Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. May 2, 2021 at 11:27 AM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Disappointed to have missed that.
  2. May 2, 2021 at 12:07 PM
    cahzbrah
    cahzbrah Well-Known Member
    Newcastle, WA
    21 TRD OR 6spd
    Wouldn’t hurt to try! PM me your address
  3. May 2, 2021 at 3:48 PM
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    My 2015 Prius has seen a mechanic exactly 1 time in 100,000 miles, to change the trans fluid and the brake fluid. Other than that I'd done all the oil changes. zero issues. great car. 47mpg in town, 42-44 on long road trips,would happily buy another. AND is keeps the raod miles off of my sexy Tacoma
  4. May 3, 2021 at 9:03 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    If it doesn't work for me I'll send it to you!
    BudFriendguy[QUOTED] likes this.
  5. May 4, 2021 at 2:22 PM
    nevadawolf03
    nevadawolf03 Well-Known Member
    PNW
    2016 SR5 DCLB
    SR wheels, side marker black-out, Clazzio's, Tweeters, Tailgate inserts, interior vinyl inserts
    Does anyone have an EV?
    I just got one and want to know if the bid I just got for a home charging station installatiom are within reason.
  6. May 4, 2021 at 2:23 PM
    nevadawolf03
    PNW
    2016 SR5 DCLB
    Also - looking for electricians that aren't going to rip me off :fingerscrossed:
  7. May 5, 2021 at 1:10 PM
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    If you're headed back to the valley, check out Alesong and Block 15 too.
  8. May 5, 2021 at 9:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yumm... Love Sticky Hands from Block 15.
  9. May 7, 2021 at 10:48 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    bobsuruncle and JDAM like this.
  10. May 7, 2021 at 11:22 AM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    :1up:
  11. May 8, 2021 at 6:26 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Sorry @BudFriendguy, it was a perfect fit.
    BudFriendguy likes this.
  12. May 8, 2021 at 6:27 PM
    BudFriendguy
    Zak
    Cheers!
    steelhd[QUOTED] likes this.
  13. May 23, 2021 at 2:00 PM
    503MIKE
    503MIKE Well-Known Member
    Oregon
    2021 AG TRAIL
  14. May 23, 2021 at 3:53 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    Charging stations aren’t in my normal line of electrical work, but guessing your looking at around $100/hr with a 2 hr min charge. Then it’s gona depend on what level charger you have & where you want it installed in relation to your electrical panel location. May know some good electricians/shops, depending on what area your in
    edit- just noticed this was posted a bit ago, probably already got it installed :cheers:
  15. May 23, 2021 at 4:43 PM
    nevadawolf03
    PNW
    2016 SR5 DCLB
    Hi there. No, I haven't done it yet. So far I have had two bids from 850-1100 for labor and that doesn't even include the charging station itself. It just seems a bit high to me since I won't be needing a new electrical panel. I think that maybe there's no shortage of business right now so smaller projects like mine aren't really worth the time? Not really sure but I'll keep looking.
    I'm located in Olympia.
  16. May 23, 2021 at 10:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Not sure if this'll be helpful, but a friend of a friend charged me $750 to add a 50 amp circuit, do a cable run of ~25' and setup a plug for the Tesla. In a Tesla the charging station is part of the vehicle.
  17. May 24, 2021 at 9:41 AM
    nevadawolf03
    PNW
    2016 SR5 DCLB
    Thank you! That is helpful!
    Digiratus[QUOTED] likes this.
  18. May 31, 2021 at 4:27 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    edit - sold
    Superhulk LB and Woodylz like this.
  19. Jun 5, 2021 at 2:26 PM
    50tree
    50tree Well-Known Member
    Portland, OR
    2017 Tacoma TRD OR 4x4 DC-SB
    None yet, that's why I'm here now
    ISO Thule or Yakima tracks for Short bed canopy.
  20. Jun 6, 2021 at 5:03 PM
    nevadawolf03
    PNW
    2016 SR5 DCLB
    OK I'll bite. What kind of Lexus?
