Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. May 28, 2018 at 2:03 PM
    bigbarlo
    bigbarlo The Church of @ODNAREM OC Chapter 80085
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    garbage
    Drainbung likes this.
  2. May 28, 2018 at 2:10 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Lol hater would be me saying “my 2wd can go anywhere your 4wd can go...aka back in the day tw bullshit :rofl:
    Now we’re all stuck on the no likey the “overlenders”
  3. May 28, 2018 at 2:40 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Edited my post :laugh:
    That’s a good one. Hopefully I’ll make the meet this thursday.
    itaro and dtaco06[QUOTED] like this.
  4. May 28, 2018 at 2:41 PM
    bigbarlo
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
  5. May 28, 2018 at 3:08 PM
    bigbarlo
    Chan
    Laguna Beach
    06 AC OR PR/96 FJ80
    Fiddy more for that.
    dtaco06 and itaro[QUOTED] like this.
  6. May 28, 2018 at 3:12 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    when I first saw a skottle I was thinking that's pretty cool. until I visited the website for more details and saw the price..
  7. May 28, 2018 at 3:19 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    For reals that’s ridiculous...:facepalm:
    Same. It sucks. They’re at least making 70% profit
    itaro[QUOTED] likes this.
  8. May 28, 2018 at 3:38 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Same, I actually used one this weekend. Great idea. Idea for trips and little space needed but that price tag!!!
  9. May 28, 2018 at 7:08 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Lol I put a skillet on my Coleman burner for a lot cheaper,lol
  10. May 28, 2018 at 7:19 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    :spy:
    @MonkeyProof Got a couple questions I'm hoping you can help me out with....
    1. Do you have any photos of where you put the large triangle and the Medium triangle on the back LCA mount? I think from your photos I figured out where the big one goes(I'm gonna have to modify mine to fit well), but for the fuck of me I can't figure out where the medium sized triangle goes.
    2. How many miles have your poly LCA bushings been lasting? Brand new mine weren't exactly tight in there, but I'm going to end up replacing every fucking wear item on the front end anyway, I'm thinking about just replacing the bushings too even though they aren't too sloppy. Mine have around 16000mi on them.
    3. It looked like in your photos you welded the inside of the mounts, any concerns about hardening that area too much and cracking the frame now?
    EDIT: figured out where the medium triangle goes.
  11. May 28, 2018 at 7:38 PM
    oni06
    oni06 Well-Known Member
    Finally home. International flights are exhausting
  12. May 28, 2018 at 8:31 PM
    85straight
    85straight Mall-Rated
    Al
    Menifee,Ca
    1985 4runner
    As we were leaving the other group was trying to coax him out of that rock and back into the bush
    dtaco06[QUOTED] likes this.
  13. May 28, 2018 at 8:41 PM
    85straight
    Al
    Menifee,Ca
    1985 4runner
    No the family of like 6
  14. May 28, 2018 at 9:16 PM
    Ackrite
    Ackrite Well-Known Member
    SoCal
    1985 Toyota Pickup 4x4 single cab
    And that, right there, is the main reason I try to be covered head to toe anytime I am spending time outdoors. Rain, shine, snow, brutal cold, or extreme heat. Always pants and cowboy style slip-on boots to at least give me some protection half way up my shin in case of a bite from a snake I did not see and step on.
  15. May 28, 2018 at 10:05 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    ^^^this that’s how one of my lowers was recently so I changed them out ASAP and I also did swap the LCA bushings too
    They where pretty bad, had about 55k+ on them
    tetten[QUOTED] likes this.
  16. May 29, 2018 at 8:26 AM
    MonkeyProof
    SoCal- SGV
    Only I can have a coilover leak after a fresh recharge. At first I thought maybe it was from the schrader valve being stuck. Nope, it the fitting at the reservoir. There was a large puddle on the ground all dripping off of the subframe..
  17. May 29, 2018 at 8:47 AM
    MonkeyProof
    SoCal- SGV
    My Upper bushings are still original and still tight, been nearly 9 years now, weird. The upper uniball gets replaced yearly.
    My lower bushings last approx 2 years, same with the lower uni-balls. I grease them once a month which I think helps. I Think also alignment can prematurely wear out a bushing depending on how the cams are adjusted the each other.
    Which brings me to this point, years ago I couldn't get alignment numbers anywhere close to what I wanted them to be at, I wonder why :facepalm:
    oni06, Coot83, dtaco06 and 1 other person like this.
  18. May 29, 2018 at 9:06 AM
    tetten
    Andy
    Socal
    :rofl:
    Yeah, I found more shit fucked up than I bargained for while stripping the front for the LCA mount gussets....
    Both LCA uniballs are fucked
    Both LCA uniball bolts are bent
    Passenger LCA spindle/uniball adapter got loose and wallowed itself a little and fucked up the uniball cup
    Passenger LCA misalignment broke off in the spindle adapter
    Passenger UCA uniball is loose enough that I can't tell if it has play or not, so I guess its safer to just replace now
    LCA bushings aren't bad, but have a tiny bit of play
    Driver Side spindle gusset has a crack (already knew about)
    Passenger Side spindle gusset has a crack
    Driver side LCA mount welds started to crack again after the initial half-assed fix I did last year
    There is a weird .080" discrepancy between the steering lobes on the spindles, I knew about this since last year, but don't know if it got bent some how or it was forged that way.
    madsand and itaro like this.
  19. May 29, 2018 at 9:12 AM
    MonkeyProof
    SoCal- SGV
    And everyone kept saying that an embedded Uni-ball into the LCA is better than a Uni-Ball adapter version lmao.
    Just glad I'm not the only one with a POS :headbang:
    oni06, tetten[QUOTED] and itaro like this.
  20. May 29, 2018 at 9:14 AM
    MonkeyProof
    SoCal- SGV
    you should see the $120.00 ea. bolts that bend on the TT
