Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Jul 28, 2015 at 2:35 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    My Taco is 91" wide up front, sidewall to sidewall. Ha!
    I would pass on the LC axle. Unless you really enjoy dumping $1000 every time you pop a Birf. Birfields suck, the stock ones last for 200,000+ miles but are easy to pop if you are locked up in the rocks, and the 'moly aftermarket birfs are strong but you can't DD them. Well, you can, but they only last 30,000 miles or so. Plus, it's only an 8" ring gear just like the mini truck. And it's high pinion to boot. It is a step down in strength from stock. The reason they have such a good reputation? 120 hp motors and AWD.
    dakotasyota likes this.
  2. Jul 28, 2015 at 2:41 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I've got experience with birfields coming from a 1st gen p/u. Broke one and switched to longfields. I think they're good, but not for a truck that weighs 5k lbs and pushing 37's or bigger.
  3. Jul 28, 2015 at 2:48 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Bobby Longs are super tough. They are also super soft, almost like spring steel. That makes them capable of absorbing massive shock and torque loads, but they wear very quickly on a DD. I have a worn out set on my '91 FJ80 myself, and I'm trying to decide what to replace them with.
  4. Jul 28, 2015 at 2:54 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Trip report:
    Drove the WABDR starting last Thursday until Sunday.
    The crew was :
    '11 FJ ARB equipped all over and a new battery installed that morning,
    '04 Tacoma DCSB but caged and painted Red/Orange/Yellow on top of Silver,
    '89 Trooper with 33", sliders, skids, rear locker, new carrier bearing installed the day before,
    '03 4Runner - virgin run, 33" with sliders and skids.
    '03 Tacoma DCSB - Yeti.
    3+ hour drive from Renton to Stevenston (awesome burgers at Viking, across the street from Texaco).
    6808 towards Mt. Adams and then encountered the guler ice caves, no ice but very cool on a warm day.
    Camped at a solo sight with an American Flag on a stripped tree/pole paracorded to one of the benches.
    Lots of FS/NF dusty roads - not sure the snorkel was the best plan but whatever.
    Camped as Soda Springs/creek on the 2nd night (not 100% sure of the exact name).
    Woke up to some rain which did knock some dust down, but only for a little while.
    Ran along the route until RimRock lake, then headed East to get into something else besides FS/NF roads = technical off camber steep rocky sections with lots of downed trees/logs. Had to double hook a 4RN front/rear as the off camber soil was super loose causing sliding into a tree at each turn of wheel or forward/reverse progress. To solve the "problem" (a downed tree blocking the easy way thru), a 30K tow strap and the uber powerful 1st gen Yeti in 4lo locked front/rear with some constant pressure and tugging, the downed tree yielded and was removed from offending other fellow travelers. Video to follow... After unclogging the route and getting the "double hooker" out, we were thwarted by a choice of a straight steep loose skree section or an easier not comfortable off camber section. After three failed attempts via the FJ on the skree section, we turned around and continued back onto the WABDR to Bethel Ridge. Ran 325 up and along Bethel Ridge (amazing views) - turned to go down 1400 to Bear Lake and the campground we were going to park at had some Neanderthal glaring at us as we drove in. Ended up camping along 1400 about 1/2 up between Bear Lake and 325.
    In the AM, headed down to Bear Lake again and instead of turning left into the campground, turned right and had a nice hill climb that dropped us off back on top on 325; continued along Bethel Ridge on down to Nile, jumped on the 410 and headed to Little Naches Trail on 18PSI marshmellow tires. Started on the Upper section that has been closed for "erosion abatement" and that section is TIGHT! After passing several NF roads that one can bail out to NF-70, we climb towards the Naches Pass. At a rather fortuitous section of the trail, the clutch on the Trooper $hits the bed. No forward movements. Break out the 30K tow strap and hook it to the FJ and we reverse trail and basically tow/coast out to the backside road the NF-70.
    So next time for us, it will be starting at Nile and run up thru Liberty/Wenatchee/Chelan area.
    Had fun and would do it again...
