Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Feb 27, 2017 at 1:40 PM
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    Tire pressure question: so when I air down 18 is a sweet spot for me generally. Sobi air down to 20 on hot tires which puts me at 18 approximately. Now, the question is when I air back up to 40 (chalk test confirmed this is right for my tires) do I air up to 40 psig, 38 psig, or 42 psig? Been thinking about that a lot lately.
    eccracer104 likes this.
  2. Feb 27, 2017 at 1:41 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    When you do your chalk test, are you doing it with cold or hot tires? That should answer your question.
  3. Feb 27, 2017 at 1:42 PM
    uhplifted
    Brian
    16 DCLB OR
    I usually air up to an estimated area and then re-check my pressure later that night or the next morning when I'm home.
    Speaking of - I got myself a leak out in J Tree. Got it patched up this morning though
  4. Feb 27, 2017 at 1:44 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    With how cold the co2 is in the IAS tank I'd go 38 and let it warm up to 40.
  5. Feb 27, 2017 at 1:46 PM
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    Ok team. I bolted the rear and the ubolts in snug. Now there is too big of a gap to get the frame mount and the leaf to line up. What's the best plan? Front first? Only issue is the center pin then has issues lining up. It's one thing after another.
    Nicklovin[OP] likes this.
  6. Feb 27, 2017 at 1:48 PM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    Where do you live?
    itaro likes this.
  7. Feb 27, 2017 at 1:49 PM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    Speaking of co2. How do you like it? Found a spot that fills me up for 10 bucks. Stoked on that
  8. Feb 27, 2017 at 1:49 PM
    Nicklovin
    Nicklovin [OP] Mall Crawlin Through Life
    Nick
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    :cool:
  9. Feb 27, 2017 at 1:50 PM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    Ahh. The corona crawl prevents me from going there.
    YotaGurlIAm likes this.
  10. Feb 27, 2017 at 1:50 PM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    I go front to back with the deuce gens
  11. Feb 27, 2017 at 1:53 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    What worked on my truck when @goblue82 and I did the install was front first, then lined up the center pin, then rear. Idk if it'll be the same for a 1st gen but same concept.
    It's great so far! After JT took 20 seconds per tire to go from 20psi to 32 :D Easy as can be to set up and use, no complaints so far.
  12. Feb 27, 2017 at 2:04 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Lol nice avatar
    Nicklovin[QUOTED][OP] likes this.
  13. Feb 27, 2017 at 2:06 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Then Greg needs ~36.4psi cold to get 40psi hot?
  14. Feb 27, 2017 at 2:09 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Assuming you did the chalk test on cold tires:
    40 PSI if your tires are cold.
    44-45 PSI if your tires are already warm.
    If you've been wheeling all day im not sure if this counts as warm or cold, most likely somewhere in the middle, depending on what you were doing.
    I usually air up to a reasonable amount somewhere close to what it should be and then check my tires again the next day when they are cold so that I can make sure the pressure is good.
    eccracer104 and dtaco06 like this.
  15. Feb 27, 2017 at 2:15 PM
    goblue82
    The Dude Abides
    Southern California
    Click muh sig
    Word. I think the consensus is air up to approximate proven value and then recheck asap on a cold tire. Respek. I'm guilty of not always rechecking the next day.
    Dammit, all this airing down and up talk has me jonesin' to go wheeling. How was mammoth, James? Snow for days I know that much.
    dtaco06 likes this.
  16. Feb 27, 2017 at 2:17 PM
    downhillbik3r
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Mammoth was sweet, good weather Saturday. I stayed in a second story condo and had snow blocking some of the windows. Massive amounts of snow everywhere.
    MotoEd and YotaGurlIAm like this.
  17. Feb 27, 2017 at 2:21 PM
    Tacotruck7
    SoCal
    Well my axel must be angled or something I'm just
    Going to wait for my neighbor to get home at 4 from work because I'm a kook and can't line it up. Front is bolted back isn't and I still have issues.
  18. Feb 27, 2017 at 2:23 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Got a picture of where you're stuck?
    I had to use a bottle jack to apply pressure to move the leafs where they needed to be to bolt everything up. The 2nd side went in much smoother though haha. Sometimes you have to outsmart the truck and move one thing to make room elsewhere.
    LOLLY likes this.
  19. Feb 27, 2017 at 2:28 PM
    Nicklovin
    Nick
    Tacoless
    TXpro4X4[QUOTED] likes this.
  20. Feb 27, 2017 at 2:29 PM
    Tacotruck7
    SoCal
    Let me know if you need more. The front is bolted.
