest links in a hurry.
    A fairly basic F-150 (should still have similar features to a Tacoma) with the 2.7L EcoBoost and their 'payload package' might fit the bill.
  14. Aug 15, 2016 at 10:13 AM
    nevadawolfe
    Heather
    Northern Nevada
    I might just have to take you up on that offer... I'm just outside of Carson City, so not too far from you.
  15. Aug 15, 2016 at 10:34 AM
    BaconPower
    Portland, OR, USA
    The way I see it, the 4.0L and its transmission are designed to easily support a supercharger, so they are both capable of more in stock form. Also if you look back at full-size trucks from 15-20 years ago, their torque figures were comparable to the 2nd gen 4.0 but their payload/towing capabilities were rated higher.
    The 2nd gen chassis/brakes are plenty strong as well. Now everyone knows the weakest link on a 2nd gen is the rear suspension. Maybe Toyota did not want the Tacoma to compete with the Tundra and gave it such low payload figures, who knows?
    Once rear suspension is improved, this weakest link is no more. I don't know which is the next weakest link but I believe an extra 600lbs payload (regardless of manufacturer rating) is feasible.
    Also keep in mind that the 2nd gen Tacoma is a mid-size truck, like the T100 used to be. The 1st gen Tacoma was small size but the similarity is in the name only. 2nd get Tacomas have almost identical outside dimensions to the T100 and first-gen Tundras.
  16. Aug 15, 2016 at 10:36 AM
    dmharvey79
    Dennis
    Northern Virginia
    Keep us updated!
  17. Aug 15, 2016 at 10:44 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I have the Hellwig 550s and they work fine for what I need. Boat trailer with 250 lb tongue weight + bed full of camping gear. The Hellwigs keep me from riding nose up which is what happened before I added them.
  18. Aug 15, 2016 at 11:02 AM
    BaconPower
    Portland, OR, USA
    Did you install 1 or 2 leaves per spring pack?
  19. Aug 15, 2016 at 12:43 PM
    Marshall R
    Marshall
    none
    The engine and transmission aren't the issue. The truck is rated to tow 6500 lbs and will be able to move an extra 600lbs in the bed with ease. The issue is the suspension, and legalities. Adding 600 lbs of capability is a 50% increase over factory and would get it up to 1800 lbs. My 2014 F-150 is only rated at 1620. The newer aluminum body trucks are several hundred pounds lighter and it is reflected in more payload. But you'll find around 1600 lbs is pretty typical of most steel body 1/2 ton trucks by any manufacturer unless they were ordered with heavy duty payload packages. Even those will just barely get you to 2000 lbs. Not much more than the 1800 proposed.
    You also have to look at the ratio of cargo weight to vehicle weight. My F-150 weighs almost 1500 lbs more than my Tacoma. Adding 200 lbs more in the Tacoma than the F-150 is rated for would push that light of a vehicle around a bit I'd think.
    Just because you can find a way to swap components and put 1800 lbs in one of these trucks and have it ride level doesn't make it legal to do so. You could find yourself explaining a lot to a judge if you're ever in an accident.
    I'd say the rear axle.
  20. Aug 15, 2016 at 1:09 PM
    Pigpen
    Dan
    Northwest Montana
    I run around with 400 pounds in the bed daily and 600 is common, plus I tow regularly. I don't think OP is suggesting increasing GVWR, though all vehicles are capable of operating past their legal limit.
    Putting 600 pounds on stock suspension regularly is a bad idea. I ran air bags on stock 2+1 springs with all this weight for a couple years and it worked great. My main concern was axle wrap and the damage it can cause. That's why I added Dakars.
