Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Feb 8, 2017 at 9:24 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I have a 2900. It is ok. Cool you can change the channel in the mic. The range is killer far. I can talk to Hesperia from out at Johnson Valley. Had it for 5 years and rough off road. I use a 3db 5/8 antenna.
    The Kenwood that pci uses or that rugged radio one is sweet.
    Just going off memory.
  2. Feb 8, 2017 at 9:27 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    @itaro sent me the pics :D
  3. Feb 8, 2017 at 9:35 PM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Yeah Mike, the main complaint, at least with the 1900 is the squelch. I'm almost FULL squelch and it acts as if it is open??? Even messing with the "digital" side of it, I forget what they call it, but anyways, I've dialed up/down on those settings to see if I can get better squelch capability only to find out that that is one of the main complaints for that model/unit. I just don't know if it followed through with the 2900? Other than that, it works VERY WELL and I have no real "complaints", in that sense!!! Very easy to change settings once you get the hang of it. Again, for my 1900.
    Regarding the full wattage setting, I almost NEVER go full wattage unless I have to. You're doing your radio a favor in doing that as well.
  4. Feb 8, 2017 at 9:38 PM
    Redfive11
    Redfive11 Well-Known Member
    La Mirada, CA
    2012 PreRunner
    FOX 2.5 EXTENDED TRAVEL w RESI /DSC CAMBURG UCA PELFREYBILT HYBRID FRONT BUMPER
    SOOOOOO.....your sayng stay with the one I have?? the B-tech one?
    WileECoyote[QUOTED] likes this.
  5. Feb 8, 2017 at 9:50 PM
    MadTaco461
    CA
    Kinda stock
    I leave my squelch about 75% or higher. Yeah only transmit full blast a few times to get some friends really far away. 5 watts on top of idyllwild i talk to San dimas. If I'm too close to a bunch of radios I'll get some interference on rare occasion.
    WileECoyote[QUOTED] and dtaco06 like this.
  6. Feb 8, 2017 at 10:06 PM
    WileECoyote
    SoCal
    That or go with the mini? The mini is NOT a bad way to go due to its size. I just don't know if it will fit where you want it to go height and width wise? As far as depth for the mini's, unless your firewall is up to your knees, then you have quite a bit of depth to play with from what I'ver personally seen with Madison's and Mike's radio (a.k.a. their mini's or versions of it).
    Also, if you are pretty much at max depth with the radio that you have, I HIGHLY recommend you get that RF 90* adapter because it will save you SOME room as far as depth. Remember, you have to think about your RF cable and it is going to add even that much more depth because they are typically STRAIGHT cables! You NEVER EVER want to KINK an RF cable!!!
    I'm noticing that you are going for higher wattage, which, I can understand, but 10W and 25W will take you quite far out there. I can connect to the 2m repeater near Big Bear from HB area without ANY issues. Even on LOW wattage on my Baofeng HT!!! From the foothills or very near the Azusa foothills, I can connect to the HB RACES repeater with very little to no problems. The valley areas, it tends to cut IN/OUT, but I expect certain areas to do that as that needs to be taken into consideration anyways. Yes, there are times when you need to up the wattage a bit, but very rare and in this example that I give, these are units that are putting out about 1W on LOW and roughly 5W on HIGH. For the mini's, now you are getting into the +10W range, which is starting to get pretty healthy transmit wise. The one thing that people don't get or understand at first is that they think that wattage is everything? Well, hate to break the bubble, that is NOT always true and I think alot of HAMs would agree with me. The main key is the antenna and how good your antenna system is setup!!!!!!! Magmount is okay, hard mount is even that much better!!!
    Regarding the "unlocking", I honestly do not know if you need or not need to do that for those mini's? Heck, for all I know, you may need to do that for the one that you already have, unless you have already semi-connected it and TESTED for that??? From my personal experiences, it all depends on how they shipped from the factory. Even when you think you have the latest and greatest, you may get a unit that has older firmware in it just because it's been sitting on the shelf longer for whatever reason?!
    So, with that said, for certain situations, they will tell you to look for the firmware version of your radio to be able to connect to the appropriate CHiRP software.
    Just telling you about my experiences with my radios and what I know and what I have read and what I have had to deal with.
    MotoEd likes this.
  7. Feb 8, 2017 at 10:20 PM
    WileECoyote
    SoCal
    That is about where I have my squelch, maybe a little higher. I would rather have it so that it sits at around 50% or a little lower to have "room to play with", if you get my meaning.
    Also, F'ME, "5W" and you can reach San Dimas!!! :eek::thumbsup::fistbump: That's still pretty krazy far! Just AWESOME! But, are we talk'n through a repeater? Or NO repeater? That's gotta be through a repeater?!
    MotoEd likes this.
  8. Feb 8, 2017 at 10:51 PM
    Nicklovin
    Nicklovin [OP] Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    The :frusty: Of Randy :cool:
    ODNAREM, Maggot61 and WileECoyote like this.
  9. Feb 8, 2017 at 10:56 PM
    WileECoyote
    SoCal
    Hey, my last post was short! LOL! :rofl::rofl::rofl:
    Nicklovin[QUOTED][OP] likes this.
  10. Feb 8, 2017 at 11:25 PM
    BLKTRUCK
    BLKTRUCK Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
    I have one but it has a small dent. Yours if toy want it.
    itaro[QUOTED] likes this.
  11. Feb 8, 2017 at 11:34 PM
    BLKTRUCK
    The Privilege
    Find Ron
    I figured you were looking for a rear bumper.
    It's not the straightest rear bumper but you can have it.
  12. Feb 8, 2017 at 11:39 PM
    BLKTRUCK
    The Privilege
    Find Ron
    Just a tad. I backed into a low pole a few years back. It's just been siting around.
  13. Feb 9, 2017 at 8:11 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
  14. Feb 9, 2017 at 8:12 AM
    Nicklovin
    Nick
    Tacoless
    Only 1 class then I'm done today
    :bananadance::bananadance:
    TXpro4X4 and KingTaco81 like this.
  15. Feb 9, 2017 at 8:23 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Nice. Im in coto de caza today :pout:
    1truckdriver likes this.
  16. Feb 9, 2017 at 8:29 AM
    Nicklovin
    Nick
    Tacoless
    Engles por favor :boink:
  17. Feb 9, 2017 at 8:29 AM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    I suggest going to Board and brew for lunch then! Its right next to coto
  18. Feb 9, 2017 at 8:31 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    16 DCLB OR
    Seconded.
  19. Feb 9, 2017 at 8:37 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    I have both the CB and HAM. Haven't set up the CB yet (too lazy to run the coax under the truck). I have a uniden CB and a kenwood TM-281 HAM. Both have firestik and fire ring setups with the HEAVY DUTY stainless steel springs.
  20. Feb 9, 2017 at 8:41 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Lol thats where i went yesterday!
    There sandwiches are on point!
