Options??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kaiser1, Nov 8, 2018.
  1. Nov 8, 2018 at 9:32 PM
    Kaiser1
    Kaiser1 [OP] Well-Known Member
    2017 tacoma
    I just bought a new 2017 sr with a small lift, but the dealer put 285/75/16 tires on it and the tires rub on the uca when I turn sharp.
    And when the tires are straight they are almost touching the uca.
    Do I need skinnier tires or should I get som spacers?
  2. Nov 8, 2018 at 10:53 PM
    COOutlaw
    COOutlaw Old Guy-fan of: Shotguns,Birddogs,Flyrods,Whiskey.
    Colorado
    2019 DCLB TRD OR CEMENT
    None yet
    Lift specs? Wheel type (stock or aftermarket) offset ? Pretty hard to know what doesn't match without knowing what you currently have.
  3. Nov 8, 2018 at 11:02 PM
    Kaiser1
    2017 tacoma
    Spacer lift, probably 1” not sure about offset. They are Toyota stock wheels
  4. Nov 8, 2018 at 11:07 PM
    COOutlaw
    Colorado
    None yet
    I believe 285's will require a 2 1/2-3" lift (ideally with UCA's) and Body Mount chop or at least trimming to clear without rubbing....guessing the dealer went overboard with tire size and assume the fender wells look fully stuffed. 265/75/16's will clear stock but would have been ideal with just a spacer lift.
    You can search the threads for builds running 285's and see the suspension mods it takes to run them. If the 285's are new the cheapest route would be to sell them and buy some 265's....your fuel mileage and power will increase as well. Alternatively....you can do suspension work and a full lift set-up and continue to run the 285's.
    Kaiser1[OP] likes this.
  5. Nov 9, 2018 at 1:46 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I think spacers might help.
    Kaiser1[OP] and Nunya Bizness like this.
  6. Nov 9, 2018 at 8:00 AM
    Kaiser1
    2017 tacoma
    Thanks
  7. Nov 9, 2018 at 8:06 AM
    su.b.rat
    su.b.rat broken truck
    your dealer totally short cutted your truck setup and made it look good at the expense of all function. if you want that Tacoma to perform like it should then remove that crap and go back to stock, or pay the money for a proper lift and keep your 285's, or deal with a looks-good-until-you-drive-it lift with rubbing, handling issues, and poor suspension performance. good luck.
    Kaiser1[QUOTED][OP] likes this.
  8. Nov 9, 2018 at 8:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ask them to swap the tires to a 255 80 17 or 255 85 16 (depending on your wheel size)
    That will give you the full 33" dia and eliminate the rub.
    Since they did it 'wrong', they should do the swap for low to no cost to you, assuming you've not piled a bunch of miles or wear on them.
