Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Apr 12, 2016 at 9:02 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    If anything I'll head down to O, O, O O'Reily!
  2. Apr 12, 2016 at 12:44 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    You need a torque wrench that goes OVER 150, the front axle hub nut gets torqued to 173.
    Rotor falls off once you get the caliper out of the way
    If you need help keep me posted, I may have time
  3. Apr 12, 2016 at 3:46 PM
    JoeTacoma02
    Good lord!! Thanks for the heads up.
  4. Apr 12, 2016 at 3:50 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    no worries... we'll just attach the wrench to a really long bar, and use someone's winch to tighten it down :D
  5. Apr 12, 2016 at 7:03 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Eeeeeek, I definitely didn't get 173ft lbs on mine....... 130 yeah but not 173, holy shit there's parts on the new rock crusher at work that get torqued to that.
    Obligatory new crusher pic setup.
    Got a few more conveyors to swing into place then run the power cables from the 800 ekW genset.
    BenTheMan and TacoSTIG like this.
  6. Apr 12, 2016 at 8:54 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    :puke:
    Nice friend tho a bit too sweet....:)
  7. Apr 12, 2016 at 8:56 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Lmao
  8. Apr 12, 2016 at 10:57 PM
    Chickenmunga
    Keizer, Oregon
    This is my little friend. I bought it partially for this job, and partially because I really wanted a nice torque wrench. My Craftsman handles the stuff below 40 if I really feel the need.
    bobsuruncle[QUOTED] and TacoSTIG like this.
  9. Apr 12, 2016 at 11:13 PM
    TacoSTIG
    TacoSTIG Untamed Member
    Jeremy
    WA, Issaquah
    2005 AC, TRD OR
  10. Apr 13, 2016 at 11:47 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I just used a 12" crescent wrench and got it one grunt tight, which according to my hillbilly engineering conversion manual is around 170 ft lbs.
    BroTaco and Bennett707 like this.
  11. Apr 13, 2016 at 12:59 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Holy $HIT this is HOT!
    JoeTacoma02 likes this.
  12. Apr 13, 2016 at 1:22 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Click type elbows for the win
  13. Apr 13, 2016 at 2:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :eek: You have a 35 mm crescent wrench?
  14. Apr 13, 2016 at 3:52 PM
    JoeTacoma02
    Lol! So hot but sooo good, right? I grew up adding that to noodles similiar to pho whenever my family does noodles. I squeeze lime with the broth to 'simmer' down the hotness.
  15. Apr 13, 2016 at 6:35 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Ya, snap-on. I just looked, it's a 15". Goes to 42mm or so. 1 9/16"
  16. Apr 14, 2016 at 8:35 AM
    Usethe2nd
    Justin
    Fall city
    Welded metal
    Does anyone have a rifle chambered in 280 Remington my LGS sold me a box of 140 gr Remington accutip boat tails thinking they were 270's. $25
  17. Apr 14, 2016 at 9:58 AM
    Bobert14
    Bobert14 [OP] .
    280 Remington? Now that's an odd caliber.
    Anyone ever see Softtopper canopies on craigslist? I would love to pick one up, but never see them on craigslist and the retail price is a little ridiculous for something that isn't quite as durable as a hard canopy.
    Usethe2nd and Yetimetchkangmi like this.
  18. Apr 14, 2016 at 10:12 AM
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    Try checking out a marine shop that makes custom watercraft covers. They may be able to make one for your rack. I'm looking into that myself.
  19. Apr 14, 2016 at 11:14 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Yay. Power is back.
    The wind hit us pretty good yesterday. Ripped up the cover for the airstream, bent the poles that held it, took some branches off the tree and snapped one of my neighbors cherry trees in half. It ripped the roof off the research facility two doors down and took part of their wall with it. When the roof came off, it wrapped half of the metal panels around one of their trucks, the rest took out the power lines and went flying across the street after nailing the neighbors car and house.
  20. Apr 14, 2016 at 1:15 PM
    cahzbrah
    cahzbrah Well-Known Member
    Newcastle, WA
    21 TRD OR 6spd
    Hey whats up guys?
    I'm moving to Bellingham Washington this June from Hawaii, and I was looking at buying new suspension when I get up there. I was wondering what kind of off roading there is up there? Is there any fast dirt roads or anything like that in that area? I am torn in between either getting king coilovers and shocks or just sticking to something less gnarly depending on what kind of trails there are. Don't want to blow money on something I wont be using too much. Thanks for the help!
