Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Jun 13, 2014 at 4:37 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I have a spare Elocker third with fresh 4.88's in it if you need one, 150 easy miles on it. Going to pull it this weekend.
  2. Jun 13, 2014 at 4:46 PM
    frycook
    frycook Well-Known Member
    Zach
    Tacoma, WA
    07 Speedway blue TRD OR
    All Pro LT w/ fox 2.5x8" RR coilovers, Rear will have B.A.M.F Shock relocation kit w/ Kind 12" smoothies RR, ATO hybrid bumper, All Pro sliders
    I have an E locker. But thanks though:)
  3. Jun 13, 2014 at 5:16 PM
    Bobert14
    Bobert14 [OP] .
  4. Jun 13, 2014 at 5:31 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I know, I meant for use as a trail spare. It took a couple weeks to get a replacement for the last one I grenaded, I was wishing I had a spare! They are surprisingly tough, but like anything mechanical will eventually fail, especially if you drive like I do. :D Just trying to get back what I have in to it, $650 in person, $700 shipped. Core is $500 on these thirds.
  5. Jun 13, 2014 at 5:46 PM
    frycook
    Zach
    Tacoma, WA
    I don't think I will ever drive as crazy as you! Oh on another note I was about 20 miles away from my spindle popping out of the lower control arm and becoming a statistic lol. Glad that was found!
  6. Jun 13, 2014 at 6:21 PM
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    Does it need adjustment to give the proper pressure (is it fully engaging)? I would think you would notice it slipping in all gears rather than just the top end. Check your clutch fluid as well, but I doubt you are low on it otherwise it would likely not fully disengage and you would grind gears more shifting.
  7. Jun 13, 2014 at 6:34 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Did you resurface the flywheel when you replaced the clutch? If not that would be your problem. Always put a new disk on new metal...
  8. Jun 13, 2014 at 7:00 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Hmm. Try to burn it in. Aggressive, (like 1500 rpm) quickly engage the clutch. Try to bark the tires, but not roast them. Do that about 20 times and see if it still slips. Like brakes, sometimes bedding them in helps. This is especially true with kevlar clutch disks. Stop if you smell burnt clutch or if it slips bad. If you had someone do it take it back to them and have them fix it. ...
  9. Jun 13, 2014 at 7:25 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Microscopically the two surfaces are not mated. The most common indicator is clutch chatter, but slipping can also occur if high spots on the flywheel are riding on high spots on the disk effectively reducing the surface area and therefore the friction available. I know you said they turned it, but that doesn't mean they turned it right. If the disk is made of something like kevlar or ceramic then you have to bed it in. This is common with performance parts. I would take it back to the dudes who installed it and have them unfuck it personally, but you could try to bed it and see what happens. Even going back and forth in the driveway would do it, it doesn't take long.
  10. Jun 13, 2014 at 9:11 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    so im annoyed... Any of you who swapped new rear shocks in have issues? The damn foxes I have, the eyes with sleeves are a little bigger then the bracket on the axle. I just spent 2 hours trying to get ONE in with no luck. I even tried spreading the bracket slightly, but its only spreading the opening only or twisting the ends. Any ideas what my next route is? trick perhaps? Im so over putting the LT kit on... :/
  11. Jun 13, 2014 at 9:14 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Jonnie had a swell time with his , I can't remember if we did anything out of ordinary besides heat?
  12. Jun 13, 2014 at 9:25 PM
    snowgod06
    Rob
    06 Access Cab
    im getting really pissed at it. Their in such a spot that trying to beat just one out is nearly a waste of time, and i cant seem to get leverage enough to bend the whole part of the bracket open. Bout to say F it and just run leafs for life haha.
  13. Jun 13, 2014 at 9:30 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Wut?
    It's not rocket surgery man. Use a bolt with two nuts on it and back off the outer nut to spread it apart. If all else fails post pictures so we can help you.
  14. Jun 13, 2014 at 9:33 PM
    snowgod06
    Rob
    06 Access Cab
    Im just going to shove a bigger pry bar in tomorrow and bend them open. I didnt want to distort them to much, but Im pretty sure the lower shock mount bolt will close them up nicely lol.
  15. Jun 14, 2014 at 8:24 AM
    Bennett707
    Oregon
    So ronery only taco and truck for the st Helens run... I'm gonna branch off with the lady and hike but will convoy up
  16. Jun 14, 2014 at 12:32 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Pictures Rob. I didn't have any issues with fitment of the 2.0 or 2.5s when I installed. The only issue I had was compressing the 2.5 to get on the axle.
  17. Jun 14, 2014 at 2:36 PM
    snowgod06
    Rob
    06 Access Cab
    I got it, used logans trick to spreading the axle mount apart. Never thought of that lol. She getting an alignment as we speak. The rear is a bit higher then the front, but with the new EXPOs I assumed it would be.
  18. Jun 14, 2014 at 6:08 PM
    Mitch
    Mitch
    Spokane, WA
    pics bro
  19. Jun 14, 2014 at 6:18 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  20. Jun 15, 2014 at 8:20 AM
    Mitch
    Mitch
    Spokane, WA
    Joe, I'll be at TM on Saturday in August. Don't think Sunday anymorr
