Orange County CAF's: up to no good
Discussion in 'Southern California' started by Nicklovin, Apr 27, 2012.
  1. Jan 19, 2016 at 12:12 AM
    #8621
    Dangerousd1987
    Dangerousd1987 Member
    Dustin
    Long Beach, CA
    2011 Tacoma TRD Sport
    •Custom Satoshi Grill w/ backing Hella 500s •4" Maxtrac lift Bilstein 6112 SPC Light Racing UCAs ARB Old Man Emu Dakar Leafs Bilstein 5160s Earls Performance Extended Brake Lines 285/70/17 Cooper Discover STT 17" Raceline Rock Crushers •BAMF 80" Sliders
    Might be free. Friday's are usually better but might be able to swing Saturday.
  2. Jan 19, 2016 at 12:16 AM
    #8622
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    :thumbsup:
  3. Jan 19, 2016 at 3:50 AM
    #8623
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    Something to say/consider:
    I have a CB, HAM, and GMRS radio setups. The reasons:
    1) Not everyone has a HAM license. So...
    2) the next "best radio setup" is CB (Citizen Band)... some/most HAM's don't think so, but that is their opinion, which they're entitled to.
    3) GMRS (i.e. the ones that you can buy from the stores that say "36mi range" or something similar, which btw, technically, you need a license for those radios as well... I won't get into that part... just know and realize that technically you do need one but most people don't). Btw, do NOT be fooled that you will achieve 20, 24, 36, etc miles out of these units.
    A little bit about CB, the handhelds, from my TESTING/experiences typically output approx 2 Watts, whereas the mobiles will output the maximum 4 Watts or very close to it. I TESTED my Midland 75-822 HT with a GenDyn R2670B System Analyzer at just under 2 Watts. When I measured the mobile, it was approx 4 Watts (i.e. max output power for the CB bands, period). Thus, the handhelds do not seem to output the max power, probably because to save battery power? Anyways, something to think about as far as output power, at least from my TESTING. Also, as far as CB "range", me and a friend estimated about 6mi (i.e. this was not really line of sight either, so distance could have been greater maybe if it was line of sight, but, most likely, not by much...). He was driving north with a 3ft mag mount (NOTE: I don't necessarily care for mag mounts as they're not as good as an antenna that is actually mounted... from my experiences with radio systems, whether car or otherwise) and I was driving south with my setup on the truck utilizing a 4ft whip connected to a Cobra 19 UltraIII mobile.
    A little about HAM, when you get your license, it opens up a very wide range of possibilities. You can do radio-to-radio, connect to repeaters, the web, etc etc etc and "skip", when weather favors (NOTE: skip can be done with CB as well when weather favors it). I have NOT personally talked to people "out of state" on my setup, but during Field Day, one time I was invited to do calls/contacts and contacted a person in Arizona, not too far, but far enough for my first-hand experiences. Anyways, a HAM license is an overall better way to go, but it doesn't hurt to have some sort of "back-up" mechanism and keeping in mind that not everyone has a CB and it is illegal to "cross talk" from 10Meter (HAM) to 11Meter (CB) and viceversa. So, as far as legal aspects, don't do it! Also, for HAM you can output more wattage (i.e. 1500Watts, I'd have to review that part, but I believe it is right around that) whereas CB, it is only 4Watts output, this I do know. CB'rs will use RF Amps to increase this output, but it is highly illegal to do!!!
    A little about GMRS, from my understanding, the license is a few dollars for about 5yrs. It's a voluntary (i.e. honest system) mail process. You pay the money and then they mail you your call sign. At least that is how I remember reading it. Plus, you can use those radios, but just stay off of the channels that the GMRS freq are on (i.e. I believe ch1-8 are some, 9 to ? are "open" for casual use, my understanding). Anyways, at this point, I don't even think it is really enforced anymore and/or at all to do, but there are definitely people out there that get wound up if using channels and you're not "properly licensed and/or calling out your call sign" as I have personally experienced one time?! I just ignored it and went on to the next channel when I was TESTING my new radios, at the time, which are Midland GXT-800. For me, kinda hard to say/tell if it is illegal if it is not really enforced???!!! I don't use them that much, and when I do, I stay off of the channels that are "assigned" when traveling with friends family from car-to-car communications when going on fairly long trips that will last an hour or more and/or just to keep in contact with the next car for whatever reason.
    So, in conclusion, having the setup that I have, gives me a certain amount of options to me when traveling! If someone doesn't have a HAM license, no problem, go to CB. If they don't have HAM/CB, no problem, give them a GMRS radio.
    Cell phones... I basically don't TRUST them because it really is true, if a incident strikes, cell towers are "jammed" to the point of uselessness. Hence, the reason why I have the other options availble to me. I just don't care and/or trust my life all that much in cell phones when/if a natural disaster was to hit. That is just me though!!!
