Ordered: ARB "Bull Bar" Bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AzogSS, Dec 22, 2010.
  1. Dec 22, 2010 at 8:50 AM
    AzogSS
    AzogSS [OP] Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    After doing some research, I decided to go with ARB's new style with the fog lights. Need to start looking at lifts for the front now, any suggestions on what is the best in the long run??
    Need Help with LIFT selection... please read below.
  2. Dec 22, 2010 at 8:51 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Congrats! I like the OME setup they offer. Are you going to run a winch on the bar?
  3. Dec 22, 2010 at 8:52 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    The ARB + Winch has been a great purchase. You will like it. I would suggest the 886 springs with the OME front struts.
  4. Dec 22, 2010 at 8:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All depends on the amount of lift you want. For a 3" lift, they all have their pros and cons. Example:
    Old Man Emu: Solid dependable lift, non adjustable, but you can add trim packers to account for extra weight of the driver side. Proven dependable.
    Bilstien 5100's. Can be adjusted off the truck, up to 2.5". Life time warranty against defects. Can be used with OEM springs, or aftermarket springs, and adjusted acccordingly.
    Coil over sets: Example Fox, King, Icon,
    fully adjustable and rebuildable. King is the most money, but (IMHO) the best.
    Icons have a digressive dampening, giving a more firm ride on the dtreet, but softer on larger hits.
  5. Dec 22, 2010 at 9:05 AM
    Dark Knight
    Jeff
    NC/SC
    best bang for your buck (IMO) -> Skyjacker Platinum adjustable coilovers. Made by Fox. Rebuildable. Mine have been great!
  6. Dec 22, 2010 at 9:13 AM
    AzogSS
    Andy
    Soda City, SC
    No plans on a winch at the moment. I had been checking out the OME setup, I want a couple inches of lift, don't want to have to buy new tires, as I just bought these BFG AT's in 265 75 on my FJ wheels (don't want them looking too small). Cost isn't that important, I don't halfway do anything. What is the point that that you need new control arms after lifting a 2nd gen??
  7. Dec 22, 2010 at 9:50 AM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
    I'm mounting my arb as we speak! Just waiting on my winch to get here...common UPS!
    You guys who have winches in this bumper-did you need to turn the gear box for proper fitment? the instructions say to turn it 72 degrees??? Also does anyone have suggestions on wiring the lights?
  8. Dec 22, 2010 at 9:55 AM
    Dark Knight
    Jeff
    NC/SC
    This is my install article The gear box is very easy to clock 72 degrees but do not lift it higher than needed to turn the housing.
  9. Dec 22, 2010 at 10:50 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    I'd go 5100's and set them at 1:75 there's your coule inches, I have this same setup on my truck with the relentless fab bumper, sits about dead level and you're only out $180 for the billys
  10. Dec 22, 2010 at 10:53 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    I used a relay and spliced my OR lights into my hi beams, they come on whenever my hi's are on
  11. Dec 22, 2010 at 11:02 AM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    5100s at 1.75" is pretty safe to get properly aligned. The caster is what seems most limiting due to the forward shift of the control arms. It seems that each truck is a little different, in my experience. Mine JUST makes it into alignment spec at 1.75", so would never make it at 2.5. I've heard of others who have made it in spec at 2.5. Mine is aligned, but very little caster, so the truck does wander more than OEM. Also, 1.75 levels just about right with the rear spring TSB. It might be a bit low though with the ARB and a winch. The 5100s also give a nice ride.
    I'm jealous--I'd love the ARB and winch--nice call.
  12. Dec 23, 2010 at 2:20 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I really love my toytec coil=over lift, they utilize bilstein 5100's
  13. Dec 23, 2010 at 5:13 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x2. Great ride quality.
  14. Dec 24, 2010 at 9:02 PM
    AzogSS
    Andy
    Soda City, SC
    Thanks for the input... here is what I am planning
    -TACOMA OME NitroCharger Sport Suspension Kit (TrdParts4u)- Heavy Duty
    -Toyotec 3 deg shims
    -Total Chaos Upper control arms.
    Opinions on quality and longevity?
  15. Dec 25, 2010 at 2:40 PM
    AzogSS
    Andy
    Soda City, SC
    Merry Christmas Bump.
  16. Dec 25, 2010 at 2:44 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    I have a ARB Bull Bumper as well and currently I'm running Toytec CO's cranked up to about 2.75" (maybe a little more) and with the weight of the bumper it sits at about 2.5" Front lift so it doesn't make the suspension sag and ton but enough to be noticable.
  17. Dec 25, 2010 at 6:11 PM
    AzogSS
    Andy
    Soda City, SC
    Thanks theduck911, do you know anyone running the setup I am looking at? It is around 2.75-3 inches of lift as well. Are you running UCA's?
  18. Dec 25, 2010 at 6:16 PM
    theduck911
    Max
    Locked and Geared!
    Yea, I'm running Light Racing UCA's and not that I know of or can think of right now
  19. Dec 25, 2010 at 6:19 PM
    2011TacoSport4x4
    Clyde
    Just a little update.
    I got everything mounted, wired and ready to go! It was a pretty easy install, and it looks awesome. I'm very happy with the bumper/winch combo and it lowered the front of my truck less than 1/4 inch with 885 coils. I will post some pics soon.
    Thanks everyone for all your input!
  20. Dec 28, 2010 at 11:11 PM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    Congrats on completing the project. Can't wait to see the pics!!!!!:D