  5. Jul 28, 2015 at 3:00 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    From a local motorcycle group. If any of you have info, I'll do my best to route it along.
  6. Jul 28, 2015 at 4:47 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Nope. Talking about the roof weather stripping :( mine went mia yesterday
  7. Jul 28, 2015 at 5:24 PM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    That's actually good you had your snorkel. :)
    Fun fact! Aside from water crossings, snorkels were originally designed to help minimize dust from entering the intake, since it's heavy and doesn't accumulate as much up high. I am seriously considering adding one soon, in addition to water/dust protection it should add slightly better MPGs too!
    Thanks for posting this Mike, will keep an eye/ear out. :pray:
    There's this guy:
    https://www.tacomaworld.com/threads/tacoma-roof-strips.374905/
    I wonder if his brother really works at a Toyota dealer, and if so, why do they keep the weather strips if they are in good condition. It's just the pessimist in me thinking "I bet this guy just goes around town ripping them off Tacos" - same thought I get when I see guys selling a ton of tailgates on CL....
  8. Jul 28, 2015 at 5:33 PM
    Chickenmunga
    Keizer, Oregon
    Last bit of info I have:
  9. Jul 28, 2015 at 7:07 PM
    Chickenmunga
    Keizer, Oregon
    Sounds like the people are found, so that's good
    Benson X and Usethe2nd like this.
  10. Jul 28, 2015 at 7:07 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Good!
    I might call around to junk yards later this week. Find someone who has one
  11. Jul 28, 2015 at 9:34 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    @stikle where be our tsf pics lol
  12. Jul 28, 2015 at 10:23 PM
    lo1dakota
    lo1dakota Well-Known Member
    Brandon
    Longview, Washington
    2007 Speedway blue double cab TRD off road
    OME K&N Short Thow shifter Pro Comp 16" Wheels Toyo 33" Tires Road Armor Bumpers N-Fab full length bars
    I got my N-Fab Steps on today!
  13. Jul 29, 2015 at 8:39 AM
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Hmmm...THAT is an exceedingly good question. I will answer in pseudo-Ben form:
    I call this picture "Hello Kitties".
    I've been a little preoccupied the last couple weeks. Sorry...sorta. :D
  14. Jul 29, 2015 at 11:13 AM
    stikle
    Seth
    Ok ok ok...I ordered this kit and . Man...I hope it all works. And more importantly, I hope my bonus payout in September actually happens to pay for this.
    Bennett707[QUOTED] likes this.
  15. Jul 29, 2015 at 11:33 AM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
  16. Jul 29, 2015 at 11:39 AM
    Chickenmunga
    Keizer, Oregon
    you would be very upset, because this swap isn't for 2nd gens. 2nd gens have a much more expensive option, check out what @skygear is doing.
    Bennett707 likes this.
  17. Jul 29, 2015 at 1:13 PM
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
  18. Jul 29, 2015 at 1:19 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    If I had the funds I'd do mine along side yours Seth. Plan to do them yourself?
  19. Jul 29, 2015 at 1:41 PM
    stikle
    Seth
    I read through that most excellent how-to and it seems super straightforward. I've got a dremel and cutoff wheels to notch the dust shield, so that shouldn't be a big deal. Replacing the brake fluid and bleeding the lines seems to be the hardest part since I've never done that before, and it's likely to be difficult with just me.
    Also, the bedding in process seems a little iffy. I don't know where I can legally get to the correct speeds and perform the slowdowns directly after doing the upgrade.
    So yeah...maybe another hand would be...handy. The kit isn't expected to arrive until next week some time next week, so maybe I'll attempt this on the 8th or 9th.
  20. Jul 29, 2015 at 4:38 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I converted my 05 to disk in the rear. I used the front calipers and disks for an 04- taco on a Diamond axle housing. They work great. Frankly the stock front brakes with Porterfield Racing R4 pads and drilled and slotted rotors perform very well. I can squall 37's at highway speeds no problem.
    94755D9B-FAAF-419D-BD67-627DA5E86BCF_zps_e7b7de7beef0b6d2d79214ae15055c9139135168.jpg
