Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Aug 3, 2017 at 8:15 AM
    TPDTaco
    TPDTaco Well-Known Member
    Brett
    Cypress,CA
    LT 2011 TRD Sport 4x4 DCLB MGM
    yeah my ultragauge doesnt show anything and i can try and look at what is happening to rpm etc when it happens but i am usually more worried about not getting hit etc
  2. Aug 3, 2017 at 8:16 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    ODNAREM, itaro, tcjacado and 8 others like this.
  3. Aug 3, 2017 at 8:18 AM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Get a job already and get off here :D
  4. Aug 3, 2017 at 8:20 AM
    TPDTaco
    Brett
    Cypress,CA
    ODNAREM, SocalOC, itaro and 6 others like this.
  5. Aug 3, 2017 at 8:22 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    ODNAREM, Nicklovin[OP], itaro and 8 others like this.
  6. Aug 3, 2017 at 8:25 AM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    AGREED!!!
    Yeah, speaking of RPM's, my RPM gauge would go from whatever down to ZERO, practically INSTANTLY, when that happened to me. I could literally see it because my cluster gauge on my Dodge had an RPM dial gauge even though it was an automatic, LOL!!! But, anyways...
    I was also thinking that if you have quite a bit of "appliances/add-ons" (i.e. stereo system amp, fridge, etc) and have a stock alternator, it's HARD on your charging system when you have all of that on a stock alternator. A while back, I was actually thinking about installing a +2500W Power inverter and was reading that they recommend changing the alternator to a bigger one due to power consumption demanded from the alternator. So, when your truck is running, I BELIEVE your alternator, more or less, takes over at that point while you are driving and the alternator is actually "supplying the power to your vehicle" as well as charging the battery and/or batteries (i.e. dual setup).
    MotoEd and ChadsPride like this.
  7. Aug 3, 2017 at 8:28 AM
    TPDTaco
    Brett
    Cypress,CA
    a better one def would not be the worst thing ever but if its currently working good i wont replace it
  8. Aug 3, 2017 at 8:35 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    A buddy of mine was having pretty much the exact same issue. His turned out to be a plugged fuel pump and fuel filter. Might want to look at the simple things. He replaced the fuel pump and fuel filter and it runs like a champ now.
  9. Aug 3, 2017 at 8:39 AM
    TPDTaco
    Brett
    Cypress,CA
    i thought the fuel filter was non serviceable?
    ChadsPride and MotoEd[QUOTED] like this.
  10. Aug 3, 2017 at 8:41 AM
    WileECoyote
    SoCal
    Yeah, I would be the same way right there!!! :thumbsup::fistbump: But, definitely look in on it though as far as start saving up money for a bigger one (i.e. IF you have all of that extra stuff). That way, you're not without a rig if/when the alt decides to dump on you!!! :notsure::ballchain::annoyed:
    But yeah, take your rig to some auto place to get a free alt check. :thumbsup: It would be a quick thing to do, at least rule that out real quick, and you can move on to the next item on the list that would possibly cause something like that. :thumbsup::fistbump: I'm obviously not saying that what I am suggesting is the number one cause, other than just something that could/would be easily ruled out AS A cause. :thumbsup::D:cheers:
    ODNAREM, ChadsPride and MotoEd like this.
  11. Aug 3, 2017 at 8:43 AM
    WileECoyote
    SoCal
    MAKES SENSE!!! :thumbsup::fistbump::cheers:
  12. Aug 3, 2017 at 8:44 AM
    TPDTaco
    Brett
    Cypress,CA
    that sounds nice and inexpensive :rofl:
    tcjacado, uhplifted, MotoEd and 2 others like this.
  13. Aug 3, 2017 at 8:44 AM
    WileECoyote
    SoCal
    :rofl::rofl::rofl:
  14. Aug 3, 2017 at 8:46 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Hopefully it in a good spot on the 4.0 it was a pain to change out on my truck. Side of the motor.
  15. Aug 3, 2017 at 8:48 AM
    MadTaco461
    CA
    Kinda stock
    Put some fuel cleaner in your tank first if you haven't done that yet.
  16. Aug 3, 2017 at 8:49 AM
    uhplifted
    Brian
    16 DCLB OR
    My Rodeo in Hawaii had the fuel pump/regulator shit out on me. Same problems He is having sort of. Then one day the damn thing wouldn't turn on.
  17. Aug 3, 2017 at 8:49 AM
    TPDTaco
    Brett
    Cypress,CA
    would you use fuel cleaner or seafoam or octane booster?
  18. Aug 3, 2017 at 8:50 AM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
  19. Aug 3, 2017 at 8:51 AM
    TPDTaco
    Brett
    Cypress,CA
  20. Aug 3, 2017 at 8:51 AM
    WileECoyote
    SoCal
    ODNAREM, MotoEd and ChadsPride like this.
