Options when not carrying a spare
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NeonHeights, Sep 8, 2017.
  1. Sep 8, 2017 at 8:29 PM
    #41
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    6 inch fabtech lift. Trd beadlock wheels from the factory
  2. Sep 8, 2017 at 8:30 PM
    #42
    NeonHeights
    NeonHeights [OP] Well-Known Member
    Width of wheel & What Backspace + offset? No way youre running 16s on a DB without decent stanced wheels.
  3. Sep 8, 2017 at 8:31 PM
    #43
    Bebop
    Nick
    Yeah I am
    uurx and nDub like this.
  4. Sep 8, 2017 at 8:33 PM
    #44
    Bebop
    Nick
    Wheels are stock from the factory. Couldn't part with them when I did my lift
  5. Sep 8, 2017 at 8:34 PM
    #45
    NeonHeights
    No way, You running spacers though? awesome you got away with that! Fabtech even says on their website that you need a minimum of 17" wheels with 4 & 4/5 Backspacing. Crazy. I was gonna go with fabtech for my DB lift but it was another $1500 vs the BDS kit and was hard as hell to find in canada for cheap
    "Our 6" Basic Systems include steel coilover shock spacers that utilize the stock front coilover shocks for a factory like ride. This system includes our proven IFS technology with extended length ductile iron steering knuckles and arched crossmembers for exceptional suspension ground clearance with a 1/4" thick differential skid plate, impact struts, heavy duty tie rods, rear add-a-leafs and more.
    *FOOTNOTES
    65. Must use 17" wheels or larger."
  6. Sep 8, 2017 at 8:36 PM
    #46
    Bebop
    Nick
    Fabtech is full of shit. You gotta get creative. I spent 40 bucks extra on my way to get the wheels to work.
  7. Sep 8, 2017 at 8:42 PM
    #47
    NeonHeights
    Amazing, in all honesty I was wondering about a lot of the requirements that some of these manufacturers spec.. BDS said you absolutely could not run anything below 18 but theres another member here who runs 17's with a super wide stance on the same kit I have. Same with the Pro Comp kits, they say you need 18s but ive seen members running 17s as well. I didnt want to chance having 16s or 17s not fit and not having a vehicle for a few days cause the tires wouldnt fit on it. I need my truck for work so I had to do the 18s. Oh well. Im not a huge fan of the bigger rims so I may end up selling these and figuring out a way to work with 16s or 17s like you when I burn through these tires.
    How do you like the fabtech kit? Was it worth the price?
  8. Sep 8, 2017 at 8:45 PM
    #48
    Bebop
    Nick
    Spacers and blocks are garbage. Love the ride height but the ride is crap. Saving for some full length king coilovers and bigger rear leafs to eliminate the blocks. Also some adjustable upper control arms to get your caster back into spec. I also want to do longer rear shocks with the weld on shock hoop
  9. Sep 8, 2017 at 8:53 PM
    #49
    NeonHeights
    Yeah ive got 4" blocks in the rear, I know all about that. When the bed is empty and theres no weight back there, it feels like the world is ending going over potholes/bumps. Eventually going to invest in an alcan 6" leaf pack, but that isnt cheap either. I also get minor driveline vibrations for about a second or two after being stopped if I hit the gas too hard. 99% sure its from the massive blocks I have in the rear.
  10. Sep 8, 2017 at 8:56 PM
    #50
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Auto club premiere membership or RV membership have the best roadside privileges such as (1) tow up to 200 miles and numerous other benefits
  11. Sep 8, 2017 at 9:20 PM
    #51
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Walking is good for the soul anyway
    vssman, Pigpen and TxFireman like this.
  12. Sep 8, 2017 at 9:38 PM
    #52
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    That would work- we all cringed reading your topic title!! :)
  13. Sep 8, 2017 at 9:54 PM
    #53
    Pigpen
    Dan
    Northwest Montana
    This was my exact thought upon reading the first post. Find a used tire close to the diameter you're running now. Get a real spare and matching tire when you can.
  14. Sep 8, 2017 at 10:01 PM
    #54
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Everywhere is walking distance if you have the time.
    *steven wright
    TexasWhiteIce likes this.
  15. Sep 9, 2017 at 4:55 AM
    #55
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Buy a decent quality air compressor, plugs, and tools. But buy a spare too. No matter how much it costs it is cheaper than the alternative. I've been doing this too long. I keep compressors, plugs and spares in all my vehicles. Over the last 20 years I've probably plugged 20 tires for myself and others. It is a LOT simpler, safer and faster than putting on a spare.
    But it can't always be done. I've had holes too big to be plugged. Once I got 3 plugs in a tire to hold air enough to get me to the next exit and a tire store. They couldn't save the tire, but put on my spare for $10. It was worth it being 1000 miles from home and cheaper than buying another tire. Another time I was 20 miles from pavement when the same thing happened, hole too big to fix with plugs and AAA couldn't get to me without a 4X4 even if I'd had cell service. Which I didn't. Did I mention that it would be good to have a spare.
    The compressor is also good for airing tires up after a day of driving off road. I usually keep 30 psi in my trailer tires since an ATV is the heaviest thing I normally carry. But last week I needed to haul a HEAVY load. I forgot to air up the tires to 50 psi until AFTER loading the trailer when I noticed low tires. Using the compressor it took me about 10 minutes to get both tires up to 50 psi and get back on the road.
  16. Sep 9, 2017 at 5:04 AM
    #56
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    just a few random options if one was stranded without a spare....
    87e3bedfe61d79ee113ba6723c0e32b4.jpg images.jpg MotoJackRack.jpg dsfasdfsfs.jpg forrest-gump-nike-cortez.jpg
  17. Sep 9, 2017 at 5:32 AM
    #57
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    If you have the money to lift your truck, you have the money to buy a spare. I would never go anywhere without a spare. DUH
  18. Sep 9, 2017 at 6:50 AM
    #58
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Carry a spare tire of appropriate size on your old rim, if you get a flat on the front, you'll have to move a rear tire to the front then put the spare on the back. More work but you'll be able to be more self sufficient.
  19. Sep 9, 2017 at 7:37 AM
    #59
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    #59
  20. Sep 9, 2017 at 8:14 AM
    #60
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I've always taken it as gospel to never drive without a spare.... So I dont
