OR trim- less obvious differences, rear axle strength, etc...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NHOwl, Mar 3, 2016.
  1. Mar 3, 2016 at 10:04 AM
    NHOwl
    NHOwl [OP] Well-Known Member
    I've seen several posts regarding the obvious differences between the OR and other trims (mechanically) such as Crawl Control/MTS, suspension, locker, available manual trans. I've also seen one post that specifically called out the hydraulic brake booster instead of vacuum.
    I searched and found zero that mentioned any benefits to the 8.75" rear over what I believe is a smaller rear in all other models (8.5"?). I have a Jeep TJ currently and getting the Dana 45 over the Dana 35c was a BIG deal strength wise. So here are my questions
    1) Am I wrong and all models have the 8.75" rear so therefore this is irrelevant?
    2) If only the OR has the 8.75" is there no strength difference? Does it not matter in any way besides fitting the e-locker? I'm just surprised it hasn't been a topic of discussion if there is any strength difference...
    3) Are there any other mechanical differences like this which are not commonly discussed?
    Thanks...
  2. Mar 4, 2016 at 11:37 AM
    NHOwl
    No one knows?
  3. Mar 4, 2016 at 11:53 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    maybe the 4 cylinders have the smaller rear? Not sure.
  4. Mar 4, 2016 at 1:35 PM
    Doug007
    Doug007 Well-Known Member
    Doug
    Houston, TX
    '16 TRD Off-Road M/T
    tombiosis likes this.
  5. Mar 4, 2016 at 4:19 PM
    Trifenix
    so cal
    99 LT 5 lug Taco
    so the 4x4 sr5 does not have have 8.75 diff?
  6. Mar 4, 2016 at 5:09 PM
    Doug007
    Doug
    Houston, TX
    Nope. SR5 4x4 V6 has the 8".
  7. Mar 4, 2016 at 5:38 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  8. Mar 4, 2016 at 6:56 PM
    NHOwl
    Thank you- very useful. For the record I did search and this did not come up- go figure.
    Is there a difference in the axle shafts as well? I'm guessing so given the different weight bearing?
    Are there any other random differences then besides the hydraulic brake booster?
  9. Mar 4, 2016 at 9:26 PM
    Trifenix
    so cal
    99 LT 5 lug Taco
    Thanks for the info! I was thinking about just sticking with a 4x4 sr5 and use the money saved for mods but now the rear axle has me thinking.... I wonder if the 8" is strong enough for offroading?
  10. Mar 4, 2016 at 9:44 PM
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    I've only recently seen posts about that but haven't found anything confirming it's a hydraulic booster. I looked at it but it was hard to tell. I wasn't sure if the lines I saw were off the power steering pump or something else.
