Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Oct 22, 2018 at 3:45 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    haha nope, but I'll have to watch that tonight
    TXpro4X4[QUOTED] likes this.
  2. Oct 22, 2018 at 4:34 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    It's how I found that sauce
    eccracer104[QUOTED] likes this.
  3. Oct 23, 2018 at 6:03 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Asking here since this is probably the most active thread with actual knowledgable member:
    Anyone know how to tell if a steering rack is going bad? I have a noise I'm trying to diagnose and am really hoping it's not the rack. 2015 with 57k miles on it- could it be covered under warranty if so?.
  4. Oct 23, 2018 at 6:27 PM
    GHOST SHIP
    GHOST
    Which is why I'm concerned. There's a bit of an almost grinding type noise while rolling - only noticeable at slow speeds. Also a clunk when turning the wheels left to right in short strokes. Almost like something is unloading and/or making contact in either direction. Visually, everything looks tip-top. No leaks, no tears in the boots, no rust/damage. Cant figure it out. Just did a complete rebuild on my suspension so everything is pretty much brand new up front. Rechecked torque on every fastener that I touched and got 2 alignments 2 weeks apart after install thinking that might cure the symptom.
  5. Oct 23, 2018 at 6:38 PM
    GHOST SHIP
    GHOST
    The steering is a little stiff but I just replaced the uniballs. I even though that one of the uniballs might have been fucked but that wouldn't explain the rolling resistance.
    WileECoyote likes this.
  6. Oct 23, 2018 at 6:47 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    You check the tie rods? I've had them seize up on my even when the boots where good.
    What's the last change you made to the front end?
  7. Oct 23, 2018 at 7:00 PM
    GHOST SHIP
    GHOST
    Complete rebuild which is kind of why I'm at a loss because everything's been touched. Rebuilt coilovers with new coils (14"/700lbs), TC Cam tab gussets, rebuild UCAs (bushings, uniballs), removed swaybar. I've checked and recheck torque on all fasteners. Aside from getting the alignment, I didn't touch the tie rods. A quick touch o' the wrench and they felt snug but I trust my alignment shop so I didn't check full torque or put too much effort into it.
    Another possibility:
    Is there any way for the CV to pull out of the front diff accidentally enough to cause the noise? When I was changing the UCA, I dropped the spindle (which I left unsupported-rookie move) and noticed that the CV boots were at a severe angle. Everything buttoned back up no problem and looked fine after install so I didn't think about it furhter. 4H still engages fine but does not affect the noise at all.
    So if it can pull out, can it be pushed back in?
    Drainbung likes this.
  8. Oct 23, 2018 at 8:00 PM
    GHOST SHIP
    GHOST
    Thanks. Still gotta figure this damn noise out. Just hoping it’s not an announcement of catastrophic failure on its way.
    WileECoyote and Drainbung like this.
  9. Oct 23, 2018 at 8:54 PM
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    I know this maybe a stupid thought, but did you check out your front brakes? Not tooooo sure about a 2nd Gen, but look at the brake pads and how they are secured as well as the whole brake assy itself. Maybe check out the steering knuckle as well? :notsure:
    Coot83 likes this.
  10. Oct 23, 2018 at 9:06 PM
    GHOST SHIP
    GHOST
    Brakes are fine. It’s definitely a rolling noise.
    I’ll probably disassemble and reasses and reinstall this weekend. I’ve isolated it so far to the passenger side.
    dtaco06 and WileECoyote[QUOTED] like this.
  11. Oct 23, 2018 at 9:15 PM
    WileECoyote
    SoCal
    Okay.
    I only say the brakes because on the 1st Gen there is a retainer "spring" sorta deal. Also, I've never had a "hung caliper", but was wondering if that was a possible cause? If it's a rolling/grinding I was just figuring possibly a brake assy issue somehow?
    Hope you figure it out brotha!!! :thumbsup::fistbump:
  12. Oct 24, 2018 at 6:00 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Wheel bearing would be high on my list, I would suggest on removing the wheel and rotor in order to rotate the hub assembly by hand..
    GHOST SHIP[QUOTED] and Coot83 like this.
  13. Oct 24, 2018 at 7:29 AM
    GHOST SHIP
    GHOST
    Thanks. I’ll take a look this weekend. Got another alignment yesterday and it seemed to cure the noise but I’ll still take a look just in case something else is going on.
    WileECoyote, Drainbung and dtaco06 like this.
  14. Oct 24, 2018 at 10:19 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Man I've always liked Terry Crews, seeing something like this just makes my day!
    I've gotten weird stuff like this from tierods pulling in and out of the rack.. also, every now and then my CVs will start clunking and popping and making noises at me but it disappears quickly enough and then doesn't come back for ages.
    Checking brake dust covers is a good suggestion, although that would be more of a screech or rattly whine.
    I once had a brake caliper bolt back out and the caliper was dangling off a single bolt, only took a couple of times using the brake to figure those noises out! *VEEEEER to the riiiightt!!!!*
    TXpro4X4[QUOTED] and WileECoyote like this.
  15. Oct 24, 2018 at 10:25 AM
    GHOST SHIP
    GHOST
    Thanks for the feedback! My best guess is more along the lines of the tie rods so I'll continue my search there. Got another alignment last night (which included reclocking the steering wheel) and it seemed to cure the noise. I have it narrowed down to the passenger's side so I'll be going over it again this weekend.
    Brakes are fine and it's not the dust cover (different noise).
  16. Oct 24, 2018 at 11:33 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    :wave:
    Good to see ya!
    Glad I could help out :hattip:
  17. Oct 24, 2018 at 11:39 AM
    WheelInTheSky
    G
    Jackson Hole
    :wave:soon to be.... :cheers:
    We're driving to the dealership to drop off my Mom's 3rd gen so they can figure out why the transfer case is leaking... So obviously we are walking to a mex joint to grab tacos then we'll go to a brewpub amd kill a fees hours until they call about the truck!:drunk::fistbump:
    TXpro4X4[QUOTED] and dtaco06 like this.
  18. Oct 24, 2018 at 12:07 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Mmmm beer.....
    :cheers:
    eccracer104 likes this.
  19. Oct 24, 2018 at 1:03 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    I could go for a beer right about now. Off site working so I’m stuck with water
  20. Oct 24, 2018 at 1:17 PM
    Maggot61
    Maggot61 Well-Known Member
    Jose
    Sky Valley, CA
    2005 Tacoma Prerunner 4.0L
    "If I'm gonna die, I'm gonna die historic on the fury road!"
    FIFY :thumbsup:
