Ordered Stubbs Sliders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wlmuncy, May 16, 2010.
  1. May 16, 2010 at 7:35 PM
    wlmuncy
    wlmuncy [OP] Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I am need of pictures of the welding done to the truck to weld these on for a double cab. Also proper measure down from the cab to keep them from hitting doors and not interfering with normal cab flex.
    Thanks.
  2. May 17, 2010 at 7:44 AM
    wlmuncy
    William
    Knoxville, TN
    bump for weld pics.
  3. May 17, 2010 at 8:24 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    When mine were welded on my access cab, he just eyeballed one side, tacked them up, checked the doors, and measured out the other side so they were the same. I wasn't aware the placement had to be exact. He did have to take off some of the gusset furthest toward the cab to fit it correctly.
  4. May 17, 2010 at 5:59 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    I had mine installed a couple of weeks ago and as far as the DC is concerned, there is really only one way for them to be put on. When we laid under the truck and held them up, it became very clear that Richard has taken great care to engineer the plates so that they are precision fit. If you use the the rear gusset as a guide all the other plates fall into line perfectly.
    Hope this helps a bit, let me know if you have any other Q's.
  5. May 17, 2010 at 6:03 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Is that a scribe line on the inside of th weld bead on the left?
    I know it can't be a crack can it?????:confused:
  6. May 17, 2010 at 6:08 PM
    wlmuncy
    William
    Knoxville, TN
    Thanks man. What I was looking for.
  7. May 17, 2010 at 6:09 PM
    squad314
    Marc
    No sweat, glad to help.
  8. May 17, 2010 at 6:13 PM
    squad314
    Marc
    I know just what you mean.......When I saw the picture for the first time I thought WTF? It's the shadow of the outline of the scab plate, the angle doesn't allow you to see the bead behind it.
