Ordering wheels today, need help please
Discussion in 'Wheels & Tires' started by Daudio, Apr 1, 2011.
  1. Apr 1, 2011 at 10:29 AM
    Daudio
    Daudio [OP] Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    I have tires already, they are BFG all terrains 265/75/16. Excuse my ignorance but I don't know anything about wheels and tires. What I need to know is what rim will these tires fit on. I'm not sure if I need to go 16x7, 16x8 or if either one of those are possible. Here is the link to the wheels I am going to order. Any help would be appreciated, I don't wanna order the wrong ones.
    http://www.wheelsnext.com/wheels-rims/Black Rock-942D-Black Flat.html
  2. Apr 1, 2011 at 10:36 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    16x8, 6 on 5.5 bolt pattern and 4.5" backspacing, and you still might need to grind the backs of the rims for caliper clearance.
  3. Apr 1, 2011 at 10:40 AM
    Daudio
    North Jersey
    '02 SR5
    Thanks for the reply....I'd like to avoid having to grind anything if I can. Is there anything I can do to avoid that? thinner wheel? smaller backspacing?
  4. Apr 1, 2011 at 10:53 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    No, you will need to worry about backspacing if you plan on running 285s to clear the UCA.. Most 16s will fit, i know XDs will.
  5. Apr 1, 2011 at 10:55 AM
    Daudio
    North Jersey
    '02 SR5
    They're not 285's, they are 265's. Does that mean that I won't have any problems fitting them?
  6. Apr 1, 2011 at 10:57 AM
    krimson
    krimson Nothin
    TRD Off Road
    Kinda worded it wrong, (on a phone) You will only need to worry about BS if you plan on running 285s**** No you wont the 265/75/16s will be fine with any wheel.
  7. Apr 1, 2011 at 11:03 AM
    krimson
    krimson Nothin
    TRD Off Road
    Just a suggestion, look at the XD Hoss, i got them and love them. They're fairly inexpensive and look good plus they have a 4.5 BS, if you plan on running 285s down the road. Looking at the Tacomas on here with em will eventually change you're mind ;)
  8. Apr 1, 2011 at 11:17 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You won't have to worry about caliper clearance becuase you have a first-gen. Only 2nd gen's have caliper issues with 16" rims.
  9. Apr 1, 2011 at 4:09 PM
    Daudio
    North Jersey
    '02 SR5
    I am not as concerned with caliper clearance as I am about the tires fitting the wheels.
    Does anyone know 100% that the size tires I have will fit on the 16x8 wheels on the link I posted?
  10. Apr 1, 2011 at 4:11 PM
    Daudio
    North Jersey
    '02 SR5
    I will eventually run bigger tires. The plan is to get it paid off soon and turn it into a woods toy, I have a ton of trails right around where I live. But for now its a daily driver/work truck and I need it to be able to get onto the highway(4 cyl) and with a 285 I don't think that is going to happen quickly enough haha
  11. Apr 1, 2011 at 4:36 PM
    Daudio
    North Jersey
    '02 SR5
    can anyone tell 100% sure that my tires will fit those wheels?
  12. Apr 1, 2011 at 4:50 PM
    Daudio
    North Jersey
    '02 SR5
  13. Apr 1, 2011 at 4:58 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    265/75/16 would work on either a 7" or 8" wheel. I would recommend the 8" wide so you can have the option of getting wider tires in the future if you ever wanted to. I ran that tire size on a 8" wide and it was fine. And if you click that photo it'll bring up more pics when I was running that setup.
  14. Apr 2, 2011 at 10:35 AM
    Daudio
    North Jersey
    '02 SR5
    Thank you very much man!!! This is exactly what I was looking to hear. +rep for you.
