Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Dec 11, 2017 at 7:09 AM
    Jimmyboyblue
    Jimmyboyblue Well-Known Member
    Jimmy
    Baja California
  2. Dec 11, 2017 at 7:29 AM
    Jimmyboyblue
    Jimmy
    Baja California
    Yea but my guess is they will be here sooner than later
  3. Dec 11, 2017 at 9:19 AM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Thank you for the information. I am not sure how far back you moved it, but why not make two different mounting hole options on your hangers? This way people could choose what they would like to do in regards to the rearward relocation of the hanger. This could increase business with those who are skeptical, and allow people to make changes if they change other parts of their rear suspension system. We can all agree the stock hangers are flimsy and swapping it out with a more beefy one will benefit the truck.
    Whether or not moving the shackle rearward would be beneficial seems that it would vary depending on each persons particular rear suspension setup. Im not saying trying to say which product is better, I just think people should do research and try to understand the differences and try to figure out what would work best for their setup. In my particular case, with a shock relocation, Dakars (designed for stock mounting points) and 12" kings, the stock shackle does not limit my droop, nor my bump travel. The stock hanger allows the springs, and shock to achieve a full range of motion. Therefor I would not see a reason to move the pivot point of the shackle.
    I would have to cycle the suspension to be sure, but in my particular setup if the hanger was moved rearward, and I did not purchase your optional longer shackle, It seems like I would loose droop due to the spring-shackle pivot location being moved rearward. The springs would not be allowed to arch as much and would be required to be flatter to span the longer distance. The springs would also be even more inverted at full bump due to the hangers being longer, but the shackle being stock length.
    desertjunkie760 and eccracer104 like this.
  4. Dec 11, 2017 at 9:22 AM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Yeah I like the LCE design more. I would've gone with them but their 3.0 headers aren't CA smog legal and I do want to be street legal. Otherwise they look virtually the same. Maybe easier y pipe set up
    For yours, the LCE ones are definitely better. They're long tubes which put out more power. You won't see huge gains on a stock engine but if you continue to add to it the LCEs will definitely have more gains. They talk abou it a little bit in this video.
    https://youtu.be/Y7_lSU3D0jw
    Plus it says you don't have to worry about any dipsticks if you have a manual. Sounds like its time for a 5 speed swap :boink:
    WileECoyote[QUOTED] likes this.
  5. Dec 11, 2017 at 9:36 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Remember that I have to design something to work with every aftermarket spring out there. That said, there is no benefit of stock location over where I choose to put it vs stock hangers, even with Dakars. You are correct, the shorter Dakars can droop out with stock shackle laid out to about 5 degrees above horizontal in stock hanger. My HH can let the shackle hit about 15 degrees below horizontal, putting rear of spring about 2" lower (1" at the axle) making up for pulling the Dakars back a bit, but also resulting in less fanning out of leaves in the Dakar pack. You are also correct that the Dakars can benefit from a longer shackle with my hangers, like the 1st gen Tundra shackles, or maybe my 4.9" shackles will be good, not tested yet with Dakars.
    Even you will gain droop with stock shackles if you aren't currently shock limited. If you want to discuss over the phone, I'd be happy to.
    Thanks for bringing up a valid point, and believe me I took that into account, but I wasn't about to pigeon hole my design for 1 spring on the market. My preproduction design had 2 locations, but it felt complicated, so I went to 1 position.
  6. Dec 11, 2017 at 1:12 PM
    Jimmyboyblue
    Jimmy
    Baja California
    Seems like a good price if they work but not to sure
    uhplifted likes this.
  7. Dec 11, 2017 at 1:26 PM
    Nicklovin
    Nicklovin [OP] Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Costs a lot more than that new that's for sure. See if everything works out well, kc specific replacement parts can be expensive.
    For example, the cost for me to get 2 replacement housings for my old setup is more than the price of buying everything brand new
  8. Dec 11, 2017 at 1:27 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    16 DCLB OR
    Almost want them to put around my bed bars for camp lights
  9. Dec 11, 2017 at 1:28 PM
    Jimmyboyblue
    Jimmy
    Baja California
    I don’t need more lights I figured for that price someone could use it
    Nicklovin[QUOTED][OP] likes this.
  10. Dec 11, 2017 at 1:29 PM
    Jimmyboyblue
    Jimmy
    Baja California
    Hit them up don’t hurt to check them out. It’s a steal if they do work
  11. Dec 11, 2017 at 1:31 PM
    uhplifted
    Brian
    16 DCLB OR
    I've got better things to spend 200 bucks on than lights. That's like 1/6 the cost of a bumper. I don't think they'd even fit on my bars with my current setup. Good deal for sure but I've got no real use for lights. Only light I want to buy right now is a single amber
  12. Dec 11, 2017 at 1:33 PM
    Jimmyboyblue
    Jimmy
    Baja California
    Yea I need to get a trail light too even though I don’t hit the trails
  13. Dec 11, 2017 at 1:43 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Didn't take many pictures other than my truck lol but here's a couple of our group Sunday on our way out.
    sdsurfer, TXpro4X4, Dalandser and 8 others like this.
  14. Dec 11, 2017 at 1:51 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    We didn't check out the mine, wanted to get to camp with some daylight left.
    Aside from the shooting area at the entrance of Berdoo which is all tagged up, we didn't see anything. Not sure where it happened, but most likely a mine trail.
    BandanaBerg and dtaco06[QUOTED] like this.
  15. Dec 11, 2017 at 2:51 PM
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    eccracer104 likes this.
  16. Dec 11, 2017 at 2:51 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    the banger made it out there. very nice.
  17. Dec 11, 2017 at 3:03 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Someone had to supervise the fire :rofl:
  18. Dec 11, 2017 at 3:07 PM
    MadTaco461
    CA
    Kinda stock
    Classic. I love it.
  19. Dec 11, 2017 at 6:54 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    If you guys want to come down this weekend sometime I can take you over to a spot and we can look at Christmas lights! We try to this weekend of the year for lights
    BLKTRUCK[QUOTED] and dtaco06 like this.
  20. Dec 11, 2017 at 7:29 PM
    4WALKER
    4WALKER Save the manual trans!!!
    1991 4runner 5 speed SR5 4X4
    Dirt
    Sleepy Hollow Christmas Lights Extravaganza
    23254 Robert Rd, Torrance, CA 90505
    https://goo.gl/maps/fn8vvgPGdeu
    South bay Xmas lights if you wanna travel. Worth it
    BLKTRUCK, madsand, tcjacado and 2 others like this.