    Anyways, hope this helps some people out there. These are my experiences and what I have learned thus far over the years.
    BTW, the "rubber duckies" that come with the handhelds, whether CB or HAM, DITCH THEM!!! Get aftermarket antennas. The original ones that come from the factory SUCK!!! Trust me on that!!!
    Happy Wheel'n
  4. Jan 19, 2016 at 6:01 AM
    #8624
    BLKTRUCK
    BLKTRUCK Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
    Thanks for the explanation. Are the GMRS the walkie talkies the ones everyone uses at Disneyland?
    I would say get a ham license, and use a ham.
  5. Jan 19, 2016 at 6:17 AM
    #8625
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Im to cheap. Run what i got, its not like we use to save lives. I use to talk shit when most people are less than 100yrds away.
    Thanks for the knowledge though.
  6. Jan 19, 2016 at 6:37 AM
    #8626
    HBGIBBY
    HBGIBBY Well-Known Member
    Ian
    Huntington Beach CA
    2011 DCLB 4x4
    No Mods Yet
    @WileECoyote , do you have a VSWR meter and can you help me tune my Firestick antenna some time?
    :D
  7. Jan 19, 2016 at 7:22 AM
    #8627
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    I have no clue about CB, Ham radio... Do they have class that they offer?
  8. Jan 19, 2016 at 8:07 AM
    #8628
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    When and where?
  9. Jan 19, 2016 at 8:13 AM
    #8629
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    I'm free Saturday morning... I'll can do holy Jim since it's not that far...
  10. Jan 19, 2016 at 8:31 AM
    #8630
    Notaco85
    Notaco85 Member
    Long Beach, CA
    1985 Toyota 4x4
    E Locker Rear, BudBuilt Tummy Tuck Skidplate, ARB OME Leafs, Rock Sliders, AllPro Rear Bumper, 1990 Front Clip, ARB Snorkel, ARB Awning
    Never been to Holy Jim. What kind of wheeling is it? Saturday morning would be ideal...
  11. Jan 19, 2016 at 8:33 AM
    #8631
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    Imagine a normal road but with a bunch of potholes. Then throw in some trash dirt and you've got Holy Jim. It is nothing magical.
    Edit: Screw you Autocorrect...
    monkey4x4, MostEpic, ODNAREM and 2 others like this.
  12. Jan 19, 2016 at 9:23 AM
    #8632
    spacecat
    spacecat Well-Known Member
    Lauren
    So Cal
    03 White 3.4L V6
    Personally would hit up anywhere but Holy Jim, if you're lookin to do some decent wheelin
    Its pretty torn up there right now.
    Pothole city.
  13. Jan 19, 2016 at 9:30 AM
    #8633
    Nicklovin
    Nicklovin [OP] Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Awesome
    Wow that quote was wayyyyyyyyyyyy back. Anyways thanks for the info, I may get the HAM setup @Dangerousd1987 has and get a license after this semester
    I'd be down to do Saturday morning depending on when it rains, gotta redirty the 4Banger since Toyota just washed it
    It's pretty moderate, there are some areas where you can challenge yourself a little bit. A way to think of it, sometimes cars go back there to reach the hiking trails, although they go really slow. Lots of potholes thanks to rain and after it rains a good amount there's always some mud bogs! Also can't wait to see your truck :thumbsup:
    Currently it's graded for about a minute of driving past the bridge, although in the future they plan of paving the whole area..... but with the economy that'll probably be a while.
  14. Jan 19, 2016 at 9:31 AM
    #8634
    Nicklovin
    Nick
    Tacoless
    Yapp it's pot hole city right in the front mostly, know any other areas we could all hit?
  15. Jan 19, 2016 at 9:32 AM
    #8635
    YotaGurlIAm
    YotaGurlIAm Well-Known Member
    Madison
    Arizona
    2008 4.7L - wait..I’m on the wrong forum.
    Stuff n' Thangs
    I wanna go...:pout:
  16. Jan 19, 2016 at 9:36 AM
    #8636
    Notaco85
    Notaco85 Member
    Long Beach, CA
    1985 Toyota 4x4
    Johnson Valley isn't too far, but an all day affair...
  17. Jan 19, 2016 at 9:36 AM
    #8637
    Nicklovin
    Nick
    Tacoless
    We all wish you could too :fistbump:. One of us can facetime you while we're on the trails :D
    YotaGurlIAm[QUOTED] likes this.
  18. Jan 19, 2016 at 9:40 AM
    #8638
    Nicklovin
    Nick
    Tacoless
    Definitely looks interesting
  19. Jan 19, 2016 at 10:31 AM
    #8639
    4x4Banger
    4x4Banger Gold Member
    Ham
    Los Angeles
    2012 DCSB/OR 4x4
  20. Jan 19, 2016 at 10:40 AM
    #8640
    ODNAREM
    Ron
    Thanks for the explanation and further knowledge!:thumbsup:
