Orange/yellow Sludge in Oil Fill Stem and Cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJC84, Mar 16, 2023.
  1. Mar 17, 2023 at 2:34 PM
    tacoma_n8
    tacoma_n8 Well-Known Member
    looks dirty, i'd flush it. just get your garden hose and flush it out /S
  2. Mar 17, 2023 at 7:25 PM
    911monty
    911monty Active Member
    Monty
    07 Tacoma TRD Sport
    When I picked my new to me 07, the oil cap had the white shake on it. PO lived in Morro Bay and drove it all of 2 miles to work and back home. Never got up to proper temp. Poor thing.
  3. Mar 17, 2023 at 11:12 PM
    AJC84
    AJC84 [OP] Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    Moved to RI from SC 3 months ago. Never had this issue in SC, but was using the truck more and doing some highway driving. It’s been cold here in RI and wet and I’ve been sick for a month with Covid and a cold so all of my driving had been like 1 mile to grocery store, pharmacy or to family’s houses. So I’m thinking not enough use/high temp operation. Took truck to a St. Paddies gathering today 45 min run on highway and ran 4th gear. Hoping some highway operation solves my issue and will make sure to run it more and hard more often.
    wi_taco likes this.
  4. Mar 18, 2023 at 6:52 AM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    It's moisture,period. My truck does the same thing,with a 6mi drive to work. Wipe that crap out best you can then go drive on the highway for awhile.
    AJC84[OP] likes this.
  5. Mar 18, 2023 at 7:08 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Same as what everyone else is saying... On my old '07 that had about 60K miles on it and my commute was 3 miles. It only made it to highway speeds probably once a week and I had the same build up. Lived in PNW weather, garage kept. Meticulously maintained with Mobil 1. It was alarming at first, but I started running it a little longer and would at least let it heat up to operating temp. I would clean out the gunk with a q tip. I did one round trip of about 1500 miles after a fresh oil change and didn't have any gunk. Still not thrilled about it, but it's probably okay.
  6. Mar 18, 2023 at 10:54 AM
    AJC84
    Andy
    Where did you get the PCV valve? I had looked into it a while ago and Toyota wanted a lot for it if I remember. If I can get the part number I’m sure I can get it on Amazon or somewhere else for a better price.
  7. Mar 18, 2023 at 11:01 AM
    AJC84
    Andy
    Update. Did a 45 min highway run in 4th last night and the sludge has not returned. Will continue to monitor it and drive truck more to get it to temp.
  8. Mar 18, 2023 at 11:46 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  9. Mar 18, 2023 at 4:37 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    eBay has OEM. Got mine last summer
    AJC84[QUOTED][OP] likes this.
  10. Mar 18, 2023 at 8:59 PM
    Waasheem
    Waasheem
    2007 xrunner
    Mine rarely gets driven during the weekdays and on weekends it’s mostly short trips.
    To help combat the problem. After driving away from a morning cold start after a couple minutes to get a little temperature in the engine. Then I’ll just leave it in a lower gear to bring the rpm’s up higher. I usually do somewhere around 60-120 seconds. If I don’t do that I end up with what you’re seeing. After I started doing it, I haven’t seen it again.
    Agreed. I think I paid about $6. Your dealer is trying to pull a fast one.
    Short trips not getting it up to operating temperature is more abusive than most know. I’ve seen many crank and cam position sensors fail from the moisture.
    AJC84[OP] and wi_taco[QUOTED] like this.
  11. Mar 19, 2023 at 5:24 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well it seems everyone has this problem must be a lot of blown head gaskets etc. Wonder why no one has mention catch cans? Drive more worry less. Mine has done this from new 160K miles ago.
    robm7 likes this.
  12. Mar 19, 2023 at 6:06 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Have had my truck going on 16 years... never had this happen. Do a lot of short trips where truck never gets up to operating temperature. I live in a dry environment though... not much humidity. :notsure:
  13. Mar 19, 2023 at 6:08 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Forbidden peanut butter
    AJC84[OP] and tak1313 like this.
  14. Mar 23, 2023 at 8:32 PM
    AJC84
    Andy
    Been ripping it on the highway and did an oil change and changed PCV and all seems well now. PCV may have been contributing it was pretty gummed up didn’t have as much rattle as the new one I installed. No more truffle butter in oil fill
  15. Mar 24, 2023 at 1:09 PM
    #35
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Next oil change send sample of your oil to Blackstone Labs. It will will give you an idea of your engine condition.
  16. Jun 12, 2023 at 5:47 AM
    #36
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Seen the same thing but only during the winter. With the long plastic oil filler tube the area near and including the cap never gets hot and as mentioned moisture can condense. Come spring/summer/fall and above zero temps and its never there.
  17. Jun 12, 2023 at 5:58 AM
    #37
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    He definitely has something other than too many short trips. A little build up can be attributed to that but what he has is excessive.
  18. Jun 12, 2023 at 6:01 AM
    #38
    babylon5
    David
    Agreed. I only see a little of the stuff inside the oil filler cap. That I consider normal. His is indeed way beyond that.
    $yoda$[QUOTED] likes this.
  19. Jun 12, 2023 at 7:14 AM
    #39
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    do the combustion test for head gasket...hope it is not,,
  20. Jun 12, 2023 at 8:53 AM
    #40
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    When it's happened to me it's been a white creamy color, not yellowish.
