Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Feb 6, 2016 at 11:33 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Auto
  2. Feb 6, 2016 at 11:40 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you had a 1st gen, the answer would definitely be 4.88s. It may still be the right answer for you because of the auto even tho the 4.0 has more grunt than the 3.4.
    If you were a manual, the answer would be a whole lot more subjective.
  3. Feb 6, 2016 at 11:43 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I've heard from some first gens that 4.88's and 285's seem to be perfect so Im thinking it will be with 35's for me, with more reasons than just that.. Im just hoping that since I won't be on 35's for about a year (ordering gears at the end of this month though because I want lockers) that Ill be running the engine to high just to do highway speeds for trips in summer. I guess ill just have to take it slow for one year..
  4. Feb 6, 2016 at 11:51 AM
    Digiratus
    Roaming the PNW
    The RedHead
    With the automatic and 33s, or a manual with 35s, this is true because of the gear ratio within the transmissions.
    The best mod I have done is go to 4.88s. It puts the powerband back into the sweet spot with 33s.
  5. Feb 6, 2016 at 12:53 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    I've got 4.56s with my 33s. Yet i don't have them Installed, but after me readings awhile back it's seemed sensible for my situation. Plus i got a great deal :)
    NorthwestCruiser likes this.
  6. Feb 6, 2016 at 1:12 PM
    snowgod06
    Rob
    06 Access Cab
    Wow.. i fail at life lol. Your wanting 35s...
    Your 4.88s amd 33s for now would for sure have your truck a little more rapped out then om 4.56. But 4.88 would be better for your 35s, depending on what your looking for. More control offroad but a higher rpm on the road.
  7. Feb 6, 2016 at 1:17 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Lol
    Im thinking it'll be worth it and for one year ill just have to drive slower across the state... I think the only time i'll really notice is when im crossing the state for trips in the summer wanting to do 75mph.
  8. Feb 6, 2016 at 3:20 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I have 4.88's with 37's and it is exactly the same as stock gears with stock tires. The speedometer is even correct. If you want stock like performance with 35's, get 4.56 ratio. If you would like slightly deeper gears with 35's, get 4.88. Sure, your top speed will suffer and mileage will suck at freeway speeds with 4.88's and 33's, but you will have some gnarly bottom end! It's not a taco, but I run 4.88's in my FJ80 on 33's. It's like a monster truck in low range, shifts faster than an F1 car, but tops out at about 35mph. It will still do 80mph without having the motor too wound up on road trips.
  9. Feb 6, 2016 at 4:06 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Would anyone be interested in a set of 285/65/16? I think they're 65... my sister in Oregon wants to get rid of them on her Silverado for something that'll get better mileage.
  10. Feb 6, 2016 at 4:12 PM
    Captain Taco
    Captain Taco RipCity
    Rob
    Portland
    2013 Black Tacoma Sport
    3" Lift, Krank Fuel Wheels, TRD Pro Grill, Curved Roof LED Light Bar
    Where in Oregon?
  11. Feb 6, 2016 at 4:12 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I don't remember what it's like being on stock with stock tires haha but that does help. Im 99% sure I won't be going bigger than 35's but who knows.
    Mileage and speed will suffer but it's only for one summer, I think I'll like it better in the end.
  12. Feb 6, 2016 at 4:22 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    Salem. If you have something the same size in a more highway tire as she uses it to haul horses. Cooper discoverer st by the way. Forgot to add that.
  13. Feb 6, 2016 at 4:38 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    And they are 285/75/16... not 65. Load range d
    Captain Taco likes this.
  14. Feb 6, 2016 at 4:51 PM
    Captain Taco
    Rob
    Portland
    I have a set of 285/70/17 I am actually thinking a buddy of mine might be interested. I sent him a message on here with your screenname to see if he is. He has the regular stock Hwy tires that tacomas come with.
    Haslefre[QUOTED] likes this.
  15. Feb 6, 2016 at 6:49 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    Go big. If I know you, you will change to 37's, so take your own advice......:D
  16. Feb 6, 2016 at 6:52 PM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I would but..
    A) I don't want to have to upgrade the rear axle
    B) I want to be able to NOT RUB at full lock/stuff..
    I know @username can fit them without rubbing but I don't want to tub and not sure I want glass fenders for my purposes
  17. Feb 7, 2016 at 10:16 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    If I had it to do over again I would have kept my midtravel setup on 33's. Take my truck for a 3 hour road trip and you're ready to pour gas on it and flick a match. Nothing like loud tires and unbalanced double beadlocks on the freeway, combined with the rattle of bypass shocks on all four corners. When I burn these 37's up I might end up going with 35's on "normal" rims. The added maintenance of LT sucks as well, I don't drive it much because it eats parts.
  18. Feb 7, 2016 at 10:18 AM
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Hmm.. My truck is loud enough now but hopefully going to fix that with dynomat and c-channel rubber on the roof rack.
    Thats my fear with LT is its just a constant tearing apart the front
  19. Feb 7, 2016 at 1:27 PM
    snowgod06
    Rob
    06 Access Cab
    Just get a +2 race kit from TC and be happy. :)
    I need to sell my Allpoo uppers and llowers, coilovers with low miles for the tc setup.
  20. Feb 7, 2016 at 1:46 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Listen to this f*king thing. All of that noise runs right through all of the tubes of the cage, amplifying it.
    https://youtu.be/MJcad_2OwSQ
