Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Mar 27, 2014 at 9:30 AM
    J88logue
    J88logue NorthWest Member
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Can someone with a 1st gen check their tow package tongue capacity and tow rating capacity.
    IDK but i checked mine this morning, the 1st gens are supposed to all be 5,000 and 500 tongue.
    Mine says
    5,000 & 500
    Then 2002 and newer 6,000 & 600.
    Not sure why i would have the capability to haul another 1k for being one year newer than a 2001...
  2. Mar 27, 2014 at 9:36 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Because 02s are gay.
  3. Mar 27, 2014 at 9:38 AM
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    go check yours nutsack!!! let's see how much weight you can haul ass clown
  4. Mar 27, 2014 at 9:41 AM
    Truck Girl
    Truck Girl Well-Known Member
    Jamisyn
    Arlington, Washington
    2012 DCLB 4x4 SR5
    wheels, tires, retrofits/bhlm, 5100's front an rear, Billet Grille, debadged, tinted tail lights, plate bumper, fender flares, pink pink pink :).. so far
    I heard hes into that type of thing
  5. Mar 27, 2014 at 9:46 AM
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    Found this in the towing thread.
    "Gen 1 Tacoma (1995.5-2004)
    The 3.4L V6 (Standard on the s-runner, and 4x4 double cab, and available in xtra-cab and double cab pre-runners as well as the xtra-cab 4x4)
    190 hp @ 4,800 rpm
    220 lb.-ft. @ 3,600 rpm
    Max. Towing capacity 5,000 lbs. (*except s-runner 3,500 lbs.)
    Max. Tongue weight 500 lbs. (*except s-runner 350 lbs.)
    The Gen 1 trucks were NEVER available with a “towing package”
    A relatively small number of trucks did come from the factory with a Toyota class III receiver hitch and 4-flat wiring. The trucks that were factory equipped like this also came with a different pitched fan to pull slightly more air through the radiator.
    Other trucks had the class III hitch and 4-flat wiring installed at the dealer. These trucks do not generally have the alternate fan unless the customer specifically requested it.
    To tow most things safely, these trucks will need some additional aftermarket parts installed such as a brake controller, and an automatic transmission cooler (obviously only if you have an automatic transmission. We’ll cover that later."
  6. Mar 27, 2014 at 10:49 AM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Cool!
    When I was in Dutch, there wasn't eagles or much less trees.
    We had the killer whales swim along side near the $hit shoot for all the unwanted fish we caught and would throw away.
    Biggest thing we caught was a 450lb halibut that was about 12" thick and it was still alive in the net. That was quite a show to see that thing flopping around on deck and then attempting to get it back into the water.
  7. Mar 27, 2014 at 12:06 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
  8. Mar 27, 2014 at 12:41 PM
    Bobert14
    Bobert14 [OP] .
    Not a four point if you go by the just the tip philosophy haha.
  9. Mar 27, 2014 at 1:08 PM
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    woohaa
    Rockwells, kings, open headers, comp cut boggers :cool:
  10. Mar 27, 2014 at 3:35 PM
    Bennett707
    Oregon
    Robert, is that another find? jesus. coordinates please for the weekend?
  11. Mar 27, 2014 at 9:56 PM
    Bennett707
    Oregon
    just picked up a second diehard platinum for $150. i swear they go on sale everytime after i buy something. lets see how much of a hard time they want to give me to return the one i just bought or to wash my sale. -_-
  12. Mar 27, 2014 at 11:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Which one did you get? I was looking at a group 35 for $183 with exchange. :eek:
  13. Mar 28, 2014 at 7:25 AM
    Bennett707
    Oregon
    35 as well.
    i found a few additional coupons to knock that 183 to 160 and had some points i redeemed. if you don't have a shop your way account i recommend getting one. 20 off the top and then $10 of points as well when you purchase the battery.
    e/ i bought the same battery Sunday, and they didn't ask for my old battery. thought that was weird.
  14. Mar 28, 2014 at 8:35 AM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Visiting from Socal anyone hitting trails today or tomorrow near Portland area?
  15. Mar 28, 2014 at 9:20 AM
    J88logue
    Johnny
    HWY 30
    02 D.C. TRD
    Clicko BUILDo
    wish i knew what the fuck you are talking about...:confused:
  16. Mar 28, 2014 at 9:40 AM
    Bennett707
    Oregon
    Battery Jonnie. Diehard Platinum size 35 from Sears.
    Currently listed at 183. Log into/create a Shop Your Way account, apply some additional coupons. Get checkout price for 163 IIRC, and earn $10 additionally in points for a next purchase at Sears. They have some great deals sometimes.
    Sunday I bought one when they were on sale, paid $190 out the door. Checked last night and noticed the price dip, found some coupons, used some points, paid ~$153 OTD, returned my other one for the $190. Due to me using the points I earned for the previous purchase that had been returned ideally my returned amount should be ~180, but for some reason the guy said $195 on the phone. Will verify tonight when I pick up receipts. Very odd, but if it's correct, I just received a $229 listed price battery for $148. Fuck me, right?
  17. Mar 28, 2014 at 5:14 PM
    Bennett707
    Oregon
    Just confirmed I was refunded 195 when I purchased it at 190. The guy said "eh".
    So I got it for $148 and $11.00 worth of points on top of it for the next purchase. Not bad!
  18. Mar 29, 2014 at 9:35 AM
    Bobert14
    Bobert14 [OP] .
    haha yup! Didn't see it until I stepped on it this time. Just been on the family farm outside Yamhill. I think I'm going to start shed hunting up around Barney Reservoir. I've seen some good sized deer come out of that timberland.
    I think I found a new hero. Like a God damn boss. Guns, prerunners, and babes. Good to go.
    https://www.youtube.com/watch?v=-wAB11GndpY
  19. Mar 29, 2014 at 9:38 AM
    Bennett707
    Oregon
    What a bamf.
    5 jets. 44k squarefeet.
  20. Mar 29, 2014 at 10:06 AM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    That was his dad. This guy takes it up a notch from there.
