Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Jan 31, 2018 at 11:47 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Way to go Mike
    ODNAREM and eccracer104[QUOTED] like this.
  2. Jan 31, 2018 at 11:49 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Camburgs kit with heimed UCA, Fox coilovers.
    Coot83[QUOTED], dtaco06 and itaro like this.
  3. Jan 31, 2018 at 11:51 AM
    Oneluv13T4R
    Oneluv13T4R Cause I can wheel...better than you.
    Miah
    Long Beach/Desert Hot Springs,CA
    2003 Toyota 4Runner
    Wouldn't you like to know - Complete Garage Mod Edition
    BF2100EA-2ACD-4E45-A685-A73A899CF20B.jpg 21558BB8-6895-4F34-9AD1-A66AD3C5E058.jpg 002382D0-F01C-4A71-9781-4367A72BDC82.jpg
  4. Jan 31, 2018 at 11:52 AM
    Sterling_vH111
    Sterling
    socal
    Yeah :/ it’s my DD so during the week is practically impossible with school/work.
    itaro[QUOTED] likes this.
  5. Jan 31, 2018 at 11:59 AM
    Oneluv13T4R
    Miah
    2003 Toyota 4Runner
    I have a set ....
  6. Jan 31, 2018 at 12:00 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    2wd?
  7. Jan 31, 2018 at 12:01 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    ^^ :rofl:
    FIFY
  8. Jan 31, 2018 at 12:05 PM
    Oneluv13T4R
    Miah
    2003 Toyota 4Runner
    I have a garage, tools and the ability to make this happen for you...
  9. Jan 31, 2018 at 12:08 PM
    Sterling_vH111
    Sterling
    socal
    thank you, although I hope to get this done sooner, Ill let you know.
    yes 2wd prerunner
    that would be great! i am available all weekend after Saturday 11am. I could be in the long beach area by noonish.
    itaro likes this.
  10. Jan 31, 2018 at 12:11 PM
    Oneluv13T4R
    Miah
    2003 Toyota 4Runner
    Well that’s good...but Palm Springs is where I am
  11. Jan 31, 2018 at 12:11 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Don't think it would be too bad to accomplish as I have the TC equivalent.
    Have you ever taken off or installed LCAs, UCAs, coilovers, axles? You don't need to know how to do all of that as most of it is pretty simple with mostly one way to remove them.
    Items I would do ahead of time...
    • Bust out the instructions and lay out the part for confirmation of parts needed.
    • Verify with tools that all sockets, torque bar, breaker bar, two floor jacks(makes it easier), rope to help yank out CVs with (crowbar helps here too). I would get ahold of a grease gun or quality grease at a minimum for the bushings. The brake line wrenches in 10mm will also be needed so you don't strip your lines!
    • Spray liquid wrench or preferred penetrating oil on all bolts that will be removed unless you recently broke them open, ESPECIALLY on your brake lines and the LCA cam bolts! The more the oil sits the better it works so sooner than later, also spraying a few times on them through out the remainder of the week doesn't hurt.
    • Watch youtube on UCA install, coilover install, cv axle swap if not familiar
    • Buy replacement cam bolts from the dealership or from someone who has extras. Mine was a 2012 and half of them were seized, may not be the case in socal, but sucks to find out the hard way...about $130-200 depending on your source.
    • You will need a welder and a grinder to weld on the adjustable limit strap mounts.
    • If you havnt gotten the TC cam tabs, now is a good time to install if you have the truck torn apart.
    • Spare CVs and doing the axles ahead of time can alleviate a lot of time and struggle. I had mine done with an extra set of CVs I had planned to use as my spares, but of course the threads on both of my stock cvs were warped at the ends. If I didn't have spare CVs already extended out then I would have been fucked in my install. Many don't see this issue, but would suck to learn the hard way.
    • Expect the truck to be apart for a solid 10-20 hours depending on the skill involved.
    • LT coilovers have weld on resi brackets and also must be welded on. You can get away with zip ties in the interim though if needed.
    I would consider parking your ride as soon as you can on Friday and then trying to break open the bolts just to get them opened up. Don't need to wrench by yourself, but just knowing that nothing is seized is a good start. Im sure others will chime in with their thoughts.
  12. Jan 31, 2018 at 12:13 PM
    Sterling_vH111
    Sterling
    socal
    whoops haha just glanced at your profile, id gladly drive out there for this to happen.
    Maggot61, itaro and dtaco06 like this.
  13. Jan 31, 2018 at 12:17 PM
    Sterling_vH111
    Sterling
    socal
    Thank you, I can probably knock out most of this stuff in the remaining days. little less complicated as im 2wd, and have access to dealer parts at 50% off. Most all bolts have been touched fairly recently too.
    Coot83[QUOTED] and itaro like this.
  14. Jan 31, 2018 at 12:21 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Then update your location :smack:
  15. Jan 31, 2018 at 12:45 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    You don't have enough freedom credits. your vehicle exceeds maximum gross vehicle weight
  16. Jan 31, 2018 at 1:00 PM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    you in Indio?
    I just saw this a few minutes ago off 10fwy and Indian Ave (N. Palm Springs) :drool:20180131_124416.jpg 20180131_124407.jpg 20180131_124423.jpg
  17. Jan 31, 2018 at 1:34 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Congrats @4x4Banger !:woot::hattip:We All Look Foward To Seeing The Replacement In Your Arms.:D:cheers:D45DCE8D-7CEB-4001-988B-3C4DA6B75ED7.jpg
  18. Jan 31, 2018 at 1:46 PM
    kyle11863
    kyle11863 King of the BS
    Kyle
    Big Bear, CA
    1990 Toyota 4Runner SR5 V6 4x4
    Doug Thorley long tube headers and lots of mud
    Famous last words
    Ha I remember that day. Was fun. Charlie was very proud of his little dolphin. You didn't join us that day did you Ron?
    Congrats @4x4Banger!
  19. Jan 31, 2018 at 1:56 PM
    ODNAREM
    Ron
    :wave:
    You’re correct Kyle.I was in Arizona.
  20. Jan 31, 2018 at 5:12 PM
    BLKTRUCK
    BLKTRUCK Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
    Glazed Ham?
    Hammie?
