OR to TRD Pro Fox shocks impressions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Madtown, May 5, 2018.
  1. Jan 22, 2020 at 12:15 PM
    #201
    MacAttck5
    MacAttck5 Member
    2019 TRD OR
    I think I read a few pages bacl that they are.
    I've been pricing Fox 2.0 as well.
    GreyBaldTaco[QUOTED] likes this.
  2. Jan 22, 2020 at 12:22 PM
    #202
    MacAttck5
    MacAttck5 Member
    2019 TRD OR
    Appreciate the feedback.
    He's said they are priced at $800 considering the rebuild but I'll offer what you suggest.
    Thanks again.
  3. Jan 22, 2020 at 12:26 PM
    #203
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I paid $150 for a full set with 20k on them, one shock needed a rebuild. I think due to the down time of having no shocks for 1-2 month turns most people off to rebuilding and they just buy a new set of something else.
    Also keep in mind, that price I gave you is just for a rebuild. If they have to replace any parts then the cost goes up. It was a extra $90 to have the shaft on my rear replaced during the rebuild. The unknown costs that may pop up is what kills rebuilding for many people unless they got a real good deal.
    If all the shafts are scratched up and need to be replaced, there a extra $90 per strut tacked on to the 500-600 rebuild cost. Not trying to scare you away from getting them, but something to keep in mind.
    If possible, look under the boots (you will need a flash light for the fronts)
    MacAttck5[QUOTED] likes this.
  4. Jan 22, 2020 at 2:13 PM
    #204
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    $600 tops.
  5. Jan 29, 2020 at 11:58 AM
    #205
    SmokeyTacoAZ
    SmokeyTacoAZ Well-Known Member
    2018 DCSB TRD 4x4 OR
    Stupid question alert!
    So to confirm, anyone with a TRD Pro has to have the fox suspension rebuilt at 50k miles by the fox factory or buy a new set? I'm guessing most end up doing the latter due the impractical amount of time waiting for the rebuild for a daily driver. I'm researching lift kits so this is all new to me.
  6. Jan 29, 2020 at 12:02 PM
    #206
    5nahalf
    Erik
    Minnesota
    They recommend rebuilding at 50k (normal driving) 10k for heavy offroad use. But yes, I would assume most people would either buy new aftermarket stuff or not even bother rebuilding the fox shocks. This is why I am keeping my trd offroad suspension, I can swap out the pro stuff to get it rebuilt in 30k miles (mine had 20k when I got it)
    SmokeyTacoAZ[QUOTED] likes this.
  7. Jan 29, 2020 at 12:37 PM
    #207
    SmokeyTacoAZ
    Oh duh! That's a good idea! I have an Off-road and am thinking about doing the Pro suspension at some point and roughly calling it done. Seems like that would work well unless you add a bunch of other weight to the truck in the interim.
  8. Jan 29, 2020 at 12:47 PM
    #208
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    The recommended rebuild interval is for aftermarket Fox shocks/struts, not the TRD Fox shocks/struts. AFAIK there is no recommended maintenance intervals for TRD Foxes. Obviously no fluid lasts forever, but I would not rebuild anything unless they were leaking or riding rough, IMO.
  9. Jan 29, 2020 at 12:51 PM
    #209
    5nahalf
    Erik
    Minnesota
    Fox recommends following the standard fox maintenance schedule even for the toyota ones (since they are made by fox)
    https://www.ridefox.com/service.php?m=truck&ref=topnav
  10. Jan 29, 2020 at 1:05 PM
    #210
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Right, but none of it is relevant to TDR Foxes. I mean it's not bad to follow that recommendation in general, but it is not necessary, IMO.
  11. Jan 29, 2020 at 1:11 PM
    #211
    5nahalf
    Erik
    Minnesota
    OG_Tacoma and savethewheels like this.
  12. Jan 29, 2020 at 2:34 PM
    #212
    Pro-Taco
    Lou
    Commiefornia
    All TRD Pro parts
    Here is response to my email to Fox:
    Me:
    Is it necessary to rebuild at 50k regardless, or is it just a suggestion to keep them in top shape? If mine are not leaking or exhibiting any abnormalities do I absolutely have to rebuild them?
    Thank You
    Fox:
    Hello,
    These are suggestions, decrease in performance or visual signs of wear or leaks will be key indicators.
    Thank You,
    Service Department – Offroad Division
    Truck | SUV | Offroad Race | Defense |Circle Track
    orservice@ridefox.com
    Direct-1-800-369-7469 (press 8 then 2)
    Fax-619.596.3740
    1280 N. Johnson Ave Suite 100, El Cajon, CA 92020
  13. Jan 29, 2020 at 3:02 PM
    #213
    5nahalf
    Erik
    Minnesota
    Well no, you also dont need to go to the dentist 2 times a year, but you do it to keep your teeth in good shape.
    If I have a high end suspension then you better believe im going to make sure its working 100%
    OG_Tacoma likes this.
  14. May 17, 2020 at 6:50 PM
    #214
    BOZOJUICE
    BOZOJUICE Well-Known Member
    2023 ICE CAP PRO
    Ready to make the switch to keep with OEM parts on my rig. Just placed on order PTR61-35071 kit from Bam Wholesale Parts. Next order will be strut top hats. Already using Timbren in rear. Then plan half day for install after arrival.
  15. Jun 3, 2020 at 10:24 PM
    #215
    BGXtobe
    BGXtobe Well-Known Member
    Central Valley, CA
    2016 MGM TRD Sport 4x4
    Does anyone know if the 2017-2019 TRD Pro fox shocks will work on a 2016 tacoma?
    I mean it makes sense that they would but every website ive looked at only has those years (2017,2018,2019,2020) for the tacoma fitment but not the 2016.
  16. Jun 3, 2020 at 10:27 PM
    #216
    5nahalf
    Erik
    Minnesota
    2016-2018 are all the same, 2019 got a slight refresh, 2020 got a full refresh. They will all fit any 2016-2020 model though.
    BGXtobe[QUOTED] likes this.
  17. Jun 3, 2020 at 10:31 PM
    #217
    BGXtobe
    Central Valley, CA
    Thanks, is there any big differences to the refresh that are worth paying for?
  18. Jun 4, 2020 at 6:52 AM
    #218
    5nahalf
    Erik
    Minnesota
    19 I think was just a cosmetic change, 20 got new springs and some slight changes to the shocks. I would say probably not, but I have not used to 2020 shocks.
  19. Jun 4, 2020 at 8:25 AM
    #219
    stylett9
    stylett9 Active Member
    Orange County Ca
    07 Taco
    none so far.
    I'm not an expert, but I'm going to go out on a limb and say Toyota probably wouldn't equip any of their vehicles with parts that MUST be replaced or serviced at 50K miles, considering what their brand reputation is supposed to represent. Fox is probably recommending 50K service maintenance as preventative maintenance and to be honest, additional fee revenue, but if you are putting your Pro through normal driving, I would imagine you would approach 100K before truly needing servicing, no different than any other vehicles suspension. Assuming it's just a regular daily driver.
    just my two cents
    jetfishn, Hank Heel and Pro-Taco like this.
  20. Jul 5, 2020 at 9:47 PM
    #220
    Notcris
    Notcris Well-Known Member
    Cristian
    Georgia
    2021 4runner Lunar Rock Trd Pro 2004 Xtra xab red
    None
    What are you guys paying for used Trd pro suspensions? Someone in my area wants 1200 for one that came off a trd pro at 7500 miles of a 2017.
