Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Apr 11, 2017 at 12:32 PM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    I use to have an iphone back when they firat came out ... how much did the change ?
  2. Apr 11, 2017 at 2:39 PM
    bigbarlo
    bigbarlo The Church of @ODNAREM OC Chapter 80085
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
  3. Apr 11, 2017 at 2:42 PM
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
  4. Apr 11, 2017 at 2:48 PM
    bigbarlo
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    @WileECoyote There is a class on the 29th in Long Beach. Know of any others?
    WileECoyote likes this.
  5. Apr 11, 2017 at 3:15 PM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    SWEET!!! I don't know if you have a license or not, but I can show you how to connect to a repeater if you do. Also, if you come this Thursday, I can show you a couple things that may or may not be useful... it all depends on how the person wants to operate the radio I guess? But, anyways, I can show you a few things.
    My advice, get an aftermarket antenna to help with "range". Meaning, the efficiency of those stock duckies just SUCK A$$ for sure and you will thank me later, I'm sure!!! They're just NOT very efficient with the TX/RX although you would think that would be the case. A very common aftermarket antenna is the Nagoya NA-701/717/771, but the 771 is pretty long and can be a hassle within the cab of you rig due to length. Btw, stock duckies suck on most, if not, all of other handheld name brands such as Yaesu, Kenwood, etc. That I know of, that is why most HAM's have a tendency to change them out... like I did. I know my previous boss and the sr. engineer did that for that very same reason.
    Finally, if you can, get the MIC for that thing as well and you can sort of make a "mobile" out of it. Hence, you no longer have to carry the handheld unit itself and instead, just the MIC. VERY USEFUL for sure.
    The pics below is how "I" typically use my Baofeng on the trails. Plus, as much as possible, if you don't have an external antenna, try to get your handheld's antenna as close to the window as possible to reduce your cab's interference when TX'ing... I don't know if you know this or not, but your cab will act as a "shield" and reduce your range quite a bit!!! I mean, you SHOULD, most definitely be able to contact anyone 100yds in front/back of you, but definitely your range is still suffering as the person is further out... even on the HIGH wattage setting!!! Just to let you know if you don't already know???!!!
    Just a close-up shot.
    The "pig tail" you see connected to the antenna port is to act as a strain relief when connecting to a larger type cable. You NEVER want to connect a larger type cable to a smaller connector as you can easily SNAP off the smaller connector!!! I'm just showing the overall MIC setup here.
    Awesome man!!! :thumbsup::fistbump::cheers:
    ODNAREM, Lord Helmet, MotoEd and 3 others like this.
  6. Apr 11, 2017 at 3:21 PM
    bigbarlo
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    Thanks man. Great tips. I do not have my license but I surely plan on getting one.
    goblue82 and ODNAREM like this.
  7. Apr 11, 2017 at 3:23 PM
    WileECoyote
    SoCal
    I do not. I definitely recommend the class as that is the route I took. The TEST is NOT that hard, but taking the class made studying soooooo much easier, at least for me. My instructor made certain things much easier to remember as well and I would go home every night starting from CH1 to whatever chapter we ended on and typically repeat the process a few more times and using his examples on how to remember certain things. The ohm's law and crap was cake, it was the rules crap that got me or certain other things, but the electronics part, I was already comfortable with.
    You no longer need to learn CW (morse code), but I'm still teaching myself. The problem with that is the fact that all of those di-dahs are useless if the receive end has no F'N CLUE on what they just heard, LMAO!!!
    Btw, regarding the class, if you had questions, there was someone that could answer them for you right away!!! For me, it just made it easier and I wanted to know the stuff and not just pass the TEST, but that is just how "I" am as a person.
    ODNAREM, Lord Helmet, MotoEd and 2 others like this.
  8. Apr 11, 2017 at 3:31 PM
    WileECoyote
    SoCal
    And, I have to seriously VENT HERE, LOL, but your manual is TITS!!! When I bought my Baofeng, it was like me wanting to just take the radio outside and put a nice hefty round through it to put it out of "MY" misery, LOL!!! :infantry:
    That was one of the things/complaints, that I know of, when buying these radios was that the manual just LACKED!!! I have been hearing that they've gotten better for sure and looking at yours proves that, LMAO!!! :woot::rofl::rofl::rofl:
    ODNAREM, Lord Helmet and Maggot61 like this.
  9. Apr 11, 2017 at 3:32 PM
    bigbarlo
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    I am the same. I tend to remember things better after taking a class as opposed to just reading.
  10. Apr 11, 2017 at 3:40 PM
    WileECoyote
    SoCal
    I am definitely more of a "visual person" for sure! :D:thumbsup::fistbump:
  11. Apr 11, 2017 at 3:55 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    I got my license last year. I used HamTestOnline to study and I highly recommend it. It lets you do as many practice tests online as you want. I think I only missed one question on the exam. The link to their site is http://www.hamradiolicenseexam.com/index.html
    goblue82, ODNAREM, uhplifted and 7 others like this.
  12. Apr 11, 2017 at 4:07 PM
    WileECoyote
    SoCal
    :wave: Dirk.
    Also, @bigbarlo make sure it is the correct question pool year!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I was also doing an on-line test and recommend it as well, but when I was studying/practicing one night a question popped up and it looked familiar, but the answers didn't seem to make too much sense???!!! It ended up being for sure that it was for the class license I was going for, but the question pool happened to be "older"!!!
    Anyways, just make sure to not make the same mistake I did while studying. I caught it fairly quickly, but, in essence, I was still studying an older question pool, which WILL mess you up if you're not paying attention!!!
  13. Apr 11, 2017 at 4:11 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    :wave: Randy. Been too long!
  14. Apr 11, 2017 at 4:18 PM
    WileECoyote
    SoCal
    Yeah, TRUST ME, I know!!! LOL!!! :rofl::rofl::rofl::annoyed::goingcrazy::frusty::facepalm::help:
    ODNAREM and sdsurfer[QUOTED] like this.
  15. Apr 11, 2017 at 7:21 PM
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    Used it like a champ this weekend!
    Good thing I still have @85straight car charger. Ha!
    dtaco06[QUOTED] likes this.
  16. Apr 11, 2017 at 9:21 PM
    Tacofart
    Tacofart Well-Known Member
    Brennan
    San Diego
    04 3.4 4x4 Dual cases/ Lockers
    Anybody in sd have this?
    It's the tool to remove and reinstall uniballs on tc uca's. 6pack of your choice if you let me borrow it!
    TXpro4X4 likes this.
  17. Apr 11, 2017 at 9:22 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I need to buy one of those to change out my upper uniballs
  18. Apr 11, 2017 at 10:11 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I like visual
    Especially with food
  19. Apr 11, 2017 at 10:12 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    I have a c-clamp
    But not what is in between
    eccracer104 likes this.
  20. Apr 11, 2017 at 10:16 PM
    Tacofart
    Brennan
    San Diego
    But who wants to pay $40 for it....
