Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Mar 13, 2020 at 4:41 PM
    loudboy
    loudboy Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    Anybody know of a good sheetmetal fabricator or welder that would be able to build my camper a new roof? I had zero fiberglass experience before building my roof, and that lack of skill is starting to take effect. I want to replace what I've got now with a similar form made of aluminum. I dont have the space, tools, or time to attempt this new direction on my own. I live in Portland but travel up the Olympic Penninsula often, so anywhere in that range would work. Thanks!
    Here's a good shot of the roof during construction.
    rlx02 likes this.
  2. Mar 13, 2020 at 8:15 PM
    loudboy
    Portland, OR
    Correct. Replacing the fiberglass shell with aluminum preferably (for weight, though I guess steel wouldn't be too bad?). The shell is about 120" long and 56" wide, with a 6" lip. 1/8" aluminum would be perfect. I want it to bolt to the aluminum frame seen under the shell in the first picture.
  3. Mar 13, 2020 at 8:15 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    if the day off lined up right ill help.
  4. Mar 13, 2020 at 8:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if its just waterproffing other options might be possible.
  5. Mar 13, 2020 at 8:21 PM
    loudboy
    Portland, OR
    I'm all ears for options. Waterproof and strong enough to mount roof racks to/through. My fiberglass creation is built around polycarbonate twinwall for weight savings and rigidity but it's proving to be rather fragile and crushable, probably due to my amatuer fiberglass work in sub-par conditions.
    I was looking into aluminum composite board, but there is no good way that I've seen to bend it around a radius. Polycarbonate sheet can be bent well, but is very expensive and heavy in a thickness that is rigid enough.
  6. Mar 13, 2020 at 8:39 PM
    loudboy
    Portland, OR
    MetalSupermarket.com has 4'x8' sheets of 1/8" 5052 for $267. I haven't been able to find any sheets big enough to have one single 6'x12' piece. Seems like I would have to weld multiple pieces together to get the size I need. Unless you've got a better line on big stuff? The polycarbonate twinwall I used for the fiberglass shell was a single 6'x12' sheet before I trimmed and shaped it.
  7. Mar 14, 2020 at 9:50 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Call Coast Aluminum. They have a warehouse off Airport way.
    KalamaKid and loudboy like this.
  8. Mar 16, 2020 at 1:34 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Welp.... I was just told starting tomorrow I'm being sent home until 3/26 at the earliest
    JoeTacoma02 likes this.
  9. Mar 16, 2020 at 2:41 PM
    LeftCoastBestCoast
    LeftCoastBestCoast Well-Known Member
    81D1CF6D-F7B7-4B93-B221-E710D58F6E1A.jpg TP buying spree: “Idiots.”
    *bars close*
    The Bhodi panic is real.
    b_r_o, rlx02 and El Duderino like this.
  10. Mar 16, 2020 at 2:54 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Well shit.
  11. Mar 16, 2020 at 10:08 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Dope! What do you do for a living? Paid for mandatory time off?
  12. Mar 17, 2020 at 7:44 AM
    Toywoodsguy82
    Patrick
    Oregon
    I work for a local government. Yes it’s paid. I’m lucky. I have friends being sent home with no pay
  13. Mar 17, 2020 at 9:22 AM
    JoeTacoma02
    I hear you man. Lots of places are shutting down and many people will be hurt by this. School shut down as well. My daughter, and many, started her spring break early. I still have to go to work since I work at one of the larger hospitals in Portland.
  14. Mar 17, 2020 at 9:47 AM
    Toywoodsguy82
    Patrick
    Oregon
    My work is still open but on a volunteer basis.... I have a wife that is T1D so I can risk getting her sick. I volunteered to stay at home. It will be kind of like an adult spring break
    Praying for all of you working as first responders as police and fire and EMS and hospital workers. I have many friends in those fields and all I can do is sit back and hope for the best. Another one of my friends got tested because one of the confirmed cases came into his store and he started showing symptoms... pretty scary to know that if he tests positive that a lot of people may be affected since he didn’t show symptoms until after he got back from his anniversary at the beach.
    JoeTacoma02[QUOTED] likes this.
  15. Mar 17, 2020 at 5:20 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my good thoughts go to him.
  16. Mar 17, 2020 at 5:22 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Just a friendly reminder to people being at home with their significant others for a hours on end. Give each other plenty of space. Don’t let this stuff sour your relationships.
  17. Mar 17, 2020 at 5:29 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    sharing memes on tw make me and my girl laugh. fun alternative.
    El Duderino[QUOTED] likes this.
  18. Mar 17, 2020 at 5:33 PM
    El Duderino
    Jeremy
    HI->PNW
    Awesome, just remember to keep that 6 foot distance
  19. Mar 17, 2020 at 5:36 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    only at work. if that was even possible.
  20. Mar 17, 2020 at 5:47 PM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    it's the kids that are the problem here. they are annoying each other and getting into fights.
