Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Nov 5, 2021 at 8:11 AM
    PDXscottVT
    PDXscottVT Taco Sauce Slurper
    Scott
    Portland, OR
    ‘24 Tundra 1794 Crewmax TRD-OR
    Things and stuff
    cemented likes this.
  2. Nov 5, 2021 at 4:31 PM
    mountaincrawler
    mountaincrawler Well-Known Member
    Hillsboro, OR
    2010 4x4 OR MT
    3" Lift, 35s, 4.88s, Front eLocker, Steel Bumpers, Sliders, URD Clutch Details 3" Lift (AllPro Leafs with Walker Evans 2.5" shocks & Walker Evans 2.5" Non Res Coilovers) Total Chaos UCAs 35" BFGoodrich All-Terrain T/A KO2 17x9 Fuel Offroad Shok D664 4.88 Yukon Diff Gears (ECGS 3rd member) Harrop Elocker (front) Pelfreybilt Front Bumper w/ center hoop Pelfreybilt High Clearance Rear Bumper Pelfreybilt IFS Skid Plate Pelfreybilt Weld On Sliders URD Stage 2 Clutch and Flywheel Relentless Cab Mount Chop Plates ARB Air Compressor AllPro U-Bolt Flip Kit Amp Research BedXtender HD MAX Relentless Bed Rail DUAL Quick Fist Mounts Sport Grille OEM Roof Rack Marshall Offroad Fabrication Bed Bars TEPUI Explorer Series Kukenam 3 Roof Top Tent
    No worries, I'd take the closer one too.
    Unfortunately for me the noise ended up being the wheel bearing and not the needle bearing, and then I ended up swapping the diff anyway lol. Good upgrade regardless though because of the tighter tolerance.
  3. Nov 5, 2021 at 7:16 PM
    PDXscottVT
    Scott
    Portland, OR
    Things and stuff
    I’m just doing it preemptively, since I’ll be doing my lift at the same time… might as well do it all at the same time.
    cemented and Wyckedan like this.
  4. Nov 7, 2021 at 3:16 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Let’s talk tires and wet weather traction. Since it’s now wet and will be for the indeterminate future what is your go to tire? I’m running Toyo At3’s and it seems like it is really easy to break traction. I don’t have much for weight in the back of the truck ( OEM tonneau cover, bed mat, traction boards, compressor and a bag of snow chains). Should probably go buy a sand bag or 2 for when it’s actually slick. The Toyo’s still seem to do better than my old K02’s but I wish there was better traction.
  5. Nov 7, 2021 at 3:21 PM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    The Kenda Klever R/T has been good to me. I have them in a 10.5 width and they’re great.
  6. Nov 7, 2021 at 3:26 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I should have specified I’m on running 285/75r16. I’m tempted to jump to 17’s just for the tire availability
    Wyckedan and gravyboat[QUOTED] like this.
  7. Nov 7, 2021 at 3:35 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    The coopers have definitely treated me well. But that's not to say the extra 100hp you have might change that
    Jensonbt and a2lowvw[QUOTED] like this.
  8. Nov 7, 2021 at 3:40 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The blower definitely doesn’t help. I was data logging going up the “hill” on 124th from willows towards totem lake and anything above 14% throttle would cause tire spin/trac control to engage.
  9. Nov 7, 2021 at 3:52 PM
    Wyckedan
    Dan
    Woodinville WA
    The Falkens are also supposed to be excellent in the wet. They make it in a 315/75/16 and 305/70/16. The extra width might help?
  10. Nov 7, 2021 at 4:04 PM
    mountaincrawler
    Hillsboro, OR
    2010 4x4 OR MT
    I will second that the KO2s aren't great on wet asphalt. I don't have any weight in the rear either but they seem to break loose a little too easily. Amazing for everything else.
  11. Nov 7, 2021 at 4:32 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Don't do it. The 17" volks don't look nearly as good.
    a2lowvw[QUOTED] likes this.
  12. Nov 7, 2021 at 5:55 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    that’s seriously the hold up.
  13. Nov 7, 2021 at 5:59 PM
    Wyckedan
    Dan
    Woodinville WA
  14. Nov 7, 2021 at 6:03 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
  15. Nov 7, 2021 at 6:14 PM
    Wyckedan
    Dan
    Woodinville WA
    Ohhh those are cool and classic. I just found it incredibly amusing you could order beadlocks from Sears
  16. Nov 7, 2021 at 6:38 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    what if the Volks are dash white?! :D
  17. Nov 7, 2021 at 7:00 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    I want white TEs in a real bad way but not enough to go 17s....16" progressives will pop up for sale at some point
  18. Nov 7, 2021 at 7:53 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I think the only way I would do 17’s would be if I was adding beadlocks to get rid of the weird lip but that’s dumb money at that point.
    just added 3 50lb bags of sand to the bed. See if this helps out with my traction woes
  19. Nov 7, 2021 at 7:58 PM
    Wyckedan
    Dan
    Woodinville WA
    Considered a trutrac lsd?
  20. Nov 7, 2021 at 8:06 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Considering 2 truetrac’s and some gears.
