Orange/yellow Sludge in Oil Fill Stem and Cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJC84, Mar 16, 2023.
  1. Jun 12, 2023 at 9:51 AM
    #41
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I don’t know what he has going on so without testing no point in making guesses. Just saying that much goop in there is not normal and he has something going on. If I was in his shoes I would definitely be checking some things out.
    TartanEagle likes this.
  2. Jun 13, 2023 at 5:51 AM
    #42
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    That's just due to his flavor preference. Regular vs french vanilla :bananadance:
    Fireball 00 likes this.
  3. Jun 13, 2023 at 7:52 AM
    #43
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If that goop is coolant and not moisture then the coolant level would be steadily going down. If the coolant level is always full it's not a blown headgasket
  4. Jun 13, 2023 at 8:05 AM
    #44
    Fireball 00
    Fireball 00 Mountain air is the bomb, where’s my wax?
    Ga
    2023 V6 4x4 Db cab celi-silver taco, 00 taco 2.7 4wd auto (aka.rusty-taco..R.I.P), 03 2.7 auto prerunner project!
    I had a LS1 Camaro that did this ... on the F-body cars apparently some are notorious for its oil consumption/buildup of condensation from short trips around and so on. So I gathered it’s like it’s sweating inside the tube and buildup from a reaction of positive crankcase venting issues with nowhere to go but up the tube and stop I guess ...oil was clear as a bell, pressure was great but it did this somewhat and the the fix for the ls1’s was a catch can canister off the side of the intake but sir that looks more rougher then what I dealt with I agree with the above u might have something sinister possibly starting ....I hope not let us know what u turn up....:fingerscrossed:
  5. Jun 13, 2023 at 8:32 AM
    #45
    Tacopycho
    Tacopycho Well-Known Member
    2021 Toyota Tacoma Off Road
    None
    IMHO, I wouldn’t put anything in an engine except engine oil.
  6. Jun 13, 2023 at 9:32 AM
    #46
    babylon5
    David
    I think someone already mentioned this ... Bad pcv valve ???
  7. Aug 23, 2024 at 3:45 AM
    #47
    garyods
    garyods Member
    Roseville CA
    05 DC SB SR5 4X4
    air bags rear
    I have a 05, it's been doing that since the second year. For me it happens during the winter (wet) months with short trips and clears up by itself during the summer and with longer highway trips.
    Ricardo13x likes this.
  8. Aug 23, 2024 at 5:04 AM
    #48
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Drive more worry less, very common and zero effect on any thing.
  9. Aug 23, 2024 at 6:55 AM
    #49
    babylon5
    David
    See that same yellow buildup during the winter. Not nearly that much and almost all in the cap itself. With the long plastic oil filler tube there is no heat making its way up to the filler cap.
    Summer never any buildup.. I would expect if its head gasket etc it would be there no matter the season.
    maineah likes this.
  10. Aug 23, 2024 at 10:42 AM
    #50
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well if it's the head gasket on mine it blew out about 150,000 miles ago. Maybe I should look into replacing it before it does any more damage?
  11. Aug 23, 2024 at 5:12 PM
    #51
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I have a take home car for work, so I drive my Tacoma on very short drives. I’ve never experienced that gunk, but I think that’s because I use synthetic oil as Bishop84 stated. I got a Blackstone oil report done and it seems as though a trace amount of gas is making its way into the oil. All was good, but that’s due to the short drives and the engine not getting hot enough where the gas is burned off and the piston rings don’t yet expand and prevent the gas getting into the oil.
  12. Aug 23, 2024 at 6:49 PM
    #52
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Where do you live? In the rust belt, it's common whether you use synthetic or not. I use synthetic all the time and I've had the problem, especially on the two or three-mile trips. When I know this is going to happen I try and get my vehicles out on longer runs at least once a week to make sure it gets to operating temps.
    Micbt25[QUOTED] likes this.
  13. Aug 24, 2024 at 1:04 AM
    #53
    mtntacoVA
    mtntacoVA Member
    13 Taco, 24 4Runner
    This happened to me when I first bought my 2013 taco used with 20k miles. Significantly less than that pic tho. Did the first oil changed after buying it and it freaked me the f’k out. It was during winter/ decently cold for VA (snow on the ground).
    haven’t had any issue with it in the 9 years since - figured it was just condensation from whatever fuckery the sale manager did (he was using the truck as a hunting truck before I bought it - found a slug wedged between the seats/ hvac definitely smelled like deer attractant (deer piss))/ whatever dollar general quality oil that pre-owned dealership was using.
  14. Aug 24, 2024 at 8:25 AM
    #54
    Micbt25
    TM
    i live in south Jersey, surprisingly I haven’t gotten it yet, seeing that I make a lot of shot trips and it can get cold in the winter.
  15. Aug 25, 2024 at 6:25 AM
    #55
    babylon5
    David
    Mine was also way less than the photo. And only in the oil cap itself...
  16. Aug 25, 2024 at 6:57 AM
    #56
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    A catch can won't fix the problem, the same buildup will occur in the upper crankcase area catch can or not. A catch can doesn't really do anything except collect the small amount of oil that in mist form that typically gets mixed with the intake air flow. The catch can is a waste of $$ on a 4L and probably on the 4cyl also although I don't own one of those. The factory system for dealing with the oil mist works fine and has for the last 50 years in automotive engines.
  17. Aug 26, 2024 at 5:15 AM
    #57
    babylon5
    David
    As a test i would scrape off some of the goo and place on some tinfoil in the oven at around 200F. If you come back later and what remains is just oil its condensation.
    Micbt25 likes this.
  18. Aug 26, 2024 at 7:28 AM
    #58
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    That orange stuff comes from condensation at the oil filler tube (assuming no other major engine issues) I only get it at the winter oil change. I just changed the oil Saturday morning and the cap had no evidence of that stuff at all. I do a lot of short trips of less than a mile. Only 3/4 of a mile from my house to firehouse with many cold starts at night. I only use synthetic 5w-30 oil changed every 5k with Toyota filter. I put a piece of foil type self adhesive duct insulation around the filler tube at the end of last winter. I'll have to see if that helped at January '25 oil change.
