Oregon and Washington BS thread
Discussion in 'North West' started by Bobert14, Dec 22, 2010.
  1. Nov 7, 2021 at 8:26 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I think those would be a perfect fit for you. With how impossible it is to get a quote on gears and a locker I'm considering it too. Everyone only has good things to say about the trutrac
  2. Nov 7, 2021 at 8:33 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    It sounds like Nitro is working on a 3rd member exchange program like ecgs does.
    DoulosXP and WrecklessAbandon like this.
  3. Nov 8, 2021 at 4:57 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Copied from my OP commented in the CL thread by mistake:
  4. Nov 8, 2021 at 10:29 PM
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    Doubt I will ever do anything with it, but I still have all my take off parts sitting on a bottom shelf in my garage. I would not bother swapping out for warranty concerns. I modified the suspension and gearing. I accept that any issues caused by this are my problem, not Toyotas. I have them more so if I ever sell the truck or swap the truck for something else I can take what I have off and put it back to stock and they are not in the way at all in the garage.
    BudFriendguy[QUOTED] likes this.
  5. Nov 9, 2021 at 8:08 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Can confirm, my girlfriend would rather drive my rig with the Kenda Rts, than her rig with Duratracs on the wet roads. Doubted I have a decent amount of weight in the bed and the rear end is pretty softly valved
    gravyboat[QUOTED] likes this.
  6. Nov 9, 2021 at 8:09 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Give me the blower, problem solved :burnrubber:
    NWTacoTime likes this.
  7. Nov 9, 2021 at 8:50 AM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I'm think I'll deal with it
  8. Nov 9, 2021 at 12:26 PM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    Anyone have access too a wall mounted spring compressor upgrading from 650lb too 700lb springs in the OLY area?
  9. Nov 9, 2021 at 12:37 PM
    Wyckedan
    Dan
    Woodinville WA
    I have a set of these, they aren't nearly as sketchy as most spring compressors, but not as easy as a commercial one, but work fine
    https://www.amazon.com/dp/B088GPXCH5
    Bertw192 likes this.
  10. Nov 9, 2021 at 12:39 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
  11. Nov 9, 2021 at 12:41 PM
    Wyckedan
    Dan
    Woodinville WA
    Mine are the knockoff of the SPC, only difference is the lack of rubber on the feet. Solid though, not scared using them
  12. Nov 9, 2021 at 12:43 PM
    4ast4orward
    WA
    Was getting quoted $150-200 too compress the springs if i bring the coil overs in so will probably pick these up if ya'll recommend them. Is it possible too compress the spring while coil over is still on truck with these?
  13. Nov 9, 2021 at 12:44 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Maybe.....haven't tried to squeeze them in there
  14. Nov 9, 2021 at 1:27 PM
    Wyckedan
    Dan
    Woodinville WA
    Yes, but barely. If just trying to adjust preload they'll work, but you don't need them for that. Make sure the Allen is facing out
  15. Nov 9, 2021 at 2:02 PM
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    They'll fit the coilovers while on the truck but not perfectly. Helps to disconnect the UCA while you do it. I can't adjust the preload without compressing the springs a bit. PB Blaster on the preload rings and a 2' bar to leverage on the tool helped.
  16. Nov 9, 2021 at 4:29 PM
    4ast4orward
    WA
    I'll order this, never hurts adding another tool to the arsenal. Thanks for the recommendations and advice everyone!
  17. Nov 9, 2021 at 5:24 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Holy crap. Im able to adjust the Preload on my Tacoma's Kings with an 8" long spanner wrench no cheater bar no spring compressor.
  18. Nov 9, 2021 at 6:14 PM
    Wyckedan
    Dan
    Woodinville WA
    My ADS is pretty easy with just a pin punch
    Siebler[QUOTED] likes this.
  19. Nov 9, 2021 at 6:48 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    you are adjusting them with the wheels off the ground right? The pinch bolt loosened?
  20. Nov 9, 2021 at 8:57 PM
    Siebler
    CJ
    Portland, OR
    Thats how ai do and mine are cake it was @Fletcher37 who seems to be having to do far more work to adjust than anyone else experiences.
    My tool of choice is actually a screwdriver i cut end off of that is perfect diameter. Never could make the Spanner i got at same time as the shocks fit right in coil bucket
