Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Jul 26, 2015 at 11:28 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I got mine at Kartek, but you can find them on the interwebz all over the place. http://www.kartek.com/Category/486/Bolts-Washers-Nuts.aspx
    They also carry the Pro-Am 12 points, but they are $$$.
    bobsuruncle likes this.
  2. Jul 26, 2015 at 3:27 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    so Ive been doing a little reading today.. Since the rubber isolation piece between my shift lever has failed, Ive been debating my route to fix it. I assumed Id go to a wrecking yard and just get a new shaft. I also thought today that Ill go make it a one piece unit and weld the two halfs together and be done with it (downside is more vibration/noise from transmission).
    After reading coupes thread on xr-u (LINK) im thinking maybe i could just drill 2 holes on either side and fill it with poly epoxy? It seems thats what he does, but after he does a lot of extra crap for a short shifter. I wonder if that will fix the wobble, going through his write up does that seem like it might be a feasible option? Because I may might just say F it and give it a shot. lol
  3. Jul 26, 2015 at 3:32 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Seems like it is a pretty easy job
  4. Jul 26, 2015 at 3:58 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I did the "right stuff" mod about 6 years ago. It lasted a couple years then came completely apart. I cleaned all the rubber out of it and just welded it solid. Just a couple tacks through the holes that were already drilled did it.
  5. Jul 26, 2015 at 9:09 PM
    snowgod06
    Rob
    06 Access Cab
    I know you don't care about extra sound.... lol. I'm trying to keep the inside as quiet ad possible lol. Did you notice welding it solid to be that much louder?
  6. Jul 26, 2015 at 9:11 PM
    lo1dakota
    lo1dakota Well-Known Member
    Brandon
    Longview, Washington
    2007 Speedway blue double cab TRD off road
    OME K&N Short Thow shifter Pro Comp 16" Wheels Toyo 33" Tires Road Armor Bumpers N-Fab full length bars
    Who wants to come wrench on my old Chevy with me and my cousin this weekend? I'll have beer
  7. Jul 27, 2015 at 7:27 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    They REALLY need to do one for a first gen and need a test bed...
    Let me know how that works out for you and I'll consider it. ;)
    Seriously, I'll take a look at it and start taking a look at funding. Thanks! I'd still be interested in a wrench/mod day with other people that might know specifically how to do this. A cruise up into Washington would be doable too at some point if one of these shindigs doesn't happen in the Portland area.
    Edit: Any thoughts on THIS KIT? Is Callahan a good brand? My understanding is that slotted rotors are the best way to go. And the calipers are the bigger 13WL and red, so I don't have to paint them.
    Also, I like these - I got the same ones for the rear when I did the lift. What I don't know is - would I need to order the ones for my 95-97 Taco, or do I need the ones for the 2005 Tundra to match the calipers? I don't know if brake line threads/size are standard or not.
    Edit 2: After reading that exceedingly well done write-up instead of working, I know I can do this myself. Bleeding the brakes would be about the only challenging part I think. And there's also an important side-note about the spare tire...the wheel probably won't fit over the new caliper. Definitely worth a test fit. Workarounds include having a wheel spacer in the toolbox, or if there's a front flat, move a rear tire to the front and put the spare tire on the back. Extra work involved, but would be the cheaper solution.
  8. Jul 27, 2015 at 8:49 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Contrary to popular belief, my truck is very refined. It has several layers of soundproofing and is pleasant to drive down the highway. There is no noise off the shifter, but you do feel some vibration when you rest your hand on it. I find it shifts much more accurately now, and the vibes aren't that big of a deal.
  9. Jul 27, 2015 at 8:50 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    All Toyota brakes (even drums) are threaded M10 female. Order the 95-97 Taco lines.
  10. Jul 27, 2015 at 8:53 AM
    stikle
    Seth
    Perfect, thanks!
  11. Jul 27, 2015 at 11:42 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    What is this shift lever you guys are talking about? The shifter is just one piece... I've taken out the tranmission and can't figure out what you're talking about :notsure:
  12. Jul 27, 2015 at 12:12 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    I think the might be talking about something on an auto?
    I was thinking about when I installed my shortthrow and I can't remember any lever
  13. Jul 27, 2015 at 12:19 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    Username is a manual tho...
  14. Jul 27, 2015 at 12:26 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    You took the tranny out just to see what they were talking about? :joke:
  15. Jul 27, 2015 at 12:29 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    Lol, yeah I'm never taking the damn thing out again! Taken it out two time too many.
  16. Jul 27, 2015 at 12:32 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    They are talking about a manual. On the top of the transmission is a hooked lever that comes up with a ball-shaped end. The shifter shaft connects to this.
  17. Jul 27, 2015 at 12:32 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    How bad was it? I don't have to do a clutch anytime soon but I will eventually.
  18. Jul 27, 2015 at 12:38 PM
    snowgod06
    Rob
    06 Access Cab
    The shift lever on the manual is a two piece unit, with a rubber union more or less between the two. The rubber has failed on mine. Which basically requires you to shift like there's no tomorrow. In gear I can move my whole lever around like it's in neutral, it's really annoying.
  19. Jul 27, 2015 at 12:40 PM
    snowgod06
    Rob
    06 Access Cab
    Green section is where the two parts meet with thr rubber isolation section. Red is of the two pieces.
  20. Jul 27, 2015 at 1:04 PM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Wow I had no idea, thanks for the clarification
